Hi all
I finally found some time to test the Koubachi addon discussed [here] (Koubachi not supporting new values) in a fresh OH2 installation.
As I understand from the Getting Started guide and the forum posts, I simply need to drop the OH1 jar file into the addons folder. I’m not sure if the config file in conf/services/ should be automatically generated. So I manually generated a file called ‘koubachi.cfg’ and copied the two lines from my old config, without the namespace.
But the addon is not displayed in the paper UI under Configuration -> Bindings. Is there anything else I need to do? Already restarted.
