Today I tried to upgrade my OpenHAB from 3.2.0 to the latest 4.x.x version on OpenHABian on a Raspberry Pi 3B.
Therefore I first of all uninstall java
sudo apt remove java*
Then I installed the Java 17.0.10 LTS version from Zulu and set the environment variables
update-alternatives --install /usr/bin/java java /opt/java/zulu17.42.19-ca-jdk17.0.7-linux_aarch32hf/bin/java 1
update-alternatives --install /usr/bin/javac javac /opt/java/zulu17.42.19-ca-jdk17.0.7-linux_aarch32hf/bin/javac 1
update-alternatives --config java`
which gives me the following output for java-version:
openjdk version “17.0.10” 2024-01-16 LTS
OpenJDK Runtime Environment Zulu17.48+15-CA (build 17.0.10+7-LTS)
OpenJDK Server VM Zulu17.48+15-CA (build 17.0.10+7-LTS, mixed mode)
Next, I fetched the new repo key with this command:
wget -qO- https://openhab.jfrog.io/artifactory/api/gpg/key/public | gpg --dearmor | sudo tee /usr/share/keyrings/openhab.gpg >/dev/null
Then I ran
sudo apt update
sudo apt upgrade
Everything looked ok, except some warnings for bindings, I don’t think I use at all.
But OpenHAB is not reachable via browser. So I restarted Raspberry Pi and checked the logs. Openhab.log:
2024-03-18 14:38:11.526 [INFO ] [ll.impl.action.osgi.CommandExtension] - Unregistering commands for bundle org.openhab.core.karaf/3.2.0
2024-03-18 14:38:11.541 [INFO ] [ll.impl.action.osgi.CommandExtension] - Updating commands for bundle org.apache.karaf.jaas.command/4.3.4
2024-03-18 14:38:11.551 [INFO ] [ll.impl.action.osgi.CommandExtension] - Updating commands for bundle org.apache.karaf.jaas.command/4.3.4
2024-03-18 14:38:23.692 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server’s publish address to be /
2024-03-18 14:38:23.825 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server’s publish address to be /
2024-03-18 14:38:24.075 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server’s publish address to be /
2024-03-18 14:38:24.190 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server’s publish address to be /
2024-03-18 14:38:24.303 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server’s publish address to be /
2024-03-18 14:38:24.389 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server’s publish address to be /
2024-03-18 14:38:24.480 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server’s publish address to be /
2024-03-18 14:38:24.578 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server’s publish address to be /
2024-03-18 14:38:24.656 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server’s publish address to be /
2024-03-18 14:38:24.732 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server’s publish address to be /
2024-03-18 14:38:24.791 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server’s publish address to be /
2024-03-18 14:38:24.844 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server’s publish address to be /
2024-03-18 14:38:24.893 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server’s publish address to be /
2024-03-18 14:38:24.938 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server’s publish address to be /
2024-03-18 14:38:24.975 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server’s publish address to be /
2024-03-18 14:38:25.031 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server’s publish address to be /
2024-03-18 14:38:25.070 [INFO ] [org.apache.cxf.endpoint.ServerImpl ] - Setting the server’s publish address to be /
2024-03-18 14:38:25.317 [INFO ] [vice.internal.HttpServiceFactoryImpl] - Unbinding bundle: [org.openhab.core.io.http.auth_3.2.0 [173]]
2024-03-18 14:38:25.322 [INFO ] [.jetty.server.handler.ContextHandler] - Stopped HttpServiceContext{httpContext=DefaultHttpContext [bundle=org.openhab.core.io.http.auth_3.2.0 [173], contextID=default]}
2024-03-18 14:38:25.349 [INFO ] [vice.internal.HttpServiceFactoryImpl] - Unbinding bundle: [org.openhab.core.audio_3.2.0 [154]]
2024-03-18 14:38:25.353 [INFO ] [.jetty.server.handler.ContextHandler] - Stopped HttpServiceContext{httpContext=DefaultHttpContext [bundle=org.openhab.core.audio_3.2.0 [154], contextID=custom]}
2024-03-18 14:38:25.361 [INFO ] [vice.internal.HttpServiceFactoryImpl] - Unbinding bundle: [org.openhab.core.io.http_3.2.0 [172]]
2024-03-18 14:38:26.026 [INFO ] [ll.impl.action.osgi.CommandExtension] - Unregistering commands for bundle org.apache.karaf.event/4.3.4
2024-03-18 14:38:26.052 [INFO ] [org.apache.cxf.bus.osgi.CXFActivator] - Removing the extensions for bundle 65
2024-03-18 14:38:26.054 [INFO ] [org.apache.cxf.bus.osgi.CXFActivator] - Removing the extensions for bundle 67
2024-03-18 14:38:26.056 [INFO ] [org.apache.cxf.bus.osgi.CXFActivator] - Removing the extensions for bundle 63
2024-03-18 14:38:26.081 [INFO ] [vice.internal.HttpServiceFactoryImpl] - Unbinding bundle: [org.apache.aries.jax.rs.whiteboard_2.0.0 [59]]
2024-03-18 14:38:26.085 [INFO ] [.jetty.server.handler.ContextHandler] - Stopped HttpServiceContext{httpContext=org.ops4j.pax.web.extender.whiteboard.internal.WebApplication$1@48f0a6}
2024-03-18 14:38:26.093 [INFO ] [rd.activator.CxfJaxrsBundleActivator] - destroyed whiteboard from configuration: {service.pid=org.apache.aries.jax.rs.whiteboard.default}
2024-03-18 14:38:26.099 [INFO ] [rd.activator.CxfJaxrsBundleActivator] - Unregistered SseEventSourceFactory
2024-03-18 14:38:26.102 [INFO ] [rd.activator.CxfJaxrsBundleActivator] - Unregistered ClientBuilder
2024-03-18 14:38:26.212 [INFO ] [vice.internal.HttpServiceFactoryImpl] - Unbinding bundle: [org.ops4j.pax.web.pax-web-extender-whiteboard_7.3.23 [220]]
2024-03-18 14:38:26.214 [INFO ] [ll.impl.action.osgi.CommandExtension] - Unregistering commands for bundle org.apache.karaf.http.core/4.3.4
2024-03-18 14:38:26.214 [INFO ] [vice.internal.HttpServiceFactoryImpl] - Unbinding bundle: [org.apache.karaf.http.core_4.3.4 [78]]
2024-03-18 14:38:26.262 [INFO ] [lipse.jetty.server.AbstractConnector] - Stopped 0.0.0.0:8443@138c7cf{SSL, (ssl, http/1.1)}{0.0.0.0:8443}
2024-03-18 14:38:26.266 [INFO ] [lipse.jetty.server.AbstractConnector] - Stopped default@10c04a4{HTTP/1.1, (http/1.1)}{0.0.0.0:8080}
2024-03-18 14:38:26.268 [INFO ] [org.eclipse.jetty.server.session ] - node0 Stopped scavenging
2024-03-18 14:38:26.272 [INFO ] [.jetty.server.handler.ContextHandler] - Stopped o.e.j.s.h.ContextHandler@122a251{/static,null,STOPPED}
2024-03-18 14:38:26.279 [INFO ] [j.pax.web.service.internal.Activator] - ServerControllerFactory is gone, HTTP Service is not available now.
2024-03-18 14:38:26.283 [INFO ] [j.pax.web.service.internal.Activator] - Pax Web stopped
2024-03-18 14:38:26.397 [INFO ] [ll.impl.action.osgi.CommandExtension] - Unregistering commands for bundle org.apache.karaf.system.core/4.3.4
2024-03-18 14:38:26.404 [INFO ] [ll.impl.action.osgi.CommandExtension] - Unregistering commands for bundle org.apache.karaf.shell.ssh/4.3.4
2024-03-18 14:38:26.499 [INFO ] [ll.impl.action.osgi.CommandExtension] - Unregistering commands for bundle org.apache.karaf.service.core/4.3.4
2024-03-18 14:38:26.513 [INFO ] [ll.impl.action.osgi.CommandExtension] - Unregistering commands for bundle org.apache.karaf.package.core/4.3.4
2024-03-18 14:38:26.520 [INFO ] [ll.impl.action.osgi.CommandExtension] - Unregistering commands for bundle org.apache.karaf.log.core/4.3.4
2024-03-18 14:38:26.531 [INFO ] [ll.impl.action.osgi.CommandExtension] - Unregistering commands for bundle org.apache.karaf.kar.core/4.3.4
2024-03-18 14:38:26.540 [INFO ] [ll.impl.action.osgi.CommandExtension] - Unregistering commands for bundle org.apache.karaf.instance.core/4.3.4
2024-03-18 14:38:26.559 [INFO ] [ll.impl.action.osgi.CommandExtension] - Unregistering commands for bundle org.apache.karaf.features.command/4.3.4
2024-03-18 14:38:26.565 [INFO ] [ll.impl.action.osgi.CommandExtension] - Unregistering commands for bundle org.apache.karaf.diagnostic.core/4.3.4
2024-03-18 14:38:26.572 [INFO ] [ll.impl.action.osgi.CommandExtension] - Unregistering commands for bundle org.apache.karaf.config.core/4.3.4
2024-03-18 14:38:26.586 [INFO ] [ll.impl.action.osgi.CommandExtension] - Unregistering commands for bundle org.apache.karaf.bundle.core/4.3.4
2024-03-18 14:38:26.628 [INFO ] [ll.impl.action.osgi.CommandExtension] - Unregistering commands for bundle org.apache.karaf.wrapper.core/4.3.4
2024-03-18 14:38:26.636 [INFO ] [ll.impl.action.osgi.CommandExtension] - Unregistering commands for bundle org.apache.karaf.shell.commands/4.3.4
2024-03-18 14:38:26.638 [INFO ] [ll.impl.action.osgi.CommandExtension] - Unregistering commands for bundle org.apache.karaf.jaas.command/4.3.4
2024-03-18 14:38:26.641 [INFO ] [ll.impl.action.osgi.CommandExtension] - Unregistering commands for bundle org.apache.karaf.deployer.kar/4.3.4
When I request the service’s status with
sudo service status
sudo service openhab status
openhab.service - openHAB instance, reachable at http://openhabian:8080
Loaded: loaded (/lib/systemd/system/openhab.service; enabled; vendor preset: enabled)
Drop-In: /etc/systemd/system/openhab.service.d
└─override.conf
Active: activating (auto-restart) (Result: exit-code) since Mon 2024-03-18 18:45:12 CET; 3s ago
Docs: Introduction | openHAB
https://community.openhab.org
Process: 12981 ExecStart=/usr/share/openhab/runtime/bin/karaf ${OPENHAB_STARTMODE} (code=exited, statu>
Main PID: 12981 (code=exited, status=1/FAILURE)
CPU: 3.730sMar 18 18:45:12 openhabian systemd[1]: openhab.service: Consumed 3.730s CPU time.
Can you please help me what to check further? I think, even if my bindings, items or anything else were now deprecated, OpenHAB should still start and tell me, which bindings, etc. don’t work anymore?!
Thanks and kind regards,
Dirk
