I’m using a great widget by Marcus that can display grafana graphs in a oh-webframe (Grafana chart with time ranges).
I’d like to add a swiper so I can change the charts timerange backwards/forwards in time.
I’ve modified the widget so that it shows different graphs depending on the buttons at the buttom of the widget - when the buttons are pressed a new url is loaded with the corresponding graph that shows a given time period (day, week, month year).
Here is the widget code as it is seen above:
uid: Grafana chart with timeranges v4
tags: []
props:
parameters:
- description: Title of the chart
label: Title
required: false
type: TEXT
- description: URL to show in the frame
label: Source URL
required: true
type: TEXT
- default: from=now-0d%2Fd-1h&to=now-0d%2Fd&viewPanel=3&kiosk;Day,viewPanel=6&kiosk;Week,viewPanel=7&kiosk;Month,viewPanel=8&kiosk;Year
description: Comma-separated List of options. Example "from=now-6h&to=now;-6h,viewPanel=3&kiosk;Day" for past "6h" and "Today so far". First entry is default.
label: Time range options
required: true
type: TEXT
- description: Height of the Frame (empty = default)
label: Height
required: false
type: TEXT
parameterGroups: []
timestamp: Jun 18, 2023, 9:53:36 AM
component: f7-card
outline: true
style:
--f7-card-margin-horizontal: 10px
--f7-card-margin-vertical: 3px
--f7-card-padding-horizontal: 10px
--f7-card-padding-vertical: 100px
box-shadow: 5px 5px 10px 1px rgba(0,0,0,0.3)
margin-bottom: 10px
margin-top: 10px
noShadow: false
title: =props.title
slots:
default:
- component: oh-webframe-card
borders: false
class:
- display-block
height: =props.height
noBorder: false
noShadow: true
src: =props.URL.replace('{period}', vars.selectedPeriod || [props.timerange.split(',')[0].split(';')[0]])
- component: f7-segmented
class:
- padding-bottom-half
outline: false
round: false
style:
--f7-button-border-radius: 4px
--f7-button-font-size: 14px
--f7-button-font-weight: 300
--f7-button-outline-border-width: 1px
--f7-button-padding-horizontal: 0px
--f7-button-padding-vertical: 0px
--f7-button-text-color: "=themeOptions.dark === 'light' ? 'black' : 'white'"
--f7-button-text-transform: none
margin-left: 10px
margin-right: 10px
slots:
default:
- component: oh-repeater
for: size
fragment: true
sourceType: range
slots:
default:
for: period
fragment: true
in: =[props.timerange.split(",")[loop.size].split(";")[1]]
slots:
default:
- component: oh-button
action: variable
actionVariable: selectedPeriod
actionVariableValue: =props.timerange.split(",")[loop.size].split(";")[0]
fill: "=(([props.timerange.split(',')[loop.size].split(';')[0]] == vars.selectedPeriod) || (props.timerange.split(',')[0].split(';')[1] === loop.period) && !vars.selectedPeriod) ? true : false"
outline: true
round: false
style:
--f7-button-border-color: var(--f7-card-outline-border-color)
text: =loop.period
To change these the base url is the same, the only change is the timerange and panel id which looks like the following:
The only thing I need to add is a swiper, that when the arrows are pressed increment/decrement the variable highlighted in the quote above “0”
So initially the daily powerconsumption for today is shown, then i press the left arrow and the new url should be
from=now-1d%2Fd-1h&to=now-1d%2Fd&viewPanel=3&kiosk
I’ve read alot on the forums about variables and seen defineVars and =vars.xx in oh-repeaters, but what the right tool to use and how to implement this so they change part of the props.URL I’m really struggling with, especially since what I need to change is itself in part of a {period} variable
I hope someone can help and point me in the right direction.
Cheers
