I am attempting to create a template widget that will spit out a colorpicker widget for each Hue bulb in a particular room (group). I have already gotten the Hue bridge hooked up, and have been able to manually plop a color picker widget on the page, but am having trouble when I attempt to put one into a template.
The widget itself appears, but does not reflect the state of the bulb, nor does it cause the bulb’s color to change when I click anything.
I was able to get partial success by updating to the latest snapshot, and by using the aCKolor widget. However the color picker widget only seems to work if the item has been hardcoded in it, it won’t work when using the item as part of a variable.
It was definitely a problem with my Angular variables in the end. This Template achieves what I was hoping to (will update with a better style in the near future).
Note that it looks like you need to cause the lightbulbs to update somehow before the color picker widgets populate on this screen.
