No, it’s a supported plattform. But update process is different.
There a several ways to achieve this:
Run PowerShell as an administrator
cd C:\openHAB2
. .\runtime\bin\update.ps1 Update-openHAB -OHVersion 2.5.0
OR:
Start commandline (as administrator)
cd C:\openHAB2\runtime\bin\
update.bat 2.5.0
OR:
Do it manually (not recommended):
https://www.openhab.org/v2.4/docs/installation/windows.html#updating-the-openhab-runtime
- Stop the openHAB process if it is currently running.
- Backup openHAB as described above.
- Delete the following files and folders from your existing install:
userdata\etc\all.policyuserdata\etc\branding.propertiesuserdata\etc\branding-ssh.propertiesuserdata\etc\config.propertiesuserdata\etc\custom.propertiesuserdata\etc\custom.system.propertiesuserdata\etc\distribution.infouserdata\etc\jre.propertiesuserdata\etc\org.openhab.addons.cfguserdata\etc\org.ops4j.pax.url.mvn.cfguserdata\etc\overrides.propertiesuserdata\etc\profile.cfguserdata\etc\startup.propertiesuserdata\etc\system.propertiesuserdata\etc\version.properties- Any file in
userdata\etcthat starts withorg.apache.karaf - The
userdata\cachefolder - The
userdata\tmpfolder - The
runtimefolder
- Copy and paste the contents of the zip file over your existing install, when prompted do not overwrite existing files
