Hello togehter,
I’m somewhat stuck in the upgrade process from OH 3.2 to 3.3.
I’m running openhabian on a LXC-Container.
The upgrade itself works without failures. But after restarting the service only two of my items appear. Both of them are created by text files. All other items disappeared.
I’ve been waiting for at least 15 minutes, but nothing happened.
Also tried the update with clearing the cache according to Clear the cache
Started openhabian with: openhab-cli start --debug
The output is as follows:
openhab> log:display
18:54:55.233 [WARN ] [org.apache.karaf.shell.ssh.SshUtils ] - Configured signature 'sk-ssh-ed25519@openssh.com' not available
18:54:55.257 [WARN ] [org.apache.karaf.shell.ssh.SshUtils ] - Configured signature 'ssh-ed25519' not available
18:54:57.379 [INFO ] [org.openhab.ui.internal.UIService ] - Started UI on port 8080
18:55:06.363 [INFO ] [b.core.internal.i18n.I18nProviderImpl] - Time zone set to 'Europe/Berlin'.
18:55:06.367 [INFO ] [b.core.internal.i18n.I18nProviderImpl] - Location set to '49.02532757697559,9.268421530723574'.
18:55:06.369 [INFO ] [b.core.internal.i18n.I18nProviderImpl] - Locale set to 'de_DE'.
18:55:06.371 [INFO ] [b.core.internal.i18n.I18nProviderImpl] - Measurement system set to 'SI'.
18:55:08.628 [INFO ] [del.core.internal.ModelRepositoryImpl] - Loading model 'influxdb.persist'
18:55:09.116 [INFO ] [del.core.internal.ModelRepositoryImpl] - Loading model 'updategroups.items'
18:55:12.203 [INFO ] [b.core.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
18:55:55.225 [WARN ] [se.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: AutomatedMeterSensor_TotalUsage
18:56:04.363 [WARN ] [.core.karaf.internal.FeatureInstaller] - The binding add-on 'serial1' does not exist - ignoring it.
18:56:04.381 [WARN ] [.core.karaf.internal.FeatureInstaller] - The binding add-on 'plex1' does not exist - ignoring it.
18:56:04.383 [WARN ] [.core.karaf.internal.FeatureInstaller] - The binding add-on 'horizon' does not exist - ignoring it.
18:56:04.397 [WARN ] [.core.karaf.internal.FeatureInstaller] - The ui add-on 'classic' does not exist - ignoring it.
18:56:04.397 [WARN ] [.core.karaf.internal.FeatureInstaller] - The ui add-on 'paper' does not exist - ignoring it.
18:56:08.402 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory] : BundleComponentActivator : ComponentHolder created.
18:56:08.404 [DEBUG] [.EnOceanUsbSerialDiscoveryParticipant] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.discovery.EnOceanUsbSerialDiscoveryParticipant] : BundleComponentActivator : ComponentHolder created.
18:56:08.406 [DEBUG] [ternal.profiles.EnOceanProfileFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory] : BundleComponentActivator : ComponentHolder created.
18:56:08.409 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory] : Dependency Manager created itemChannelLinkRegistryinterface=org.openhab.core.thing.link.ItemChannelLinkRegistry, filter=null, policy=static, cardinality=1..1, bind=null, unbind=null, updated=null, field=itemChannelLinkRegistry, field-option=replace, collection-type=null, parameter=null
18:56:08.410 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory] : Dependency Manager created serialPortManagerinterface=org.openhab.core.io.transport.serial.SerialPortManager, filter=null, policy=static, cardinality=1..1, bind=null, unbind=null, updated=null, field=serialPortManager, field-option=replace, collection-type=null, parameter=null
18:56:08.412 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory] : Dependency Manager created thingManagerinterface=org.openhab.core.thing.ThingManager, filter=null, policy=static, cardinality=1..1, bind=null, unbind=null, updated=null, field=thingManager, field-option=replace, collection-type=null, parameter=null
18:56:08.412 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory] : Component created: DS=DS13, implementation=org.openhab.binding.enocean.internal.EnOceanHandlerFactory, immediate=false, default-enabled=true, factory=null, configuration-policy=optional, activate=activate, deactivate=deactivate, modified=null configuration-pid=[binding.enocean]
18:56:08.414 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory] : Component Services: scope=singleton, services=[org.openhab.core.thing.binding.ThingHandlerFactory]
18:56:08.414 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory] : Component Properties: {}
18:56:08.418 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory] : Querying state disabled
18:56:08.419 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory] : Querying state disabled
18:56:08.420 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory] : Component can not be activated since it is in state disabled
18:56:08.421 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory] : Querying state disabled
18:56:08.422 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : Updating target filters
18:56:08.423 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : No change in target property for dependency itemChannelLinkRegistry: currently registered: false
18:56:08.424 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : No existing service listener to unregister for dependency itemChannelLinkRegistry
18:56:08.425 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : Setting target property for dependency itemChannelLinkRegistry to null
18:56:08.427 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : New service tracker for itemChannelLinkRegistry, initial active: false, previous references: {}, classFilter: (objectClass=org.openhab.core.thing.link.ItemChannelLinkRegistry), initialReferenceFilter (objectClass=org.openhab.core.thing.link.ItemChannelLinkRegistry)
18:56:08.428 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : dm itemChannelLinkRegistry tracker reset (closed)
18:56:08.430 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : dm itemChannelLinkRegistry tracking 1 SingleStatic added {org.openhab.core.thing.link.ItemChannelLinkRegistry}={service.id=377, service.bundleid=210, service.scope=bundle, component.name=org.openhab.core.thing.link.ItemChannelLinkRegistry, component.id=40} (enter)
18:56:08.432 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : dm itemChannelLinkRegistry tracking 1 SingleStatic active: false trackerOpened: false optional: false
18:56:08.433 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : dm itemChannelLinkRegistry tracking 1 SingleStatic added {org.openhab.core.thing.link.ItemChannelLinkRegistry}={service.id=377, service.bundleid=210, service.scope=bundle, component.name=org.openhab.core.thing.link.ItemChannelLinkRegistry, component.id=40} (exit)
18:56:08.435 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : dm itemChannelLinkRegistry tracker opened
18:56:08.436 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : registering service listener for dependency itemChannelLinkRegistry
18:56:08.438 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : No change in target property for dependency serialPortManager: currently registered: false
18:56:08.439 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : No existing service listener to unregister for dependency serialPortManager
18:56:08.440 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : Setting target property for dependency serialPortManager to null
18:56:08.441 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : New service tracker for serialPortManager, initial active: false, previous references: {}, classFilter: (objectClass=org.openhab.core.io.transport.serial.SerialPortManager), initialReferenceFilter (objectClass=org.openhab.core.io.transport.serial.SerialPortManager)
18:56:08.443 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : dm serialPortManager tracker reset (closed)
18:56:08.445 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : dm serialPortManager tracking 2 SingleStatic added {org.openhab.core.io.transport.serial.SerialPortManager}={service.id=460, service.bundleid=280, service.scope=bundle, component.name=org.openhab.core.io.transport.serial.internal.SerialPortManagerImpl, component.id=284} (enter)
18:56:08.446 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : dm serialPortManager tracking 2 SingleStatic active: false trackerOpened: false optional: false
18:56:08.448 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : dm serialPortManager tracking 2 SingleStatic added {org.openhab.core.io.transport.serial.SerialPortManager}={service.id=460, service.bundleid=280, service.scope=bundle, component.name=org.openhab.core.io.transport.serial.internal.SerialPortManagerImpl, component.id=284} (exit)
18:56:08.449 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : dm serialPortManager tracker opened
18:56:08.451 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : registering service listener for dependency serialPortManager
18:56:08.452 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : No change in target property for dependency thingManager: currently registered: false
18:56:08.453 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : No existing service listener to unregister for dependency thingManager
18:56:08.455 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : Setting target property for dependency thingManager to null
18:56:08.455 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : New service tracker for thingManager, initial active: false, previous references: {}, classFilter: (objectClass=org.openhab.core.thing.ThingManager), initialReferenceFilter (objectClass=org.openhab.core.thing.ThingManager)
18:56:08.458 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : dm thingManager tracker reset (closed)
18:56:08.458 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : dm thingManager tracking 3 SingleStatic added {org.openhab.core.thing.ThingTypeMigrationService, org.openhab.core.thing.ThingManager}={service.id=420, service.bundleid=210, service.scope=bundle, component.name=org.openhab.core.thing.internal.ThingManagerImpl, component.id=30} (enter)
18:56:08.461 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : dm thingManager tracking 3 SingleStatic active: false trackerOpened: false optional: false
18:56:08.461 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : dm thingManager tracking 3 SingleStatic added {org.openhab.core.thing.ThingTypeMigrationService, org.openhab.core.thing.ThingManager}={service.id=420, service.bundleid=210, service.scope=bundle, component.name=org.openhab.core.thing.internal.ThingManagerImpl, component.id=30} (exit)
18:56:08.468 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : dm thingManager tracker opened
18:56:08.469 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : registering service listener for dependency thingManager
18:56:08.470 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : Changed state from disabled to unsatisfiedReference
18:56:08.470 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : Component enabled
18:56:08.471 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : ActivateInternal
18:56:08.472 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : Querying state unsatisfiedReference
18:56:08.474 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : Activating component from state unsatisfiedReference
18:56:08.474 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : Querying state unsatisfiedReference
18:56:08.475 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : Querying state unsatisfiedReference
18:56:08.475 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : Changed state from unsatisfiedReference to satisfied
18:56:08.475 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : registration change queue [registered]
18:56:08.477 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : Checking constructor public org.openhab.binding.enocean.internal.EnOceanHandlerFactory()
18:56:08.478 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : Found constructor with 0 arguments : public org.openhab.binding.enocean.internal.EnOceanHandlerFactory()
18:56:08.479 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : getting field: itemChannelLinkRegistry
18:56:08.480 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : Locating field itemChannelLinkRegistry in class org.openhab.binding.enocean.internal.EnOceanHandlerFactory
18:56:08.481 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : getReferenceClass: Looking for interface class org.openhab.core.thing.link.ItemChannelLinkRegistry through loader of org.openhab.binding.enocean.internal.EnOceanHandlerFactory
18:56:08.482 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : getParameterClass: Found class org.openhab.core.thing.link.ItemChannelLinkRegistry
18:56:08.483 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : Found field: org.openhab.core.thing.link.ItemChannelLinkRegistry org.openhab.binding.enocean.internal.EnOceanHandlerFactory.itemChannelLinkRegistry
18:56:08.484 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : getting field: serialPortManager
18:56:08.485 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : Locating field serialPortManager in class org.openhab.binding.enocean.internal.EnOceanHandlerFactory
18:56:08.486 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : getReferenceClass: Looking for interface class org.openhab.core.io.transport.serial.SerialPortManager through loader of org.openhab.binding.enocean.internal.EnOceanHandlerFactory
18:56:08.486 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : getParameterClass: Found class org.openhab.core.io.transport.serial.SerialPortManager
18:56:08.487 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : Found field: org.openhab.core.io.transport.serial.SerialPortManager org.openhab.binding.enocean.internal.EnOceanHandlerFactory.serialPortManager
18:56:08.488 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : getting field: thingManager
18:56:08.488 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : Locating field thingManager in class org.openhab.binding.enocean.internal.EnOceanHandlerFactory
18:56:08.490 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : getReferenceClass: Looking for interface class org.openhab.core.thing.ThingManager through loader of org.openhab.binding.enocean.internal.EnOceanHandlerFactory
18:56:08.490 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : getParameterClass: Found class org.openhab.core.thing.ThingManager
18:56:08.493 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : Found field: org.openhab.core.thing.ThingManager org.openhab.binding.enocean.internal.EnOceanHandlerFactory.thingManager
18:56:08.493 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : This thread collected dependencies
18:56:08.494 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : getService (single component manager) dependencies collected.
18:56:08.494 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : Querying state satisfied
18:56:08.495 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : For dependency itemChannelLinkRegistry, optional: false; to bind: [[RefPair: ref: [{org.openhab.core.thing.link.ItemChannelLinkRegistry}={service.id=377, service.bundleid=210, service.scope=bundle, component.name=org.openhab.core.thing.link.ItemChannelLinkRegistry, component.id=40}] service: [org.openhab.core.thing.link.ItemChannelLinkRegistry@e94cdf]]]
18:56:08.496 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : For dependency serialPortManager, optional: false; to bind: [[RefPair: ref: [{org.openhab.core.io.transport.serial.SerialPortManager}={service.id=460, service.bundleid=280, service.scope=bundle, component.name=org.openhab.core.io.transport.serial.internal.SerialPortManagerImpl, component.id=284}] service: [org.openhab.core.io.transport.serial.internal.SerialPortManagerImpl@c880ab]]]
18:56:08.497 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : For dependency thingManager, optional: false; to bind: [[RefPair: ref: [{org.openhab.core.thing.ThingTypeMigrationService, org.openhab.core.thing.ThingManager}={service.id=420, service.bundleid=210, service.scope=bundle, component.name=org.openhab.core.thing.internal.ThingManagerImpl, component.id=30}] service: [org.openhab.core.thing.internal.ThingManagerImpl@141de25]]]
18:56:08.504 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : getting activate: activate
18:56:08.504 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : Locating method activate in class org.openhab.binding.enocean.internal.EnOceanHandlerFactory
18:56:08.505 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : Declared Method org.openhab.binding.enocean.internal.EnOceanHandlerFactory.activate([interface org.osgi.service.component.ComponentContext]) not found
18:56:08.506 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : Locating method activate in class org.openhab.core.thing.binding.BaseThingHandlerFactory
18:56:08.506 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : Found activate method: protected void org.openhab.core.thing.binding.BaseThingHandlerFactory.activate(org.osgi.service.component.ComponentContext)
18:56:08.507 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : invoking activate: activate: parameters [org.apache.felix.scr.impl.manager.ComponentContextImpl]
18:56:08.508 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : invoked activate: activate
18:56:08.508 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : Set implementation object for component
18:56:08.508 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : Changed state from satisfied to active
18:56:08.509 [DEBUG] [.EnOceanUsbSerialDiscoveryParticipant] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.discovery.EnOceanUsbSerialDiscoveryParticipant] : Component created: DS=DS13, implementation=org.openhab.binding.enocean.internal.discovery.EnOceanUsbSerialDiscoveryParticipant, immediate=false, default-enabled=true, factory=null, configuration-policy=optional, activate=activate, deactivate=deactivate, modified=null configuration-pid=[org.openhab.binding.enocean.internal.discovery.EnOceanUsbSerialDiscoveryParticipant]
18:56:08.509 [DEBUG] [.EnOceanUsbSerialDiscoveryParticipant] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.discovery.EnOceanUsbSerialDiscoveryParticipant] : Component Services: scope=singleton, services=[org.openhab.core.config.discovery.usbserial.UsbSerialDiscoveryParticipant]
18:56:08.509 [DEBUG] [.EnOceanUsbSerialDiscoveryParticipant] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.discovery.EnOceanUsbSerialDiscoveryParticipant] : Component Properties: {}
18:56:08.510 [DEBUG] [.EnOceanUsbSerialDiscoveryParticipant] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.discovery.EnOceanUsbSerialDiscoveryParticipant] : Querying state disabled
18:56:08.510 [DEBUG] [.EnOceanUsbSerialDiscoveryParticipant] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.discovery.EnOceanUsbSerialDiscoveryParticipant] : Component can not be activated since it is in state disabled
18:56:08.511 [DEBUG] [.EnOceanUsbSerialDiscoveryParticipant] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.discovery.EnOceanUsbSerialDiscoveryParticipant(313)] : Updating target filters
18:56:08.511 [DEBUG] [.EnOceanUsbSerialDiscoveryParticipant] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.discovery.EnOceanUsbSerialDiscoveryParticipant(313)] : Changed state from disabled to unsatisfiedReference
18:56:08.511 [DEBUG] [.EnOceanUsbSerialDiscoveryParticipant] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.discovery.EnOceanUsbSerialDiscoveryParticipant(313)] : Component enabled
18:56:08.512 [DEBUG] [.EnOceanUsbSerialDiscoveryParticipant] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.discovery.EnOceanUsbSerialDiscoveryParticipant(313)] : ActivateInternal
18:56:08.512 [DEBUG] [.EnOceanUsbSerialDiscoveryParticipant] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.discovery.EnOceanUsbSerialDiscoveryParticipant(313)] : Querying state unsatisfiedReference
18:56:08.512 [DEBUG] [.EnOceanUsbSerialDiscoveryParticipant] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.discovery.EnOceanUsbSerialDiscoveryParticipant(313)] : Activating component from state unsatisfiedReference
18:56:08.513 [DEBUG] [.EnOceanUsbSerialDiscoveryParticipant] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.discovery.EnOceanUsbSerialDiscoveryParticipant(313)] : Querying state unsatisfiedReference
18:56:08.513 [DEBUG] [.EnOceanUsbSerialDiscoveryParticipant] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.discovery.EnOceanUsbSerialDiscoveryParticipant(313)] : Changed state from unsatisfiedReference to satisfied
18:56:08.513 [DEBUG] [.EnOceanUsbSerialDiscoveryParticipant] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.discovery.EnOceanUsbSerialDiscoveryParticipant(313)] : registration change queue [registered]
18:56:08.514 [DEBUG] [ternal.profiles.EnOceanProfileFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory] : Dependency Manager created $000interface=org.openhab.core.thing.type.ChannelTypeRegistry, filter=null, policy=static, cardinality=1..1, bind=null, unbind=null, updated=null, field=null, field-option=null, collection-type=null, parameter=0
18:56:08.514 [DEBUG] [ternal.profiles.EnOceanProfileFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory] : Component created: DS=DS14, implementation=org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory, immediate=false, default-enabled=true, factory=null, configuration-policy=optional, activate=activate, deactivate=deactivate, modified=null configuration-pid=[org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory]
18:56:08.514 [DEBUG] [ternal.profiles.EnOceanProfileFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory] : Component Services: scope=singleton, services=[org.openhab.core.thing.profiles.ProfileFactory, org.openhab.core.thing.profiles.ProfileAdvisor, org.openhab.core.thing.profiles.ProfileTypeProvider]
18:56:08.515 [DEBUG] [ternal.profiles.EnOceanProfileFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory] : Component Properties: {}
18:56:08.515 [DEBUG] [ternal.profiles.EnOceanProfileFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory] : Querying state disabled
18:56:08.517 [DEBUG] [ternal.profiles.EnOceanProfileFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory] : Component can not be activated since it is in state disabled
18:56:08.535 [DEBUG] [ternal.profiles.EnOceanProfileFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory] : Querying state disabled
18:56:08.535 [DEBUG] [ternal.profiles.EnOceanProfileFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory(314)] : Updating target filters
18:56:08.536 [DEBUG] [ternal.profiles.EnOceanProfileFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory(314)] : No change in target property for dependency $000: currently registered: false
18:56:08.536 [DEBUG] [ternal.profiles.EnOceanProfileFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory(314)] : No existing service listener to unregister for dependency $000
18:56:08.536 [DEBUG] [ternal.profiles.EnOceanProfileFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory(314)] : Setting target property for dependency $000 to null
18:56:08.536 [DEBUG] [ternal.profiles.EnOceanProfileFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory(314)] : New service tracker for $000, initial active: false, previous references: {}, classFilter: (objectClass=org.openhab.core.thing.type.ChannelTypeRegistry), initialReferenceFilter (objectClass=org.openhab.core.thing.type.ChannelTypeRegistry)
18:56:08.536 [DEBUG] [ternal.profiles.EnOceanProfileFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory(314)] : dm $000 tracker reset (closed)
18:56:08.537 [DEBUG] [ternal.profiles.EnOceanProfileFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory(314)] : dm $000 tracking 1 SingleStatic added {org.openhab.core.thing.type.ChannelTypeRegistry}={service.id=157, service.bundleid=210, service.scope=bundle, component.name=org.openhab.core.thing.type.ChannelTypeRegistry, component.id=45} (enter)
18:56:08.537 [DEBUG] [ternal.profiles.EnOceanProfileFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory(314)] : dm $000 tracking 1 SingleStatic active: false trackerOpened: false optional: false
18:56:08.538 [DEBUG] [ternal.profiles.EnOceanProfileFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory(314)] : dm $000 tracking 1 SingleStatic added {org.openhab.core.thing.type.ChannelTypeRegistry}={service.id=157, service.bundleid=210, service.scope=bundle, component.name=org.openhab.core.thing.type.ChannelTypeRegistry, component.id=45} (exit)
18:56:08.538 [DEBUG] [ternal.profiles.EnOceanProfileFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory(314)] : dm $000 tracker opened
18:56:08.538 [DEBUG] [ternal.profiles.EnOceanProfileFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory(314)] : registering service listener for dependency $000
18:56:08.538 [DEBUG] [ternal.profiles.EnOceanProfileFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory(314)] : Changed state from disabled to unsatisfiedReference
18:56:08.538 [DEBUG] [ternal.profiles.EnOceanProfileFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory(314)] : Component enabled
18:56:08.539 [DEBUG] [ternal.profiles.EnOceanProfileFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory(314)] : ActivateInternal
18:56:08.539 [DEBUG] [ternal.profiles.EnOceanProfileFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory(314)] : Querying state unsatisfiedReference
18:56:08.539 [DEBUG] [ternal.profiles.EnOceanProfileFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory(314)] : Activating component from state unsatisfiedReference
18:56:08.540 [DEBUG] [ternal.profiles.EnOceanProfileFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory(314)] : Querying state unsatisfiedReference
18:56:08.540 [DEBUG] [ternal.profiles.EnOceanProfileFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory(314)] : Changed state from unsatisfiedReference to satisfied
18:56:08.540 [DEBUG] [ternal.profiles.EnOceanProfileFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory(314)] : registration change queue [registered]
18:56:08.541 [DEBUG] [ternal.profiles.EnOceanProfileFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory(314)] : Checking constructor public org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory(org.openhab.core.thing.type.ChannelTypeRegistry)
18:56:08.541 [DEBUG] [ternal.profiles.EnOceanProfileFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory(314)] : getReferenceClass: Looking for interface class org.openhab.core.thing.type.ChannelTypeRegistry through loader of org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory
18:56:08.542 [DEBUG] [ternal.profiles.EnOceanProfileFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory(314)] : getParameterClass: Found class org.openhab.core.thing.type.ChannelTypeRegistry
18:56:08.542 [DEBUG] [ternal.profiles.EnOceanProfileFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory(314)] : Found constructor with 1 arguments : public org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory(org.openhab.core.thing.type.ChannelTypeRegistry)
18:56:08.542 [DEBUG] [ternal.profiles.EnOceanProfileFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory(314)] : This thread collected dependencies
18:56:08.542 [DEBUG] [ternal.profiles.EnOceanProfileFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory(314)] : getService (single component manager) dependencies collected.
18:56:08.542 [DEBUG] [ternal.profiles.EnOceanProfileFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory(314)] : Querying state satisfied
18:56:08.559 [DEBUG] [ternal.profiles.EnOceanProfileFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory(314)] : Querying state satisfied
18:56:08.559 [DEBUG] [ternal.profiles.EnOceanProfileFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory(314)] : For dependency $000, optional: false; to bind: [[RefPair: ref: [{org.openhab.core.thing.type.ChannelTypeRegistry}={service.id=157, service.bundleid=210, service.scope=bundle, component.name=org.openhab.core.thing.type.ChannelTypeRegistry, component.id=45}] service: [null]]]
18:56:08.560 [DEBUG] [ternal.profiles.EnOceanProfileFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory(314)] : getting activate: activate
18:56:08.560 [DEBUG] [ternal.profiles.EnOceanProfileFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory(314)] : Locating method activate in class org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory
18:56:08.560 [DEBUG] [ternal.profiles.EnOceanProfileFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory(314)] : Declared Method org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory.activate([interface org.osgi.service.component.ComponentContext]) not found
18:56:08.560 [DEBUG] [ternal.profiles.EnOceanProfileFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory(314)] : Locating method activate in class java.lang.Object
18:56:08.561 [DEBUG] [ternal.profiles.EnOceanProfileFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory(314)] : Declared Method java.lang.Object.activate([interface org.osgi.service.component.ComponentContext]) not found
18:56:08.561 [DEBUG] [ternal.profiles.EnOceanProfileFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory(314)] : activate method [activate] not found, ignoring
18:56:08.561 [DEBUG] [ternal.profiles.EnOceanProfileFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory(314)] : Set implementation object for component
18:56:08.561 [DEBUG] [ternal.profiles.EnOceanProfileFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory(314)] : Changed state from satisfied to active
18:56:08.569 [DEBUG] [.EnOceanUsbSerialDiscoveryParticipant] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.discovery.EnOceanUsbSerialDiscoveryParticipant(313)] : Checking constructor public org.openhab.binding.enocean.internal.discovery.EnOceanUsbSerialDiscoveryParticipant()
18:56:08.569 [DEBUG] [.EnOceanUsbSerialDiscoveryParticipant] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.discovery.EnOceanUsbSerialDiscoveryParticipant(313)] : Found constructor with 0 arguments : public org.openhab.binding.enocean.internal.discovery.EnOceanUsbSerialDiscoveryParticipant()
18:56:08.570 [DEBUG] [.EnOceanUsbSerialDiscoveryParticipant] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.discovery.EnOceanUsbSerialDiscoveryParticipant(313)] : This thread collected dependencies
18:56:08.570 [DEBUG] [.EnOceanUsbSerialDiscoveryParticipant] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.discovery.EnOceanUsbSerialDiscoveryParticipant(313)] : getService (single component manager) dependencies collected.
18:56:08.570 [DEBUG] [.EnOceanUsbSerialDiscoveryParticipant] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.discovery.EnOceanUsbSerialDiscoveryParticipant(313)] : Querying state satisfied
18:56:08.571 [DEBUG] [.EnOceanUsbSerialDiscoveryParticipant] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.discovery.EnOceanUsbSerialDiscoveryParticipant(313)] : getting activate: activate
18:56:08.572 [DEBUG] [.EnOceanUsbSerialDiscoveryParticipant] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.discovery.EnOceanUsbSerialDiscoveryParticipant(313)] : Locating method activate in class org.openhab.binding.enocean.internal.discovery.EnOceanUsbSerialDiscoveryParticipant
18:56:08.572 [DEBUG] [.EnOceanUsbSerialDiscoveryParticipant] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.discovery.EnOceanUsbSerialDiscoveryParticipant(313)] : Declared Method org.openhab.binding.enocean.internal.discovery.EnOceanUsbSerialDiscoveryParticipant.activate([interface org.osgi.service.component.ComponentContext]) not found
18:56:08.572 [DEBUG] [.EnOceanUsbSerialDiscoveryParticipant] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.discovery.EnOceanUsbSerialDiscoveryParticipant(313)] : Locating method activate in class java.lang.Object
18:56:08.573 [DEBUG] [.EnOceanUsbSerialDiscoveryParticipant] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.discovery.EnOceanUsbSerialDiscoveryParticipant(313)] : Declared Method java.lang.Object.activate([interface org.osgi.service.component.ComponentContext]) not found
18:56:08.574 [DEBUG] [.EnOceanUsbSerialDiscoveryParticipant] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.discovery.EnOceanUsbSerialDiscoveryParticipant(313)] : activate method [activate] not found, ignoring
18:56:08.574 [DEBUG] [.EnOceanUsbSerialDiscoveryParticipant] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.discovery.EnOceanUsbSerialDiscoveryParticipant(313)] : Set implementation object for component
18:56:08.574 [DEBUG] [.EnOceanUsbSerialDiscoveryParticipant] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.discovery.EnOceanUsbSerialDiscoveryParticipant(313)] : Changed state from satisfied to active
18:56:08.687 [INFO ] [omekit.internal.HomekitChangeListener] - Created 0 HomeKit items.
18:56:15.659 [INFO ] [ig.discovery.internal.PersistentInbox] - Added new thing 'astro:sun:local' to inbox.
18:56:15.662 [INFO ] [ig.discovery.internal.PersistentInbox] - Added new thing 'astro:moon:local' to inbox.
18:56:15.925 [WARN ] [tty.util.ssl.SslContextFactory.config] - Trusting all certificates configured for Client@ae768b[provider=null,keyStore=null,trustStore=null]
18:56:15.925 [WARN ] [tty.util.ssl.SslContextFactory.config] - No Client EndPointIdentificationAlgorithm configured for Client@ae768b[provider=null,keyStore=null,trustStore=null]
18:56:16.303 [INFO ] [hab.ui.habpanel.internal.HABPanelTile] - Started HABPanel at /habpanel
18:56:42.139 [WARN ] [e.io.rest.auth.internal.TokenResource] - Couldn't find a user with a session matching the provided refresh_token
18:56:42.140 [WARN ] [e.io.rest.auth.internal.TokenResource] - Token issuing failed: invalid_grant
18:57:00.101 [WARN ] [e.io.rest.auth.internal.TokenResource] - Couldn't find a user with a session matching the provided refresh_token
18:57:00.102 [WARN ] [e.io.rest.auth.internal.TokenResource] - Token issuing failed: invalid_grant
18:57:13.847 [WARN ] [se.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: AutomatedMeterSensor_TotalUsage
19:00:00.640 [WARN ] [.core.karaf.internal.FeatureInstaller] - The binding add-on 'serial1' does not exist - ignoring it.
19:00:00.642 [WARN ] [.core.karaf.internal.FeatureInstaller] - The binding add-on 'plex1' does not exist - ignoring it.
19:00:00.646 [WARN ] [.core.karaf.internal.FeatureInstaller] - The binding add-on 'horizon' does not exist - ignoring it.
19:00:00.663 [WARN ] [.core.karaf.internal.FeatureInstaller] - The ui add-on 'classic' does not exist - ignoring it.
19:00:00.665 [WARN ] [.core.karaf.internal.FeatureInstaller] - The ui add-on 'paper' does not exist - ignoring it.
19:00:02.274 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : Querying state active
19:00:02.276 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : Deactivating component
19:00:02.278 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : registration change queue [unregistered]
19:00:02.279 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : Querying state active
19:00:02.280 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : getting deactivate: deactivate
19:00:02.281 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : Locating method deactivate in class org.openhab.binding.enocean.internal.EnOceanHandlerFactory
19:00:02.281 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : Declared Method org.openhab.binding.enocean.internal.EnOceanHandlerFactory.deactivate([interface org.osgi.service.component.ComponentContext]) not found
19:00:02.282 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : Locating method deactivate in class org.openhab.core.thing.binding.BaseThingHandlerFactory
19:00:02.283 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : Found deactivate method: protected void org.openhab.core.thing.binding.BaseThingHandlerFactory.deactivate(org.osgi.service.component.ComponentContext)
19:00:02.286 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : invoking deactivate: deactivate: parameters [org.apache.felix.scr.impl.manager.ComponentContextImpl]
19:00:02.286 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : invoked deactivate: deactivate
19:00:02.287 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : DependencyManager: thingManager close component unbinding from org.apache.felix.scr.impl.manager.ComponentContextImpl@1e80fb6 at tracking count 3 refpairs: [[RefPair: ref: [{org.openhab.core.thing.ThingTypeMigrationService, org.openhab.core.thing.ThingManager}={service.id=420, service.bundleid=210, service.scope=bundle, component.name=org.openhab.core.thing.internal.ThingManagerImpl, component.id=30}] service: [org.openhab.core.thing.internal.ThingManagerImpl@141de25]]]
19:00:02.287 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : DependencyManager: serialPortManager close component unbinding from org.apache.felix.scr.impl.manager.ComponentContextImpl@1e80fb6 at tracking count 2 refpairs: [[RefPair: ref: [{org.openhab.core.io.transport.serial.SerialPortManager}={service.id=460, service.bundleid=280, service.scope=bundle, component.name=org.openhab.core.io.transport.serial.internal.SerialPortManagerImpl, component.id=284}] service: [org.openhab.core.io.transport.serial.internal.SerialPortManagerImpl@c880ab]]]
19:00:02.287 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : DependencyManager: itemChannelLinkRegistry close component unbinding from org.apache.felix.scr.impl.manager.ComponentContextImpl@1e80fb6 at tracking count 1 refpairs: [[RefPair: ref: [{org.openhab.core.thing.link.ItemChannelLinkRegistry}={service.id=377, service.bundleid=210, service.scope=bundle, component.name=org.openhab.core.thing.link.ItemChannelLinkRegistry, component.id=40}] service: [org.openhab.core.thing.link.ItemChannelLinkRegistry@e94cdf]]]
19:00:02.288 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : Unset and deconfigured implementation object for component in deleteComponent for reason Unspecified
19:00:02.288 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : Changed state from active to satisfied
19:00:02.289 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : Deactivating dependency managers
19:00:02.289 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : Disabling dependency managers
19:00:02.289 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : unregistering service listener for dependency itemChannelLinkRegistry
19:00:02.289 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : unregistering service listener for dependency serialPortManager
19:00:02.290 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : unregistering service listener for dependency thingManager
19:00:02.290 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : Querying state satisfied
19:00:02.290 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : Changed state from satisfied to disposed
19:00:02.290 [DEBUG] [nocean.internal.EnOceanHandlerFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.EnOceanHandlerFactory(312)] : Disposing component (reason: 6)
19:00:02.291 [DEBUG] [.EnOceanUsbSerialDiscoveryParticipant] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.discovery.EnOceanUsbSerialDiscoveryParticipant(313)] : Querying state active
19:00:02.291 [DEBUG] [.EnOceanUsbSerialDiscoveryParticipant] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.discovery.EnOceanUsbSerialDiscoveryParticipant(313)] : Deactivating component
19:00:02.291 [DEBUG] [.EnOceanUsbSerialDiscoveryParticipant] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.discovery.EnOceanUsbSerialDiscoveryParticipant(313)] : registration change queue [unregistered]
19:00:02.292 [DEBUG] [.EnOceanUsbSerialDiscoveryParticipant] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.discovery.EnOceanUsbSerialDiscoveryParticipant(313)] : Querying state active
19:00:02.292 [DEBUG] [.EnOceanUsbSerialDiscoveryParticipant] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.discovery.EnOceanUsbSerialDiscoveryParticipant(313)] : getting deactivate: deactivate
19:00:02.292 [DEBUG] [.EnOceanUsbSerialDiscoveryParticipant] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.discovery.EnOceanUsbSerialDiscoveryParticipant(313)] : Locating method deactivate in class org.openhab.binding.enocean.internal.discovery.EnOceanUsbSerialDiscoveryParticipant
19:00:02.293 [DEBUG] [.EnOceanUsbSerialDiscoveryParticipant] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.discovery.EnOceanUsbSerialDiscoveryParticipant(313)] : Declared Method org.openhab.binding.enocean.internal.discovery.EnOceanUsbSerialDiscoveryParticipant.deactivate([interface org.osgi.service.component.ComponentContext]) not found
19:00:02.293 [DEBUG] [.EnOceanUsbSerialDiscoveryParticipant] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.discovery.EnOceanUsbSerialDiscoveryParticipant(313)] : Locating method deactivate in class java.lang.Object
19:00:02.293 [DEBUG] [.EnOceanUsbSerialDiscoveryParticipant] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.discovery.EnOceanUsbSerialDiscoveryParticipant(313)] : Declared Method java.lang.Object.deactivate([interface org.osgi.service.component.ComponentContext]) not found
19:00:02.293 [DEBUG] [.EnOceanUsbSerialDiscoveryParticipant] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.discovery.EnOceanUsbSerialDiscoveryParticipant(313)] : deactivate method [deactivate] not found, ignoring
19:00:02.294 [DEBUG] [.EnOceanUsbSerialDiscoveryParticipant] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.discovery.EnOceanUsbSerialDiscoveryParticipant(313)] : Unset and deconfigured implementation object for component in deleteComponent for reason Unspecified
19:00:02.294 [DEBUG] [.EnOceanUsbSerialDiscoveryParticipant] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.discovery.EnOceanUsbSerialDiscoveryParticipant(313)] : Changed state from active to satisfied
19:00:02.294 [DEBUG] [.EnOceanUsbSerialDiscoveryParticipant] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.discovery.EnOceanUsbSerialDiscoveryParticipant(313)] : Deactivating dependency managers
19:00:02.294 [DEBUG] [.EnOceanUsbSerialDiscoveryParticipant] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.discovery.EnOceanUsbSerialDiscoveryParticipant(313)] : Disabling dependency managers
19:00:02.295 [DEBUG] [.EnOceanUsbSerialDiscoveryParticipant] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.discovery.EnOceanUsbSerialDiscoveryParticipant(313)] : Querying state satisfied
19:00:02.295 [DEBUG] [.EnOceanUsbSerialDiscoveryParticipant] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.discovery.EnOceanUsbSerialDiscoveryParticipant(313)] : Changed state from satisfied to disposed
19:00:02.295 [DEBUG] [.EnOceanUsbSerialDiscoveryParticipant] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.discovery.EnOceanUsbSerialDiscoveryParticipant(313)] : Disposing component (reason: 6)
19:00:02.295 [DEBUG] [ternal.profiles.EnOceanProfileFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory(314)] : Querying state active
19:00:02.296 [DEBUG] [ternal.profiles.EnOceanProfileFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory(314)] : Deactivating component
19:00:02.296 [DEBUG] [ternal.profiles.EnOceanProfileFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory(314)] : registration change queue [unregistered]
19:00:02.297 [DEBUG] [ternal.profiles.EnOceanProfileFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory(314)] : Querying state active
19:00:02.297 [DEBUG] [ternal.profiles.EnOceanProfileFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory(314)] : getting deactivate: deactivate
19:00:02.298 [DEBUG] [ternal.profiles.EnOceanProfileFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory(314)] : Locating method deactivate in class org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory
19:00:02.298 [DEBUG] [ternal.profiles.EnOceanProfileFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory(314)] : Declared Method org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory.deactivate([interface org.osgi.service.component.ComponentContext]) not found
19:00:02.298 [DEBUG] [ternal.profiles.EnOceanProfileFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory(314)] : Locating method deactivate in class java.lang.Object
19:00:02.298 [DEBUG] [ternal.profiles.EnOceanProfileFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory(314)] : Declared Method java.lang.Object.deactivate([interface org.osgi.service.component.ComponentContext]) not found
19:00:02.299 [DEBUG] [ternal.profiles.EnOceanProfileFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory(314)] : deactivate method [deactivate] not found, ignoring
19:00:02.299 [DEBUG] [ternal.profiles.EnOceanProfileFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory(314)] : DependencyManager: $000 close component unbinding from org.apache.felix.scr.impl.manager.ComponentContextImpl@1a75330 at tracking count 1 refpairs: [[RefPair: ref: [{org.openhab.core.thing.type.ChannelTypeRegistry}={service.id=157, service.bundleid=210, service.scope=bundle, component.name=org.openhab.core.thing.type.ChannelTypeRegistry, component.id=45}] service: [org.openhab.core.thing.type.ChannelTypeRegistry@a37e6a]]]
19:00:02.299 [DEBUG] [ternal.profiles.EnOceanProfileFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory(314)] : Unset and deconfigured implementation object for component in deleteComponent for reason Unspecified
19:00:02.299 [DEBUG] [ternal.profiles.EnOceanProfileFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory(314)] : Changed state from active to satisfied
19:00:02.300 [DEBUG] [ternal.profiles.EnOceanProfileFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory(314)] : Deactivating dependency managers
19:00:02.300 [DEBUG] [ternal.profiles.EnOceanProfileFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory(314)] : Disabling dependency managers
19:00:02.300 [DEBUG] [ternal.profiles.EnOceanProfileFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory(314)] : unregistering service listener for dependency $000
19:00:02.300 [DEBUG] [ternal.profiles.EnOceanProfileFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory(314)] : Querying state satisfied
19:00:02.301 [DEBUG] [ternal.profiles.EnOceanProfileFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory(314)] : Changed state from satisfied to disposed
19:00:02.301 [DEBUG] [ternal.profiles.EnOceanProfileFactory] - bundle org.openhab.binding.enocean:3.3.0 (259)[org.openhab.binding.enocean.internal.profiles.EnOceanProfileFactory(314)] : Disposing component (reason: 6)
19:00:04.362 [WARN ] [.core.karaf.internal.FeatureInstaller] - The binding add-on 'serial1' does not exist - ignoring it.
19:00:04.363 [WARN ] [.core.karaf.internal.FeatureInstaller] - The binding add-on 'plex1' does not exist - ignoring it.
19:00:04.364 [WARN ] [.core.karaf.internal.FeatureInstaller] - The binding add-on 'horizon' does not exist - ignoring it.
19:00:04.370 [WARN ] [.core.karaf.internal.FeatureInstaller] - The ui add-on 'classic' does not exist - ignoring it.
19:00:04.371 [WARN ] [.core.karaf.internal.FeatureInstaller] - The ui add-on 'paper' does not exist - ignoring it.
Any hint or help is highly appreciated!
Thanks!
Chris
