Max77
(Max)
October 30, 2022, 5:26pm
1
All,
I have some issues with a zigbee device, so I wanted to set the log levels to debug as per best-practice
openhabian@openhabHost:~ $ ssh -p 8101 openhab@localhost
Password authentication
Password:
_ _ _ ____
___ ___ ___ ___ | | | | / \ | __ )
/ _ \ / _ \ / _ \ / _ \ | |_| | / _ \ | _ \
| (_) | (_) | __/| | | || _ | / ___ \ | |_) )
\___/| __/ \___/|_| |_||_| |_|/_/ \_\|____/
|_| 3.3.0 - Release Build
Use '<tab>' for a list of available commands
and '[cmd] --help' for help on a specific command.
To exit, use '<ctrl-d>' or 'logout'.
openhab> log:set debug org.openhab.binding.zigbee
Error executing command: Unable to set level for logger
openhab>
It seems the file has got the right permissions
openhabian@openhabHost:~ $ ls -ltr /var/lib/openhab/etc/log4j2.xml
-rw-r--r-- 1 openhab openhab 6278 Oct 30 18:13 /var/lib/openhab/etc/log4j2.xml
Any idea? Am I missing something obvious?
Thanks!
Max
hmerk
(Hans-JΓΆrg Merk)
October 30, 2022, 5:45pm
2
Please try with uppercase DEBUG
Max77
(Max)
October 30, 2022, 5:47pm
3
Thanks for the prompt feedback
Like this?
openhab> log:set DEBUG org.openhab.binding.zigbee
hmerk
(Hans-JΓΆrg Merk)
October 30, 2022, 5:56pm
4
Yes, strange, never saw such an error.
Max77
(Max)
October 30, 2022, 9:19pm
6
Thanks, unfortunately it seems everything in the right form - I have added both conf files, perhaps somebody could spot some inconsistencies.
Max
openhabian@openhabHost:~ $ ls -ltr /var/lib/openhab/etc/org.ops4j.pax.logging.cfg
-rw-r--r-- 1 openhab openhab 65 Oct 30 20:27 /var/lib/openhab/etc/org.ops4j.pax.logging.cfg
openhabian@openhabHost:~ $ cat /var/lib/openhab/etc/org.ops4j.pax.logging.cfg
org.ops4j.pax.logging.log4j2.config.file=${karaf.etc}/log4j2.xml
-rw-r--r-- 1 openhab openhab 6278 Oct 30 20:27 /var/lib/openhab/etc/log4j2.xml
openhabian@openhabHost:~ $ cat /var/lib/openhab/etc/log4j2.xml
<?xml version="1.0" encoding="UTF-8" standalone="no"?><Configuration monitorInterval="10">
<Appenders>
<!-- Console appender not used by default (see Root logger AppenderRefs) -->
<Console name="STDOUT">
<PatternLayout pattern="%d{HH:mm:ss.SSS} [%-5.5p] [%-36.36c] - %m%n"/>
</Console>
<!-- Rolling file appender -->
<RollingFile fileName="${sys:openhab.logdir}/openhab.log" filePattern="${sys:openhab.logdir}/openhab.log.%i.gz" name="LOGFILE">
<PatternLayout pattern="%d{yyyy-MM-dd HH:mm:ss.SSS} [%-5.5p] [%-36.36c] - %m%n"/>
<Policies>
<OnStartupTriggeringPolicy/>
<SizeBasedTriggeringPolicy size="16 MB"/>
</Policies>
<DefaultRolloverStrategy max="7"/>
</RollingFile>
<!-- Event log appender -->
<RollingRandomAccessFile fileName="${sys:openhab.logdir}/events.log" filePattern="${sys:openhab.logdir}/events.log.%i.gz" name="EVENT">
<Policies>
</Policies>
</RollingRandomAccessFile>
<!-- Audit file appender -->
<RollingRandomAccessFile fileName="${sys:openhab.logdir}/audit.log" filePattern="${sys:openhab.logdir}/audit.log.%i.gz" name="AUDIT">
<Policies>
<SizeBasedTriggeringPolicy size="8 MB"/>
</Policies>
<!-- OSGi appender -->
<PaxOsgi filter="*" name="OSGI"/>
<!-- Zwave custom file appender -->
<RollingRandomAccessFile fileName="${sys:openhab.logdir}/zwave.log" filePattern="${sys:openhab.logdir}/zwave.log.%i" name="ZWAVE">
<Policies>
</Policies>
</Appenders>
<Loggers>
<!-- Root logger configuration -->
<Root level="WARN">
<AppenderRef ref="LOGFILE"/>
<AppenderRef ref="OSGI"/>
</Root>
<!-- Karaf Shell logger -->
<Logger level="OFF" name="org.apache.karaf.shell.support">
<AppenderRef ref="STDOUT"/>
</Logger>
<!-- Security audit logger -->
<Logger additivity="false" level="INFO" name="org.apache.karaf.jaas.modules.audit">
<AppenderRef ref="AUDIT"/>
</Logger>
<!-- openHAB specific logger configuration -->
<Logger level="INFO" name="org.openhab"/>
<Logger level="ERROR" name="openhab.event.ItemStateEvent"/>
<Logger level="ERROR" name="openhab.event.ItemAddedEvent"/>
<Logger level="ERROR" name="openhab.event.ItemRemovedEvent"/>
<Logger level="ERROR" name="openhab.event.ItemChannelLinkAddedEvent"/>
<Logger level="ERROR" name="openhab.event.ItemChannelLinkRemovedEvent"/>
<Logger level="ERROR" name="openhab.event.ChannelDescriptionChangedEvent"/>
<Logger level="ERROR" name="openhab.event.ThingStatusInfoEvent"/>
<Logger level="ERROR" name="openhab.event.ThingAddedEvent"/>
<Logger level="ERROR" name="openhab.event.ThingUpdatedEvent"/>
<Logger level="ERROR" name="openhab.event.ThingRemovedEvent"/>
<Logger level="ERROR" name="openhab.event.InboxUpdatedEvent"/>
<Logger level="ERROR" name="openhab.event.RuleStatusInfoEvent"/>
<Logger level="ERROR" name="openhab.event.RuleAddedEvent"/>
<Logger level="ERROR" name="openhab.event.RuleRemovedEvent"/>
<Logger level="ERROR" name="openhab.event.StartlevelEvent"/>
<Logger level="ERROR" name="openhab.event.AddonEvent"/>
<Logger additivity="false" level="INFO" name="openhab.event">
<AppenderRef ref="EVENT"/>
</Logger>
<!-- openHAB user based script logger configuration -->
<Logger level="TRACE" name="org.openhab.automation.script"/>
<Logger level="ERROR" name="javax.jmdns"/>
<Logger level="ERROR" name="org.jupnp"/>
<!-- This suppresses all Maven download issues from the log when doing feature installations -->
<!-- as we are logging errors ourselves in a nicer way anyhow. -->
<Logger level="ERROR" name="org.ops4j.pax.url.mvn.internal.AetherBasedResolver"/>
<!-- Filters known issues of pax-web (issue link to be added here). -->
<!-- Can be removed once the issues are resolved in an upcoming version. -->
<Logger level="OFF" name="org.ops4j.pax.web.pax-web-runtime"/>
<!-- Filters known issues of lsp4j, see -->
<!-- https://github.com/eclipse/smarthome/issues/4639 -->
<!-- https://github.com/eclipse/smarthome/issues/4629 -->
<!-- https://github.com/eclipse/smarthome/issues/4643 -->
<Logger level="OFF" name="org.eclipse.lsp4j"/>
<!-- Filters warnings for events that could not be delivered to a disconnected client. -->
<Logger level="ERROR" name="org.apache.cxf.jaxrs.sse.SseEventSinkImpl"/>
<!-- Filters known issues of KarServiceImpl, see -->
<!-- https://github.com/openhab/openhab-distro/issues/519#issuecomment-351944506 -->
<Logger level="ERROR" name="org.apache.karaf.kar.internal.KarServiceImpl"/>
<!-- Filters warnings about unavailable ciphers when JCE is not installed, see -->
<!-- https://github.com/openhab/openhab-distro/issues/999 -->
<Logger level="ERROR" name="org.apache.karaf.shell.ssh.SshUtils"/>
<!-- Filters known issues of javax.mail, see -->
<!-- https://github.com/openhab/openhab-addons/issues/5530 -->
<Logger level="ERROR" name="javax.mail"/>
<!-- Filters disconnection warnings of the ChromeCast Java API, see -->
<!-- https://github.com/openhab/openhab-addons/issues/3770 -->
<Logger level="ERROR" name="su.litvak.chromecast.api.v2.Channel"/>
<!-- Added by Karaf to prevent debug logging loops, see -->
<!-- https://issues.apache.org/jira/browse/KARAF-5559 -->
<Logger level="WARN" name="org.apache.sshd"/>
<!-- Logger level="DEBUG" name="org.openhab.binding.zwave"/ -->
<!-- Zwave custom logger -->
<Logger additivity="false" level="INFO" name="org.openhab.binding.zwave">
<AppenderRef ref="ZWAVE"/>
</Logger>
</Loggers>
</Configuration>
What happens if you enter:
log:list | grep -i zigbee
Edit: Just another idea(silly question). Is the binding installed ?
openhab> bundle:list -s | grep -i binding
160 x Active x 80 x 3.4.0.M3 x org.openhab.core.binding.xml
253 x Active x 80 x 3.4.0.M3 x org.openhab.binding.amazonechocontrol
254 x Active x 80 x 3.4.0.M3 x org.openhab.binding.astro
255 x Active x 80 x 3.4.0.M3 x org.openhab.binding.avmfritz
256 x Active x 80 x 3.4.0.M3 x org.openhab.binding.exec
257 x Active x 80 x 3.4.0.M3 x org.openhab.binding.homematic
258 x Active x 80 x 3.4.0.M3 x org.openhab.binding.http
259 x Acti
mdillman
(Markus Dillmann)
November 1, 2022, 7:19am
9
I had the same issue with OH 3.3 release and the Netatmo binding. My βcureβ was to create an entry in the log4j.xml for the binding.
After that was done, I was able to switch log-levels via the console.
I did not investigate further, unfortunately. One similarity I could think of is that I also have an additional appender to log an unrelated item.
Max77
(Max)
November 1, 2022, 6:53pm
10
Interesting
openhab> log:list | grep -i zigbee
openhab>
while the binding is installed (I have a few zigbee devices installed and working)
159 β Active β 80 β 3.3.0 β org.openhab.core.binding.xml
267 β Active β 80 β 3.3.0 β org.openhab.binding.astro
268 β Active β 80 β 3.3.0 β org.openhab.binding.avmfritz
269 β Active β 80 β 3.3.0 β org.openhab.binding.chromecast
270 β Active β 80 β 3.3.0 β org.openhab.binding.exec
271 β Active β 80 β 3.3.0 β org.openhab.binding.icloud
272 β Active β 80 β 3.3.0 β org.openhab.binding.kodi
273 β Active β 80 β 3.3.0 β org.openhab.binding.mpd
274 β Active β 80 β 3.3.0 β org.openhab.binding.mqtt
275 β Active β 81 β 3.3.0 β org.openhab.binding.mqtt.espmilighthub
276 β Active β 81 β 3.3.0 β org.openhab.binding.mqtt.generic
277 β Active β 82 β 3.3.0 β org.openhab.binding.mqtt.homeassistant
278 β Active β 82 β 3.3.0 β org.openhab.binding.mqtt.homie
279 β Active β 80 β 3.3.0 β org.openhab.binding.network
280 β Active β 80 β 3.3.0 β org.openhab.binding.telegram
281 β Active β 80 β 3.3.0 β org.openhab.binding.tradfri
282 β Active β 80 β 3.3.0 β org.openhab.binding.wled
283 β Active β 80 β 3.3.0 β org.openhab.binding.zigbee
284 β Active β 80 β 3.3.0 β org.openhab.binding.zigbee.cc2531
285 β Active β 80 β 3.3.0 β org.openhab.binding.zigbee.console
286 β Active β 80 β 3.3.0 β org.openhab.binding.zigbee.console.ember
287 β Active β 80 β 3.3.0 β org.openhab.binding.zigbee.console.telegesis
288 β Active β 80 β 3.3.0 β org.openhab.binding.zigbee.ember
289 β Active β 80 β 3.3.0 β org.openhab.binding.zigbee.serial
290 β Active β 80 β 3.3.0 β org.openhab.binding.zigbee.telegesis
291 β Active β 80 β 3.3.0 β org.openhab.binding.zigbee.xbee
292 β Active β 80 β 3.3.0 β org.openhab.binding.zwave
openhab>
Does this bing us further in the troubleshooting?
Max
Max77
(Max)
November 1, 2022, 6:55pm
11
Ok, I will keep this in mind. I would love to avoid manual interventions
Letβs wait for @fibu-freak βs opinion on my command output.
Max
Sorry, but I thought, that it could be possible that the bundle is not installed. But as one can see, there is a lot stuff in.
But if you make a log:list | grep -i zigbee nothing is shown. Are all the other bindings in your log:list , and are their levels changeable
openhab> log:list
Logger β Level
ββββββββββββββββββββββββββββββββββββββββββββββββββββΌββββββ
ROOT β WARN
javax.jmdns β ERROR
javax.mail β ERROR
openhab.event β WARN
openhab.event.AddonEvent β ERROR
openhab.event.ChannelDescriptionChangedEvent β ERROR
openhab.event.InboxUpdatedEvent β ERROR
openhab.event.ItemAddedEvent β ERROR
openhab.event.ItemChannelLinkAddedEvent β ERROR
openhab.event.ItemChannelLinkRemovedEvent β ERROR
openhab.event.ItemRemovedEvent β ERROR
openhab.event.ItemStateEvent β ERROR
openhab.event.RuleAddedEvent β ERROR
openhab.event.RuleRemovedEvent β ERROR
openhab.event.RuleStatusInfoEvent β ERROR
openhab.event.StartlevelEvent β ERROR
openhab.event.ThingAddedEvent β ERROR
openhab.event.ThingRemovedEvent β ERROR
openhab.event.ThingStatusInfoEvent β ERROR
openhab.event.ThingUpdatedEvent β ERROR
org.apache.cxf.jaxrs.sse.SseEventSinkImpl β ERROR
org.apache.karaf.jaas.modules.audit β INFO
org.apache.karaf.kar.internal.KarServiceImpl β ERROR
org.apache.karaf.shell.ssh.SshUtils β ERROR
org.apache.karaf.shell.support β OFF
org.apache.sshd β WARN
org.eclipse.lsp4j β OFF
org.jupnp β ERROR
org.openhab β INFO
org.openhab.binding.amazonechocontrol β ERROR
org.openhab.binding.homematic β ERROR
org.ops4j.pax.url.mvn.internal.AetherBasedResolver β ERROR
org.ops4j.pax.web.pax-web-runtime β OFF
su.litvak.chromecast.api.v2.Channel β ERROR
openhab>
As you can see in my snippet of my bundle-list there is a bundle for the avmfritz binding but not so in my log-list.
And i tried:
openhab> bundle:list -s | grep -i avm
openhab> log:list | grep -i org.openhab.binding.avmfritz
openhab>
openhab> log:set error org.openhab.binding.avmfritz
org.openhab.binding.avmfritz x ERROR
openhab> log:set debug org.openhab.binding.avmfritz
org.openhab.binding.avmfritz x DEBUG
openhab>
And the result in frontail is a lot of this:
2022-11-01 22:56:31.087 [DEBUG] [al.handler.AVMFritzBaseBridgeHandler] - Poll FRITZ!Box for updates avmfritz:fritzbox:7490
2022-11-01 22:56:31.690 [DEBUG] [nal.hardware.FritzAhaContentExchange] - HTTP response: 200
2022-11-01 22:56:31.691 [DEBUG] [nal.hardware.FritzAhaContentExchange] - HTTP response: 200
2022-11-01 22:56:31.693 [DEBUG] [nal.hardware.FritzAhaContentExchange] - GET response complete: <devicelist version="1" fwversion="7.29"><device identifier="11960 1003400" id="17" functionbitmask="320" fwversion="03.54" manufacturer="AVM" productname="Comet DECT"><present>1</present><txbusy>0</txbusy><name>Comet DECT #1 Arbeitszimmer</name><battery>50</battery><batterylow>0</batterylow><temperature>
Edit: Maybe you can try it with your AVM-Binding too ??!!
Wolfgang_S
(Wolfgang_S)
November 2, 2022, 7:24am
13
as the file has the right permissions - does your openhab java process run with permissions of openhab ?
That of course should be the case but it would be an explanation that files could not be written.
Max77
(Max)
November 12, 2022, 6:14pm
14
Apologize, @fibu-freak , quite busy days.
I have now tried what you suggested and what I see is different
openhab>
So, it seems there is a general issue with the logging!
Max
Max77
(Max)
November 12, 2022, 6:18pm
15
Hi @Wolfgang_S
I would say yes
openhabian@openhabHost:~ $ ps -ef | grep java
openhab 714 1 3 Oct30 ? 09:48:43 /usr/bin/java -XX:-UsePerfData -Dopenhab.home=/usr/share/openhab -Dopenhab.conf=/etc/openhab -Dopenhab.runtime=/usr/share/openhab/runtime -Dopenhab.userdata=/var/lib/openhab -Dopenhab.logdir=/var/log/openhab -Dfelix.cm.dir=/var/lib/openhab/config -Djava.library.path=/var/lib/openhab/tmp/lib -Djetty.host=0.0.0.0 -Djetty.http.compliance=RFC2616 -Dnashorn.args=--no-deprecation-warning -Dorg.apache.cxf.osgi.http.transport.disable=true -Dorg.ops4j.pax.web.listening.addresses=0.0.0.0 -Dorg.osgi.service.http.port=8080 -Dorg.osgi.service.http.port.secure=8443 -Djava.awt.headless=true -Dfile.encoding=UTF-8 -XX:+ExitOnOutOfMemoryError --add-reads=java.xml=java.logging --add-exports=java.base/org.apache.karaf.specs.locator=java.xml,ALL-UNNAMED --patch-module java.base=/usr/share/openhab/runtime/lib/endorsed/org.apache.karaf.specs.locator-4.3.7.jar --patch-module java.xml=/usr/share/openhab/runtime/lib/endorsed/org.apache.karaf.specs.java.xml-4.3.7.jar --add-opens java.base/java.security=ALL-UNNAMED --add-opens java.base/java.net=ALL-UNNAMED --add-opens java.base/java.lang=ALL-UNNAMED --add-opens java.base/java.util=ALL-UNNAMED --add-opens java.naming/javax.naming.spi=ALL-UNNAMED --add-opens java.rmi/sun.rmi.transport.tcp=ALL-UNNAMED --add-opens java.base/java.io=ALL-UNNAMED --add-opens java.base/java.lang.reflect=ALL-UNNAMED --add-opens java.base/java.text=ALL-UNNAMED --add-opens java.base/java.time=ALL-UNNAMED --add-opens java.desktop/java.awt.font=ALL-UNNAMED --add-exports=java.base/sun.net.www.protocol.file=ALL-UNNAMED --add-exports=java.base/sun.net.www.protocol.ftp=ALL-UNNAMED --add-exports=java.base/sun.net.www.protocol.http=ALL-UNNAMED --add-exports=java.base/sun.net.www.protocol.https=ALL-UNNAMED --add-exports=java.base/sun.net.www.protocol.jar=ALL-UNNAMED --add-exports=java.base/sun.net.www.content.text=ALL-UNNAMED --add-exports=jdk.xml.dom/org.w3c.dom.html=ALL-UNNAMED --add-exports=jdk.naming.rmi/com.sun.jndi.url.rmi=ALL-UNNAMED --add-exports=java.rmi/sun.rmi.registry=ALL-UNNAMED --add-exports=java.security.sasl/com.sun.security.sasl=ALL-UNNAMED -Dkaraf.instances=/var/lib/openhab/tmp/instances -Dkaraf.home=/usr/share/openhab/runtime -Dkaraf.base=/var/lib/openhab -Dkaraf.data=/var/lib/openhab -Dkaraf.etc=/var/lib/openhab/etc -Dkaraf.log=/var/log/openhab -Dkaraf.restart.jvm.supported=true -Djava.io.tmpdir=/var/lib/openhab/tmp -Djava.util.logging.config.file=/var/lib/openhab/etc/java.util.logging.properties -Dkaraf.startLocalConsole=false -Dkaraf.startRemoteShell=true -classpath /usr/share/openhab/runtime/lib/boot/org.apache.karaf.diagnostic.boot-4.3.7.jar:/usr/share/openhab/runtime/lib/boot/org.apache.karaf.jaas.boot-4.3.7.jar:/usr/share/openhab/runtime/lib/boot/org.apache.karaf.main-4.3.7.jar:/usr/share/openhab/runtime/lib/boot/org.apache.karaf.specs.activator-4.3.7.jar:/usr/share/openhab/runtime/lib/boot/osgi.core-7.0.0.jar:/usr/share/openhab/runtime/lib/jdk9plus/istack-commons-runtime-3.0.10.jar:/usr/share/openhab/runtime/lib/jdk9plus/jakarta.xml.bind-api-2.3.3.jar:/usr/share/openhab/runtime/lib/jdk9plus/javax.annotation-api-1.3.2.jar:/usr/share/openhab/runtime/lib/jdk9plus/jaxb-runtime-2.3.3.jar:/usr/share/openhab/runtime/lib/jdk9plus/org.apache.servicemix.specs.activation-api-1.2.1-1.2.1_3.jar:/usr/share/openhab/runtime/lib/jdk9plus/txw2-2.3.3.jar org.apache.karaf.main.Main
I donβt know whether itβs stupid or if it helps what I propose, but have you ever tried
sudo openhab-cli reset-ownership
in the shell-console ?
Cheers,
Peter
Max77
(Max)
November 12, 2022, 8:18pm
17
@fibu-freak
no, I never did it. Unfortunately it does not solve the issue
Thanks anyway!
Max
openhabian@openhabHost:~ $ sudo openhab-cli reset-ownership
[sudo] password for openhabian:
This command gives openHAB control of its own directories.
May resolve permission errors during startup or configuration.
openHAB directories will be owned by openhab:openhab
Okay to Continue? [y/N]: y
Password:
_ _ _ ____
BigCol
(BigCol)
July 4, 2023, 8:44pm
18
Iβm having the same issue running 3.4.2
openhab> log:set DEBUG org.openhab.binding.mqtt
237 x Active x 80 x 1.2.2 x com.hivemq.client.mqtt
266 x Active x 80 x 3.4.2 x org.openhab.binding.mqtt
267 x Active x 81 x 3.4.2 x org.openhab.binding.mqtt.espmili
268 x Active x 81 x 3.4.2 x org.openhab.binding.mqtt.generic
269 x Active x 82 x 3.4.2 x org.openhab.binding.mqtt.homeass
270 x Active x 82 x 3.4.2 x org.openhab.binding.mqtt.homie
was there a fix for this issue?
Colin
Do you see any output for the command log:list?
If not, the chances are good that either org.ops4j.pax.logging.cfg or log4j2.xml are broken.
Get the original file from
BigCol
(BigCol)
July 6, 2023, 12:08pm
20
I do see a response, but it doesnt contain all the bindings i have installed
from my binding files: binding = powermax,zwave,hue,astro,mqtt,tplinksmarthome,openweathermap,ipcamera,rfxcom,mail,sonos,wled
openhab> log:list
Logger β Level
ROOT β WARN
javax.jmdns β ERROR
javax.mail β ERROR
openhab.event β INFO
org.jupnp β ERROR
org.openhab β INFO
org.openhab.automation.script β TRACE
org.openhab.binding.network β OFF
org.openhab.binding.zwave β DEBUG
Max77
(Max)
April 3, 2024, 6:25pm
21
This was indeed - marked as solution!
Thanks and apologize I did not immediately follow up
