System details
runtimeInfo:
version: 3.2.0.M3
buildString: Milestone Build
locale: de-DE
systemInfo:
configFolder: /etc/openhab
userdataFolder: /var/lib/openhab
logFolder: /var/log/openhab
javaVersion: 11.0.9.1
javaVendor: Azul Systems, Inc.
javaVendorVersion: Zulu11.43+100-CA
osName: Linux
osVersion: 5.10.63-v7+
osArchitecture: arm
availableProcessors: 4
freeMemory: 48674904
totalMemory: 247332864
Some days ago I mentioned that there were no new entries in openhab.log and event log…
Today I tried to fix this without success, because I don’t know what this means…
openhab> log:list and log:get gives me the follwig output
22:09:40.740 [Karaf ssh console user openhab] ERROR org.apache.karaf.shell.support.ShellUtil - Exception caught while executing command
java.lang.IllegalStateException: Unrecognized configuration
at org.apache.karaf.log.core.internal.LogServiceImpl.getDelegate(LogServiceImpl.java:63) ~[?:?]
at org.apache.karaf.log.core.internal.LogServiceImpl.getLevel(LogServiceImpl.java:81) ~[?:?]
at org.apache.karaf.log.command.GetLogLevel.execute(GetLogLevel.java:49) ~[?:?]
at org.apache.karaf.shell.impl.action.command.ActionCommand.execute(ActionCommand.java:84) ~[?:?]
at org.apache.karaf.shell.impl.console.osgi.secured.SecuredCommand.execute(SecuredCommand.java:68) ~[?:?]
at org.apache.karaf.shell.impl.console.osgi.secured.SecuredCommand.execute(SecuredCommand.java:86) ~[?:?]
at org.apache.felix.gogo.runtime.Closure.executeCmd(Closure.java:599) ~[?:?]
at org.apache.felix.gogo.runtime.Closure.executeStatement(Closure.java:526) ~[?:?]
at org.apache.felix.gogo.runtime.Closure.execute(Closure.java:415) ~[?:?]
at org.apache.felix.gogo.runtime.Pipe.doCall(Pipe.java:416) ~[?:?]
at org.apache.felix.gogo.runtime.Pipe.call(Pipe.java:229) ~[?:?]
at org.apache.felix.gogo.runtime.Pipe.call(Pipe.java:59) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628) ~[?:?]
Error executing command: Unrecognized configuration
openhab>
Thanks in advance for a helpful suggestion
Paul
Today I did go back to 3.2.0.M2
But i have no idea how to fix this problem
When I type log:list
or
log:tail
always the response is : Error executing command: Unrecognized configuration
Mark_VG
(Mark)
November 1, 2021, 6:54am
3
When last did the logging work - any changes that may have caused the logging to break?
Did you upgrade from <3.0?
Can you share (/userdata/etc):
log4j2.xml
org.ops4j.pax.logging.cfg
Thank you Mark, because of your questions I made one step forward !
→ last entries in openhab.log and events.log are from October 11
→ yes I made changes, but I don’t really remember the details …
→ no, I started from scratch with 3.0 and did some steps towards 3.2.0.M3
3a. /var/lib/openhab/etc/log4j2.xml (for openHAB3 !)
<?xml version="1.0" encoding="UTF-8" standalone="no"?><Configuration monitorInterval="10">
<Appenders>
<!-- Console appender not used by default (see Root logger AppenderRefs) -->
<Console name="STDOUT">
<PatternLayout pattern="%d{HH:mm:ss.SSS} [%-5.5p] [%-36.36c] - %m%n"/>
</Console>
<!-- Rolling file appender -->
<RollingFile fileName="${sys:openhab.logdir}/openhab.log" filePattern="${sys:openhab.logdir}/openhab.log.%i" name="LOGFILE">
<PatternLayout pattern="%d{yyyy-MM-dd HH:mm:ss.SSS} [%-5.5p] [%-36.36c] - %m%n"/>
<Policies>
<OnStartupTriggeringPolicy/>
<SizeBasedTriggeringPolicy size="16 MB"/>
</Policies>
</RollingFile>
<!-- Event log appender -->
<RollingRandomAccessFile fileName="${sys:openhab.logdir}/events.log" filePattern="${sys:openhab.logdir}/events.log.%i" name="EVENT">
<Policies>
</Policies>
</RollingRandomAccessFile>
<!-- Audit file appender -->
<RollingRandomAccessFile fileName="${sys:openhab.logdir}/audit.log" filePattern="${sys:openhab.logdir}/audit.log.%i" name="AUDIT">
<Policies>
<SizeBasedTriggeringPolicy size="8 MB"/>
</Policies>
<!-- OSGi appender -->
<PaxOsgi filter="*" name="OSGI"/>
</Appenders>
<Loggers>
<!-- Root logger configuration -->
<Root level="ERROR">
<AppenderRef ref="LOGFILE"/>
<AppenderRef ref="OSGI"/>
</Root>
<!-- Karaf Shell logger -->
<Logger level="OFF" name="org.apache.karaf.shell.support">
<AppenderRef ref="STDOUT"/>
</Logger>
<!-- Security audit logger -->
<Logger additivity="false" level="INFO" name="org.apache.karaf.jaas.modules.audit">
<AppenderRef ref="AUDIT"/>
</Logger>
<!-- openHAB specific logger configuration -->
<Logger level="DEBUG" name="org.openhab"/>
<Logger level="INFO" name="openhab.event.ItemStateEvent"/>
<Logger level="ERROR" name="openhab.event.ItemAddedEvent"/>
<Logger level="ERROR" name="openhab.event.ItemRemovedEvent"/>
<Logger level="ERROR" name="openhab.event.ItemChannelLinkAddedEvent"/>
<Logger level="ERROR" name="openhab.event.ItemChannelLinkRemovedEvent"/>
<Logger level="DEBUG" name="openhab.event.ThingStatusInfoEvent"/>
<Logger level="ERROR" name="openhab.event.ThingAddedEvent"/>
<Logger level="ERROR" name="openhab.event.ThingUpdatedEvent"/>
<Logger level="ERROR" name="openhab.event.ThingRemovedEvent"/>
<Logger level="ERROR" name="openhab.event.InboxUpdatedEvent"/>
<Logger level="ERROR" name="openhab.event.RuleStatusInfoEvent"/>
<Logger level="ERROR" name="openhab.event.RuleAddedEvent"/>
<Logger level="ERROR" name="openhab.event.RuleRemovedEvent"/>
<Logger level="ERROR" name="openhab.event.StartlevelEvent"/>
<Logger level="ERROR" name="openhab.event.AddonEvent"/>
<Logger additivity="false" level="DEBUG" name="openhab.event">
<AppenderRef ref="EVENT"/>
</Logger>
<Logger level="ERROR" name="javax.jmdns"/>
<Logger level="ERROR" name="org.jupnp"/>
<!-- This suppresses all Maven download issues from the log when doing feature installations -->
<!-- as we are logging errors ourselves in a nicer way anyhow. -->
<Logger level="ERROR" name="org.ops4j.pax.url.mvn.internal.AetherBasedResolver"/>
<!-- Filters known issues of pax-web (issue link to be added here). -->
<!-- Can be removed once the issues are resolved in an upcoming version. -->
<Logger level="OFF" name="org.ops4j.pax.web.pax-web-runtime"/>
<!-- Filters known issues of lsp4j, see -->
<!-- https://github.com/eclipse/smarthome/issues/4639 -->
<!-- https://github.com/eclipse/smarthome/issues/4629 -->
<!-- https://github.com/eclipse/smarthome/issues/4643 -->
<Logger level="OFF" name="org.eclipse.lsp4j"/>
<!-- Filters warnings for events that could not be delivered to a disconnected client. -->
<Logger level="ERROR" name="org.apache.cxf.jaxrs.sse.SseEventSinkImpl"/>
<!-- Filters known issues of KarServiceImpl, see -->
<!-- https://github.com/openhab/openhab-distro/issues/519#issuecomment-351944506 -->
<Logger level="ERROR" name="org.apache.karaf.kar.internal.KarServiceImpl"/>
<!-- Filters warnings about unavailable ciphers when JCE is not installed, see -->
<!-- https://github.com/openhab/openhab-distro/issues/999 -->
<Logger level="ERROR" name="org.apache.karaf.shell.ssh.SshUtils"/>
<!-- Filters known issues of javax.mail, see -->
<!-- https://github.com/openhab/openhab-addons/issues/5530 -->
<Logger level="ERROR" name="javax.mail"/>
<!-- Filters disconnection warnings of the ChromeCast Java API, see -->
<!-- https://github.com/openhab/openhab-addons/issues/3770 -->
<Logger level="ERROR" name="su.litvak.chromecast.api.v2.Channel"/>
<!-- Added by Karaf to prevent debug logging loops, see -->
<!-- https://issues.apache.org/jira/browse/KARAF-5559 -->
<Logger level="ERROR" name="org.apache.sshd"/>
<Logger level="DEBUG" name="org.openhab.core.automation"/>
<Logger level="DEBUG" name="openhab.event.ItemStateChangedEvent"/>
<Logger level="DEBUG" name="org.openhab.core.thing"/>
<Logger level="DEBUG" name="org.openhab.binding.mail"/>
</Loggers>
</Configuration>
3b. /var/lib/openhab/etc/org.ops4j.pax.logging.cfg was emty
→ I copied one line from a backup file
Bingo 1 : openhab.log is filled again !
events.log is still on October 11, no update up to now
Mark_VG
(Mark)
November 1, 2021, 12:15pm
5
Try get the latest log4j2.xml from GutHub. That was how I fixed mine.
I loaded log4j.xml from here
github.com log4j2.xml
restarted openHAB, event.log is still on October 11, no update up to now.
Mark_VG
(Mark)
November 1, 2021, 4:09pm
7
Maybe try rename or delete events.log and see if it is recreated.
Otherwise I am out of ideas.
That’s it!
The solution is:
→ I copied the one and only line from a backup file
----> openhab.log is filled again !
I deleted the events.log and restarted openHAB again, now all seems to be alright!
----> events.log is filled again !
Thank you very much Mark.
+1 here (openhabian 3.2.0-SNAPSHOT - Build #2570 ):
My org.ops4j.pax.logging.cfg was empty.
Adding
org.ops4j.pax.logging.log4j2.config.file=${karaf.etc}/log4j2.xml
and restarting the openhab service solved the problem.
In my case, deleting events.log wasn’t necessary.
@Paul_Vennhaus
Thanks for documenting the solution!
jimtng
(jimtng)
April 30, 2022, 8:29am
10
Thanks! I just came across this issue. You’ve just saved me a lot of time.
I’ve just had to do this on a 3.4.1 install after getting
when trying log:tail and log:display in the console.
This solution worked for me!
FYI I just had the same issue, however openHAB reverted my addition of that line to the file on restart.
However I luckily was able to fix it using the openHAB console using these commands:
config:edit org.ops4j.pax.logging
config:property-set org.ops4j.pax.logging.log4j2.config.file /var/lib/openhab/etc/log4j2.xml
config:update
stagf15
(Phil G)
May 21, 2024, 1:36pm
13
I know this is an old thread, but I just upgraded to OpenHAB 4.2.0.M3 from 4.2.0.M2 on Linux using the package repository (sudo apt upgrade) the way I always do, and I had the same issue. I tried the instructions that @florian-h05 recommended above (editing via console using commands) and they worked perfectly. I did not try editing the file directly. Thanks for help!
kdb
(Klaus-Dieter Brinkmann, Dr.)
June 16, 2024, 12:18pm
14
Hey, what is the one and only line ?
Can you post it ?
