kolcun
(Mike Kolcun)
July 4, 2023, 9:02pm
1
Hi all,
First time using a lock and I’m having trouble adding my Alfred DB1 Smart Lock to openhab.
Running openHAB 3.3.0 - Release Build on a Raspberry pi.
Using Aeotec Z-Stick Gel 5 (model ZW090-A
Lock: Alfred DB1 - https://products.z-wavealliance.org/products/3373
My procedure to add is
Settings->Things->Click +/Add button
Choose zwave binding
Click Scan
put lock in inclusion mode
see lock show up as a discovered thing
Log entries
16:58:16.689 [INFO ] [openhab.event.InboxAddedEvent ] - Discovery Result with UID 'zwave:device:9f08673cbd:node72' has been added.
16:58:16.689 [INFO ] [ig.discovery.internal.PersistentInbox] - Added new thing 'zwave:device:9f08673cbd:node72' to inbox.
16:58:22.892 [INFO ] [ommandclass.ZWaveSecurityCommandClass] - NODE 72: Using Scheme0 Network Key for Key Exchange since we are in inclusion mode.
16:58:23.097 [INFO ] [ialization.ZWaveNodeInitStageAdvancer] - NODE 72: SECURITY_INC State=COMPLETE
16:58:23.709 [WARN ] [zwave.discovery.ZWaveDiscoveryService] - NODE 72: Device discovery could not resolve to a thingType! 021D:0003:0002::1.4
16:58:26.977 [INFO ] [commandclass.ZWaveVersionCommandClass] - NODE 72: Command Class COMMAND_CLASS_BASIC has version 0!
16:58:27.686 [INFO ] [ommandclass.ZWaveDoorLockCommandClass] - NODE 72: Door-Lock config report - timeoutEnabled=false timeoutMinutes=254, timeoutSeconds=254
16:58:38.647 [INFO ] [openhab.event.InboxRemovedEvent ] - Discovery Result with UID 'zwave:device:9f08673cbd:node72' has been removed.
16:58:38.652 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:9f08673cbd:node72' changed from UNINITIALIZED to INITIALIZING
16:58:38.661 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:9f08673cbd:node72' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
16:58:38.668 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:9f08673cbd:node72' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
16:58:40.571 [INFO ] [ommandclass.ZWaveDoorLockCommandClass] - NODE 72: Door-Lock config report - timeoutEnabled=false timeoutMinutes=254, timeoutSeconds=254
The Thing adds fine, but there are no channels available - Unknown Device
Any pointers on what to try next would be wonderful
thanks!
apella12
(Bob Eckhoff)
July 4, 2023, 10:07pm
2
The lock needs to be added to the OH Zwave DB. The good news is that I see the MFG (Shenzhen Kaadas Intelligent Technology Co., Ltd.), so it will just be a matter to read the blog and upload the xml for that node userdata/zwave or /var/lib/openhab/zwave. (and mark for Review and wait for the next build)
I’m sure you are aware of Pi4 && Aeotec Z-Wave USB Stick Gen5 - Raspberry Pi Forums and have the appropriate mitigation (hub or hardware modification) in place.
kolcun
(Mike Kolcun)
July 5, 2023, 1:31pm
4
@anon71759204 - yup, had this problem in the past I’m running my Aeotec in a powered usb hub.
@apella12 - Thanks for the details - I’ll take a shot at working through the blog to build the new xml.
kolcun
(Mike Kolcun)
August 10, 2023, 7:38pm
5
@apella12 Wondering if you may be able to help with an error I’m seeing with the database entry.
I created the device from the xml file from openhab, and have entered all the detail I’m able to find.
I’m seeing an error
Device definition contains errors!
* Manufacturer UUID"
However I’m not able to clear this - despite having the UID set.
Screenshot of the current database entry.
Any ideas?
Thanks!
apella12
(Bob Eckhoff)
August 10, 2023, 8:06pm
6
kolcun:
My guess is that I may have been wrong about
being all setup in the ZW DB. It was in the dropdown, but maybe it wasn’t associated with 021D. I would open a ticket on the DB site for @chris to take a look. I don’t see anything else.
chris
(Chris Jackson)
August 11, 2023, 12:11am
7
This is because of a database config issue - I’ll look at it now…
kolcun
(Mike Kolcun)
August 11, 2023, 11:05am
8
apella12
(Bob Eckhoff)
August 11, 2023, 9:50pm
9
@kolcun ; If you are done editing hit the “Request Review”, so it will be included in the next build.
kolcun
(Mike Kolcun)
October 11, 2023, 7:57pm
11
I see that the database entry is now marked as OH-SNAPSHOT
. I see the new xml and doc files in GitHub as well.
I’m unclear on how I can update the zwave add-on in my current OH3 install to test it out.
Appreciate any pointers - thanks.
apella12
(Bob Eckhoff)
October 11, 2023, 11:34pm
12
kolcun
(Mike Kolcun)
October 12, 2023, 5:11pm
13
Thanks @apella12 . I might use this as a forcing function to get to OH 4.0 too
apella12
(Bob Eckhoff)
October 12, 2023, 10:08pm
14
That would be a good idea. (4.0)
Only concern I have seen a bit of forum traffic that you might need OH 4.1M2 to use the most recent zwave binding. I think there was a karaf upgrade or something.
kolcun
(Mike Kolcun)
November 15, 2023, 8:00pm
15
I did upgrade to 4.0, however the newly created lock database entry wasn’t included in the 4.0.4 release. I upgraded to the 4.1M3, and the lock works! there are some quirks, but lock/unlock works, and OH status updates to match the lock when manually actuated.
