Hi All,
Since the MyOpenHab update a little while back, I’m unable to log in, I also don’t get an email when going through forgot my password process.
My registered email address has a + in it, is that maybe no longer supported?
Regards,
Josh
Hi All,
Regards,
Josh
I have the same issue and also a + in the email adress.
i had the same issue. it worked again after using an email without a “+”. Thanks for your help
I can’t get in to change my email address, did you have to set up a new account?
yes
I can’t seem to make a new account as it says the UUID is already in use on another account.
i deleted the files and uninstalled then reinstalled the binding to get a new uuid
