I’ve created a rule using the graphical rule engine in HABMin. I’d like to trigger it from a button created in HABPanel.
Is this possible? If so, any pointers?
Thank you.
W.
Thank you.
W.
First, note that I think the graphical rules creator in HABmin is deprecated. I know it has not been updated for OH 2 as it generates OH 1.x style rules.
Create an Design Pattern: Unbound Item (aka Virtual Item) and have commands to that Item be a trigger on the Rule.
Thank you @rlkoshak for your response.
A great shame as when I saw the visual graphical rules creator, it kept me interested in OpenHAB, as I assume these “Design Patterns” are essentially scripts, written in the CLI.
I’ve found several articles and posts on what DP’s are and even what the contents may look like, but I haven’t found anything that states how and where to create them. Any pointers here?
From the beginner pages of the documentation, I learnt about creating rules in conf/rules/
, so what is the difference between rules and DP’s?
Thanks again.
DP stands for “Design Pattern”. Design Pattern: What is a Design Pattern and How Do I Use Them. Put another way, a DP is a chunk of code that can be copied into one of your .rules files and modified to meet your needs.
Pay attention to the “What Should I Know to Use a DP.” You can get this from:
Thanks again @rlkoshak. One more questions, if I may:
I don’t suppose there is an IDE / ISE with ‘intellisense’ (Microsoft Visual Studio / Code term) ?
(IDE / ISE = Integrated development / scripting environment)
