2020-11-14 15:48:20.958 [DEBUG] [.internal.handler.VeluxBridgeHandler] - handleCommandScheduled(velux:window:7680cbd2:Dennis_Velux:position,62) called.
2020-11-14 15:48:20.960 [TRACE] [.internal.handler.VeluxBridgeHandler] - handleCommand(Thread[safeCall-14,5,main]) done.
2020-11-14 15:48:20.961 [TRACE] [binding.velux.internal.VeluxItemType] - getByThingAndChannel(velux:window,position) returns enum velux:window/position.
2020-11-14 15:48:20.962 [TRACE] [.velux.internal.handler.VeluxHandler] - handleCommand() done.
2020-11-14 15:48:20.966 [TRACE] [nternal.things.VeluxExistingProducts] - isDirty() returns false.
2020-11-14 15:48:20.968 [TRACE] [.internal.handler.VeluxBridgeHandler] - syncChannelsWithProducts(): no existing products with changed parameters.
2020-11-14 15:48:20.971 [TRACE] [.internal.handler.VeluxBridgeHandler] - handleCommandScheduled(): working on item velux:window:7680cbd2:Dennis_Velux:position (type velux:window/position) with COMMAND 62.
2020-11-14 15:48:20.973 [DEBUG] [rnal.handler.ChannelActuatorPosition] - handleCommand(velux:window:7680cbd2:Dennis_Velux:position,position,62,org.openhab.binding.velux.internal.handler.VeluxBridgeHandler@817c2) called.
2020-11-14 15:48:20.975 [TRACE] [nternal.things.VeluxExistingProducts] - getNoMembers() returns 18.
2020-11-14 15:48:20.978 [TRACE] [rnal.handler.ChannelActuatorPosition] - handleCommand(): there are some existing products.
2020-11-14 15:48:20.980 [TRACE] [rnal.handler.ChannelActuatorPosition] - handleCommand(): found command of type PercentType.
2020-11-14 15:48:20.983 [TRACE] [rnal.handler.ChannelActuatorPosition] - handleCommand(): found command to set level to 62.
2020-11-14 15:48:20.986 [TRACE] [internal.things.VeluxProductPosition] - VeluxProductPosition(62 as PercentType) created.
2020-11-14 15:48:20.988 [DEBUG] [rnal.handler.ChannelActuatorPosition] - handleCommand(): sending command with target level 62.
2020-11-14 15:48:20.990 [TRACE] [.bridge.VeluxBridgeRunProductCommand] - sendCommand(nodeId=1,value=62) called.
2020-11-14 15:48:20.993 [TRACE] [internal.bridge.slip.SlipVeluxBridge] - bridgeAPI() called.
2020-11-14 15:48:20.995 [DEBUG] [rnal.bridge.slip.SCrunProductCommand] - setNodeAndMainParameter(1) called.
2020-11-14 15:48:20.997 [TRACE] [ng.velux.internal.bridge.VeluxBridge] - bridgeCommunicate(Send Command to Actuator) called.
2020-11-14 15:48:20.998 [TRACE] [ng.velux.internal.bridge.VeluxBridge] - isAuthenticated() returns true.
2020-11-14 15:48:20.999 [TRACE] [ng.velux.internal.bridge.VeluxBridge] - bridgeCommunicate(Send Command to Actuator,authenticated) called.
2020-11-14 15:48:21.006 [TRACE] [ng.velux.internal.bridge.VeluxBridge] - isAuthenticated() returns true.
2020-11-14 15:48:21.008 [TRACE] [internal.bridge.slip.SlipVeluxBridge] - bridgeDirectCommunicate(BCP: Send Command to Actuator, authenticated) called.
2020-11-14 15:48:21.010 [TRACE] [internal.bridge.slip.SlipVeluxBridge] - bridgeDirectCommunicate() 'Send Command to Actuator', authenticated
2020-11-14 15:48:21.011 [DEBUG] [rnal.bridge.slip.SCrunProductCommand] - getRequestCommand() returns 0x300.
2020-11-14 15:48:21.013 [TRACE] [rnal.bridge.slip.SCrunProductCommand] - getRequestDataAsArrayOfBytes(): ntfSessionID=2244.
2020-11-14 15:48:21.014 [TRACE] [rnal.bridge.slip.SCrunProductCommand] - getRequestDataAsArrayOfBytes(): reqCommandOriginator=8.
2020-11-14 15:48:21.015 [TRACE] [rnal.bridge.slip.SCrunProductCommand] - getRequestDataAsArrayOfBytes(): reqPriorityLevel=5.
2020-11-14 15:48:21.017 [TRACE] [rnal.bridge.slip.SCrunProductCommand] - getRequestDataAsArrayOfBytes(): reqParameterActive=0.
2020-11-14 15:48:21.018 [TRACE] [rnal.bridge.slip.SCrunProductCommand] - getRequestDataAsArrayOfBytes(): reqFPI1=0.
2020-11-14 15:48:21.019 [TRACE] [rnal.bridge.slip.SCrunProductCommand] - getRequestDataAsArrayOfBytes(): reqFPI2=0.
2020-11-14 15:48:21.020 [TRACE] [rnal.bridge.slip.SCrunProductCommand] - getRequestDataAsArrayOfBytes(): reqMainParameter=31744.
2020-11-14 15:48:21.022 [TRACE] [rnal.bridge.slip.SCrunProductCommand] - getRequestDataAsArrayOfBytes(): reqIndexArrayCount=1.
2020-11-14 15:48:21.023 [TRACE] [rnal.bridge.slip.SCrunProductCommand] - getRequestDataAsArrayOfBytes(): reqIndexArray01=1.
2020-11-14 15:48:21.024 [TRACE] [rnal.bridge.slip.SCrunProductCommand] - getRequestDataAsArrayOfBytes(): reqPriorityLevelLock=0.
2020-11-14 15:48:21.025 [TRACE] [rnal.bridge.slip.SCrunProductCommand] - getRequestDataAsArrayOfBytes(): reqPL03=0.
2020-11-14 15:48:21.027 [TRACE] [rnal.bridge.slip.SCrunProductCommand] - getRequestDataAsArrayOfBytes(): reqPL47=0.
2020-11-14 15:48:21.028 [TRACE] [rnal.bridge.slip.SCrunProductCommand] - getRequestDataAsArrayOfBytes(): reqLockTime=0.
2020-11-14 15:48:21.030 [TRACE] [rnal.bridge.slip.SCrunProductCommand] - getRequestDataAsArrayOfBytes() data is 08 C4 08 05 00 00 00 7C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00.
2020-11-14 15:48:21.032 [DEBUG] [internal.bridge.slip.SlipVeluxBridge] - bridgeDirectCommunicate() [192.168.0.21] GW_COMMAND_SEND_REQ => started => Thread[pool-43-thread-1,5,main]
2020-11-14 15:48:21.033 [TRACE] [internal.bridge.slip.SlipVeluxBridge] - bridgeDirectCommunicate() [192.168.0.21] GW_COMMAND_SEND_REQ => send mode => preparing command
2020-11-14 15:48:21.035 [TRACE] [ernal.bridge.slip.utils.SlipEncoding] - SlipEncoding(constructor) for command 0x300 with data size 66 called.
2020-11-14 15:48:21.037 [TRACE] [ernal.bridge.slip.utils.SlipEncoding] - SlipEncoding(constructor) successfully initialized, storing bytes: 00 45 03 00 08 C4 08 05 00 00 00 7C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FB.
2020-11-14 15:48:21.038 [TRACE] [ternal.bridge.slip.utils.SlipRFC1055] - encode() for data size 71 called.
2020-11-14 15:48:21.041 [TRACE] [ternal.bridge.slip.utils.SlipRFC1055] - encode() provides transfer encoding: C0 00 45 03 00 08 C4 08 05 00 00 00 7C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FB C0.
2020-11-14 15:48:21.042 [TRACE] [internal.bridge.slip.SlipVeluxBridge] - bridgeDirectCommunicate() [192.168.0.21] GW_COMMAND_SEND_REQ => command ready => start sending
2020-11-14 15:48:21.044 [TRACE] [internal.bridge.slip.SlipVeluxBridge] - bridgeDirectCommunicate() [192.168.0.21] GW_COMMAND_SEND_REQ => GW_COMMAND_SEND_REQ => sending data => 08 C4 08 05 00 00 00 7C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
2020-11-14 15:48:21.046 [TRACE] [x.internal.bridge.slip.io.Connection] - io() on 192.168.0.21: called.
2020-11-14 15:48:21.048 [TRACE] [x.internal.bridge.slip.io.Connection] - io() on 192.168.0.21: sending packet with 73 bytes: C0 00 45 03 00 08 C4 08 05 00 00 00 7C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FB C0
2020-11-14 15:48:21.049 [TRACE] [nternal.bridge.slip.io.SSLconnection] - send() called, writing 73 bytes.
2020-11-14 15:48:21.052 [TRACE] [nternal.bridge.slip.io.SSLconnection] - send() finished after having send 73 bytes: C0 00 45 03 00 08 C4 08 05 00 00 00 7C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FB C0
2020-11-14 15:48:21.053 [TRACE] [x.internal.bridge.slip.io.Connection] - io() on 192.168.0.21: receiving bytes.
2020-11-14 15:48:21.055 [TRACE] [nternal.bridge.slip.io.SSLconnection] - receive() called.
2020-11-14 15:48:21.106 [TRACE] [e.slip.io.DataInputStreamWithTimeout] - readSlipMessage() => return slip message
2020-11-14 15:48:21.107 [TRACE] [nternal.bridge.slip.io.SSLconnection] - receive() finished after having read 10 bytes: C0 00 06 03 01 08 C4 01 C9 C0
2020-11-14 15:48:21.109 [TRACE] [x.internal.bridge.slip.io.Connection] - io() on 192.168.0.21: received packet with 10 bytes: C0 00 06 03 01 08 C4 01 C9 C0
2020-11-14 15:48:21.110 [TRACE] [x.internal.bridge.slip.io.Connection] - io() on 192.168.0.21: finished.
2020-11-14 15:48:21.112 [TRACE] [ternal.bridge.slip.utils.SlipRFC1055] - decode() for packet size 10 called.
2020-11-14 15:48:21.113 [TRACE] [ternal.bridge.slip.utils.SlipRFC1055] - decode() provides payload: 00 06 03 01 08 C4 01 C9.
2020-11-14 15:48:21.115 [TRACE] [ernal.bridge.slip.utils.SlipEncoding] - SlipEncoding(constructor) called for decoding a packet with size 8.
2020-11-14 15:48:21.117 [TRACE] [ernal.bridge.slip.utils.SlipEncoding] - getCommand() returns 0x301 .
2020-11-14 15:48:21.119 [TRACE] [ernal.bridge.slip.utils.SlipEncoding] - getData() returns 3 bytes: 08 C4 01.
2020-11-14 15:48:21.120 [TRACE] [ernal.bridge.slip.utils.SlipEncoding] - SlipEncoding(constructor) successfully initialized with command 0x301 and data 08 C4 01.
2020-11-14 15:48:21.122 [TRACE] [ernal.bridge.slip.utils.SlipEncoding] - getCommand() returns 0x301 .
2020-11-14 15:48:21.123 [TRACE] [ernal.bridge.slip.utils.SlipEncoding] - getData() returns 3 bytes: 08 C4 01.
2020-11-14 15:48:21.125 [TRACE] [internal.bridge.slip.SlipVeluxBridge] - bridgeDirectCommunicate() [192.168.0.21] GW_COMMAND_SEND_REQ => GW_COMMAND_SEND_CFM => received data => 08 C4 01
2020-11-14 15:48:21.126 [TRACE] [internal.bridge.slip.SlipVeluxBridge] - bridgeDirectCommunicate() [192.168.0.21] GW_COMMAND_SEND_REQ => GW_COMMAND_SEND_CFM => applying data length => 3
2020-11-14 15:48:21.127 [DEBUG] [rnal.bridge.slip.SCrunProductCommand] - setResponse(GW_COMMAND_SEND_CFM with 3 bytes of data) called.
2020-11-14 15:48:21.129 [TRACE] [rnal.bridge.slip.SCrunProductCommand] - setResponse(): handling response GW_COMMAND_SEND_CFM (0x301).
2020-11-14 15:48:21.130 [TRACE] [rnal.bridge.slip.SCrunProductCommand] - isLengthValid() called for GW_COMMAND_SEND_CFM (0x301) with 3 bytes of data.
2020-11-14 15:48:21.131 [TRACE] [rnal.bridge.slip.SCrunProductCommand] - isLengthValid() returns true.
2020-11-14 15:48:21.133 [DEBUG] [rnal.bridge.slip.SCrunProductCommand] - setResponse(): returned status: OK - Command is accepted.
2020-11-14 15:48:21.134 [TRACE] [rnal.bridge.slip.SCrunProductCommand] - check4matchingSessionID() called for requestNodeID 2244 and responseNodeID 2244.
2020-11-14 15:48:21.135 [TRACE] [rnal.bridge.slip.SCrunProductCommand] - check4matchingAnyID() called for requestSessionID 2244 and responseSessionID 2244.
2020-11-14 15:48:21.136 [TRACE] [rnal.bridge.slip.SCrunProductCommand] - check4matchingAnyID() returns true.
2020-11-14 15:48:21.138 [TRACE] [rnal.bridge.slip.SCrunProductCommand] - setResponse(): skipping wait for more packets as sequential processing is not enforced.
2020-11-14 15:48:21.139 [TRACE] [rnal.bridge.slip.SCrunProductCommand] - setResponse(): finished=true,success=true.
2020-11-14 15:48:21.140 [DEBUG] [internal.bridge.slip.SlipVeluxBridge] - bridgeDirectCommunicate() [192.168.0.21] GW_COMMAND_SEND_REQ => finished => success
2020-11-14 15:48:21.141 [DEBUG] [.bridge.VeluxBridgeRunProductCommand] - sendCommand() finished successfully.
2020-11-14 15:48:21.142 [TRACE] [rnal.handler.ChannelActuatorPosition] - handleCommand(): The new shutter level will be send through the home monitoring events.
2020-11-14 15:48:21.143 [TRACE] [nternal.things.VeluxExistingProducts] - getNoMembers() returns 18.
2020-11-14 15:48:21.145 [TRACE] [rnal.handler.ChannelActuatorPosition] - handleCommand(): position of actuators are updated.
2020-11-14 15:48:21.146 [TRACE] [internal.handler.utils.ThingProperty] - setValue() connectionAttempt set to Sat Nov 14 15:48:21 CET 2020.
2020-11-14 15:48:21.147 [TRACE] [internal.handler.utils.ThingProperty] - setValue() connectionSuccess set to Sat Nov 14 15:48:21 CET 2020.
2020-11-14 15:48:21.149 [TRACE] [.internal.handler.VeluxBridgeHandler] - handleCommandScheduled(Thread[pool-43-thread-1,5,main]) done.
2020-11-14 15:48:21.150 [TRACE] [.internal.handler.VeluxBridgeHandler] - handleCommand.scheduled(Thread[pool-43-thread-1,5,main]) done.
2020-11-14 15:48:25.427 [DEBUG] [.internal.handler.VeluxBridgeHandler] - refreshOpenHAB() initiated by Thread[OH-thingHandler-2,5,main] starting cycle 93.
2020-11-14 15:48:25.439 [TRACE] [.internal.handler.VeluxBridgeHandler] - refreshOpenHAB(): processing of possible HSM messages.
2020-11-14 15:48:25.441 [TRACE] [.internal.handler.VeluxBridgeHandler] - refreshOpenHAB(): loop through all (child things and bridge) linked channels needing a refresh
2020-11-14 15:48:25.441 [TRACE] [.internal.handler.VeluxBridgeHandler] - refreshOpenHAB.scheduled() initiated by Thread[pool-43-thread-1,5,main] will process HouseStatus.
2020-11-14 15:48:25.443 [TRACE] [nal.bridge.VeluxBridgeGetHouseStatus] - evaluateState() called.
2020-11-14 15:48:25.444 [TRACE] [internal.bridge.slip.SlipVeluxBridge] - bridgeAPI() called.
2020-11-14 15:48:25.446 [TRACE] [ng.velux.internal.bridge.VeluxBridge] - bridgeCommunicate(Retrieve House Status) called.
2020-11-14 15:48:25.446 [TRACE] [elux.internal.handler.BridgeChannels] - getAllLinkedChannelUIDs() returns [velux:window:7680cbd2:Dennis_Velux:limitMaximum, velux:window:7680cbd2:Landing4_Velux:position, velux:window:7680cbd2:Landing3_Velux:position, velux:window:7680cbd2:Landing2_Velux:position, velux:rollershutter:07cf225a:Tim_Blind:position, velux:rollershutter:7680cbd2:Masterbed1_Blind:position, velux:rollershutter:7680cbd2:Dennis_Blind:position, velux:scene:7680cbd2:Close_all_blinds:action, velux:window:7680cbd2:Bathroom_Velux:position, velux:scene:7680cbd2:Open_Masterbed_Blinds:action, velux:window:7680cbd2:Shower_Velux:position, velux:rollershutter:7680cbd2:Nell_Blind:position, velux:window:7680cbd2:Nell_Velux:limitMinimum, velux:window:7680cbd2:Masterbed1_Velux:position, velux:scene:7680cbd2:Open_all_windows:action, velux:scene:7680cbd2:Close_all_windows:action, velux:window:7680cbd2:Dennis_Velux:limitMinimum, velux:window:7680cbd2:Nell_Velux:limitMaximum, velux:rollershutter:7680cbd2:Masterbed3_Blind:position, velux:rollershutter:7680cbd2:Masterbed2_Blind:position, velux:window:7680cbd2:Masterbed3_Velux:position, velux:window:7680cbd2:Dennis_Velux:position, velux:window:7680cbd2:Masterbed2_Velux:position, velux:scene:7680cbd2:Close_Masterbed_Blinds:action, velux:window:7680cbd2:Landing1_Velux:position, velux:window:7680cbd2:Timmy_Velux:position, velux:scene:7680cbd2:Open_all_blinds:action, velux:window:7680cbd2:Nell_Velux:position].
2020-11-14 15:48:25.448 [TRACE] [ng.velux.internal.bridge.VeluxBridge] - isAuthenticated() returns true.
2020-11-14 15:48:25.448 [TRACE] [binding.velux.internal.VeluxItemType] - getByThingAndChannel(velux:window,limitMaximum) returns enum velux:window/limitMaximum.
2020-11-14 15:48:25.450 [TRACE] [binding.velux.internal.VeluxItemType] - isToBeRefreshedNow(): returning false, as refresh cycle has not yet come for this item.
2020-11-14 15:48:25.450 [TRACE] [ng.velux.internal.bridge.VeluxBridge] - bridgeCommunicate(Retrieve House Status,authenticated) called.
2020-11-14 15:48:25.452 [TRACE] [ng.velux.internal.bridge.VeluxBridge] - isAuthenticated() returns true.
2020-11-14 15:48:25.454 [TRACE] [internal.bridge.slip.SlipVeluxBridge] - bridgeDirectCommunicate(BCP: Retrieve House Status, authenticated) called.
2020-11-14 15:48:25.452 [TRACE] [binding.velux.internal.VeluxItemType] - getByThingAndChannel(velux:window,position) returns enum velux:window/position.
2020-11-14 15:48:25.456 [TRACE] [internal.bridge.slip.SlipVeluxBridge] - bridgeDirectCommunicate() 'Retrieve House Status', authenticated
2020-11-14 15:48:25.459 [DEBUG] [nternal.bridge.slip.SCgetHouseStatus] - getRequestCommand() returns GW_OPENHAB_RECEIVEONLY (0xfffffffd).
2020-11-14 15:48:25.461 [DEBUG] [internal.bridge.slip.SlipVeluxBridge] - bridgeDirectCommunicate() [192.168.0.21] GW_OPENHAB_RECEIVEONLY => started => Thread[pool-43-thread-1,5,main]
2020-11-14 15:48:25.463 [TRACE] [internal.bridge.slip.SlipVeluxBridge] - bridgeDirectCommunicate() [192.168.0.21] GW_OPENHAB_RECEIVEONLY => receive-only mode => checking messages
2020-11-14 15:48:25.464 [TRACE] [binding.velux.internal.VeluxItemType] - isToBeRefreshedNow(): returning false, as refresh cycle has not yet come for this item.
2020-11-14 15:48:25.467 [TRACE] [binding.velux.internal.VeluxItemType] - getByThingAndChannel(velux:window,position) returns enum velux:window/position.
2020-11-14 15:48:25.467 [TRACE] [x.internal.bridge.slip.io.Connection] - isAlive() on 192.168.0.21: called.
2020-11-14 15:48:25.469 [TRACE] [x.internal.bridge.slip.io.Connection] - isMessageAvailable() on 192.168.0.21: called.
2020-11-14 15:48:25.469 [TRACE] [binding.velux.internal.VeluxItemType] - isToBeRefreshedNow(): returning false, as refresh cycle has not yet come for this item.
2020-11-14 15:48:25.471 [TRACE] [nternal.bridge.slip.io.SSLconnection] - available() called.
2020-11-14 15:48:25.471 [TRACE] [binding.velux.internal.VeluxItemType] - getByThingAndChannel(velux:window,position) returns enum velux:window/position.
2020-11-14 15:48:25.473 [TRACE] [e.slip.io.DataInputStreamWithTimeout] - available() => slip message count 6
2020-11-14 15:48:25.473 [TRACE] [binding.velux.internal.VeluxItemType] - isToBeRefreshedNow(): returning false, as refresh cycle has not yet come for this item.
2020-11-14 15:48:25.475 [TRACE] [nternal.bridge.slip.io.SSLconnection] - available(): found 6 messages ready to be read (> 0 means true).
2020-11-14 15:48:25.475 [TRACE] [binding.velux.internal.VeluxItemType] - getByThingAndChannel(velux:rollershutter,position) returns enum velux:rollershutter/position.
2020-11-14 15:48:25.477 [TRACE] [x.internal.bridge.slip.io.Connection] - isMessageAvailable() on 192.168.0.21: there are messages waiting.
2020-11-14 15:48:25.477 [TRACE] [binding.velux.internal.VeluxItemType] - isToBeRefreshedNow(): returning false, as refresh cycle has not yet come for this item.
2020-11-14 15:48:25.479 [TRACE] [internal.bridge.slip.SlipVeluxBridge] - bridgeDirectCommunicate() [192.168.0.21] GW_OPENHAB_RECEIVEONLY => message(s) waiting => start reading
2020-11-14 15:48:25.479 [TRACE] [binding.velux.internal.VeluxItemType] - getByThingAndChannel(velux:rollershutter,position) returns enum velux:rollershutter/position.
2020-11-14 15:48:25.481 [TRACE] [x.internal.bridge.slip.io.Connection] - io() on 192.168.0.21: called.
2020-11-14 15:48:25.481 [TRACE] [binding.velux.internal.VeluxItemType] - isToBeRefreshedNow(): returning false, as refresh cycle has not yet come for this item.
2020-11-14 15:48:25.482 [TRACE] [x.internal.bridge.slip.io.Connection] - io() on 192.168.0.21: receiving bytes.
2020-11-14 15:48:25.483 [TRACE] [binding.velux.internal.VeluxItemType] - getByThingAndChannel(velux:rollershutter,position) returns enum velux:rollershutter/position.
2020-11-14 15:48:25.485 [TRACE] [binding.velux.internal.VeluxItemType] - isToBeRefreshedNow(): returning false, as refresh cycle has not yet come for this item.
2020-11-14 15:48:25.487 [TRACE] [binding.velux.internal.VeluxItemType] - getByThingAndChannel(velux:scene,action) returns enum velux:scene/action.
2020-11-14 15:48:25.485 [TRACE] [nternal.bridge.slip.io.SSLconnection] - receive() called.
2020-11-14 15:48:25.489 [TRACE] [binding.velux.internal.VeluxItemType] - isToBeRefreshedNow(): returning false, as item is not refreshable.
2020-11-14 15:48:25.490 [TRACE] [e.slip.io.DataInputStreamWithTimeout] - readSlipMessage() => return slip message
2020-11-14 15:48:25.494 [TRACE] [nternal.bridge.slip.io.SSLconnection] - receive() finished after having read 27 bytes: C0 00 17 02 11 01 02 C8 00 7C 00 F7 FF F7 FF F7 FF F7 FF 00 00 9B 6F 00 00 47 C0
2020-11-14 15:48:25.494 [TRACE] [binding.velux.internal.VeluxItemType] - getByThingAndChannel(velux:window,position) returns enum velux:window/position.
2020-11-14 15:48:25.499 [TRACE] [binding.velux.internal.VeluxItemType] - isToBeRefreshedNow(): returning false, as refresh cycle has not yet come for this item.
2020-11-14 15:48:25.498 [TRACE] [x.internal.bridge.slip.io.Connection] - io() on 192.168.0.21: received packet with 27 bytes: C0 00 17 02 11 01 02 C8 00 7C 00 F7 FF F7 FF F7 FF F7 FF 00 00 9B 6F 00 00 47 C0
2020-11-14 15:48:25.501 [TRACE] [x.internal.bridge.slip.io.Connection] - io() on 192.168.0.21: finished.
2020-11-14 15:48:25.501 [TRACE] [binding.velux.internal.VeluxItemType] - getByThingAndChannel(velux:scene,action) returns enum velux:scene/action.
2020-11-14 15:48:25.503 [TRACE] [binding.velux.internal.VeluxItemType] - isToBeRefreshedNow(): returning false, as item is not refreshable.
2020-11-14 15:48:25.503 [TRACE] [ternal.bridge.slip.utils.SlipRFC1055] - decode() for packet size 27 called.
2020-11-14 15:48:25.505 [TRACE] [binding.velux.internal.VeluxItemType] - getByThingAndChannel(velux:window,position) returns enum velux:window/position.
2020-11-14 15:48:25.507 [TRACE] [binding.velux.internal.VeluxItemType] - isToBeRefreshedNow(): returning false, as refresh cycle has not yet come for this item.
2020-11-14 15:48:25.507 [TRACE] [ternal.bridge.slip.utils.SlipRFC1055] - decode() provides payload: 00 17 02 11 01 02 C8 00 7C 00 F7 FF F7 FF F7 FF F7 FF 00 00 9B 6F 00 00 47.
2020-11-14 15:48:25.509 [TRACE] [binding.velux.internal.VeluxItemType] - getByThingAndChannel(velux:rollershutter,position) returns enum velux:rollershutter/position.
2020-11-14 15:48:25.509 [TRACE] [ernal.bridge.slip.utils.SlipEncoding] - SlipEncoding(constructor) called for decoding a packet with size 25.
2020-11-14 15:48:25.511 [TRACE] [binding.velux.internal.VeluxItemType] - isToBeRefreshedNow(): returning false, as refresh cycle has not yet come for this item.
2020-11-14 15:48:25.512 [TRACE] [ernal.bridge.slip.utils.SlipEncoding] - getCommand() returns 0x211 .
2020-11-14 15:48:25.514 [TRACE] [binding.velux.internal.VeluxItemType] - getByThingAndChannel(velux:window,limitMinimum) returns enum velux:window/limitMinimum.
2020-11-14 15:48:25.515 [TRACE] [ernal.bridge.slip.utils.SlipEncoding] - getData() returns 20 bytes: 01 02 C8 00 7C 00 F7 FF F7 FF F7 FF F7 FF 00 00 9B 6F 00 00.
2020-11-14 15:48:25.516 [TRACE] [binding.velux.internal.VeluxItemType] - isToBeRefreshedNow(): returning false, as refresh cycle has not yet come for this item.
2020-11-14 15:48:25.518 [TRACE] [binding.velux.internal.VeluxItemType] - getByThingAndChannel(velux:window,position) returns enum velux:window/position.
2020-11-14 15:48:25.518 [TRACE] [ernal.bridge.slip.utils.SlipEncoding] - SlipEncoding(constructor) successfully initialized with command 0x211 and data 01 02 C8 00 7C 00 F7 FF F7 FF F7 FF F7 FF 00 00 9B 6F 00 00.
2020-11-14 15:48:25.520 [TRACE] [binding.velux.internal.VeluxItemType] - isToBeRefreshedNow(): returning false, as refresh cycle has not yet come for this item.
2020-11-14 15:48:25.521 [TRACE] [ernal.bridge.slip.utils.SlipEncoding] - getCommand() returns 0x211 .
2020-11-14 15:48:25.523 [TRACE] [binding.velux.internal.VeluxItemType] - getByThingAndChannel(velux:scene,action) returns enum velux:scene/action.
2020-11-14 15:48:25.524 [TRACE] [ernal.bridge.slip.utils.SlipEncoding] - getData() returns 20 bytes: 01 02 C8 00 7C 00 F7 FF F7 FF F7 FF F7 FF 00 00 9B 6F 00 00.
2020-11-14 15:48:25.525 [TRACE] [binding.velux.internal.VeluxItemType] - isToBeRefreshedNow(): returning false, as item is not refreshable.
2020-11-14 15:48:25.527 [TRACE] [binding.velux.internal.VeluxItemType] - getByThingAndChannel(velux:scene,action) returns enum velux:scene/action.
2020-11-14 15:48:25.529 [TRACE] [binding.velux.internal.VeluxItemType] - isToBeRefreshedNow(): returning false, as item is not refreshable.
2020-11-14 15:48:25.529 [TRACE] [internal.bridge.slip.SlipVeluxBridge] - bridgeDirectCommunicate() [192.168.0.21] GW_OPENHAB_RECEIVEONLY => GW_NODE_STATE_POSITION_CHANGED_NTF => received data => 01 02 C8 00 7C 00 F7 FF F7 FF F7 FF F7 FF 00 00 9B 6F 00 00
2020-11-14 15:48:25.531 [TRACE] [binding.velux.internal.VeluxItemType] - getByThingAndChannel(velux:window,limitMinimum) returns enum velux:window/limitMinimum.
2020-11-14 15:48:25.531 [TRACE] [internal.bridge.slip.SlipVeluxBridge] - bridgeDirectCommunicate() [192.168.0.21] GW_OPENHAB_RECEIVEONLY => GW_NODE_STATE_POSITION_CHANGED_NTF => special command => starting
2020-11-14 15:48:25.533 [TRACE] [binding.velux.internal.VeluxItemType] - isToBeRefreshedNow(): returning false, as refresh cycle has not yet come for this item.
2020-11-14 15:48:25.534 [DEBUG] [nternal.bridge.slip.SCgetHouseStatus] - setResponse(GW_NODE_STATE_POSITION_CHANGED_NTF with 20 bytes of data) called.
2020-11-14 15:48:25.535 [TRACE] [binding.velux.internal.VeluxItemType] - getByThingAndChannel(velux:window,limitMaximum) returns enum velux:window/limitMaximum.
2020-11-14 15:48:25.537 [TRACE] [binding.velux.internal.VeluxItemType] - isToBeRefreshedNow(): returning false, as refresh cycle has not yet come for this item.
2020-11-14 15:48:25.537 [TRACE] [nternal.bridge.slip.SCgetHouseStatus] - setResponse(): handling response GW_NODE_STATE_POSITION_CHANGED_NTF (0x211).
2020-11-14 15:48:25.539 [TRACE] [binding.velux.internal.VeluxItemType] - getByThingAndChannel(velux:rollershutter,position) returns enum velux:rollershutter/position.
2020-11-14 15:48:25.541 [TRACE] [binding.velux.internal.VeluxItemType] - isToBeRefreshedNow(): returning false, as refresh cycle has not yet come for this item.
2020-11-14 15:48:25.540 [TRACE] [nternal.bridge.slip.SCgetHouseStatus] - isLengthValid() called for GW_NODE_STATE_POSITION_CHANGED_NTF (0x211) with 20 bytes of data.
2020-11-14 15:48:25.544 [TRACE] [binding.velux.internal.VeluxItemType] - getByThingAndChannel(velux:rollershutter,position) returns enum velux:rollershutter/position.
2020-11-14 15:48:25.544 [TRACE] [nternal.bridge.slip.SCgetHouseStatus] - isLengthValid() returns true.
2020-11-14 15:48:25.546 [TRACE] [binding.velux.internal.VeluxItemType] - isToBeRefreshedNow(): returning false, as refresh cycle has not yet come for this item.
2020-11-14 15:48:25.548 [TRACE] [binding.velux.internal.VeluxItemType] - getByThingAndChannel(velux:window,position) returns enum velux:window/position.
2020-11-14 15:48:25.548 [TRACE] [nternal.bridge.slip.SCgetHouseStatus] - setResponse(): ntfNodeID=1.
2020-11-14 15:48:25.550 [TRACE] [binding.velux.internal.VeluxItemType] - isToBeRefreshedNow(): returning false, as refresh cycle has not yet come for this item.
2020-11-14 15:48:25.550 [TRACE] [nternal.bridge.slip.SCgetHouseStatus] - setResponse(): ntfState=2.
2020-11-14 15:48:25.552 [TRACE] [binding.velux.internal.VeluxItemType] - getByThingAndChannel(velux:window,position) returns enum velux:window/position.
2020-11-14 15:48:25.554 [TRACE] [binding.velux.internal.VeluxItemType] - isToBeRefreshedNow(): returning false, as refresh cycle has not yet come for this item.
2020-11-14 15:48:25.554 [TRACE] [nternal.bridge.slip.SCgetHouseStatus] - setResponse(): ntfCurrentPosition=51200.
2020-11-14 15:48:25.556 [TRACE] [binding.velux.internal.VeluxItemType] - getByThingAndChannel(velux:window,position) returns enum velux:window/position.
2020-11-14 15:48:25.557 [TRACE] [nternal.bridge.slip.SCgetHouseStatus] - setResponse(): ntfTarget=31744.
2020-11-14 15:48:25.558 [TRACE] [binding.velux.internal.VeluxItemType] - isToBeRefreshedNow(): returning false, as refresh cycle has not yet come for this item.
2020-11-14 15:48:25.560 [TRACE] [nternal.bridge.slip.SCgetHouseStatus] - setResponse(): ntfRemainingTime=0.
2020-11-14 15:48:25.561 [TRACE] [binding.velux.internal.VeluxItemType] - getByThingAndChannel(velux:scene,action) returns enum velux:scene/action.
2020-11-14 15:48:25.562 [TRACE] [binding.velux.internal.VeluxItemType] - isToBeRefreshedNow(): returning false, as item is not refreshable.
2020-11-14 15:48:25.562 [TRACE] [nternal.bridge.slip.SCgetHouseStatus] - setResponse(): ntfTimeStamp=-1687224320.
2020-11-14 15:48:25.565 [TRACE] [binding.velux.internal.VeluxItemType] - getByThingAndChannel(velux:window,position) returns enum velux:window/position.
2020-11-14 15:48:25.565 [TRACE] [nternal.bridge.slip.SCgetHouseStatus] - setResponse(): finished=true,success=true.
2020-11-14 15:48:25.566 [TRACE] [binding.velux.internal.VeluxItemType] - isToBeRefreshedNow(): returning false, as refresh cycle has not yet come for this item.
2020-11-14 15:48:25.567 [DEBUG] [nternal.things.VeluxExistingProducts] - update(bridgeProductIndex=1,productState=2,productPosition=51200,productTarget=31744) called.
2020-11-14 15:48:25.569 [TRACE] [binding.velux.internal.VeluxItemType] - getByThingAndChannel(velux:window,position) returns enum velux:window/position.
2020-11-14 15:48:25.570 [TRACE] [nternal.things.VeluxExistingProducts] - isRegisteredProductBridgeIndex 1) called.
2020-11-14 15:48:25.572 [TRACE] [binding.velux.internal.VeluxItemType] - isToBeRefreshedNow(): returning false, as refresh cycle has not yet come for this item.
2020-11-14 15:48:25.573 [TRACE] [nternal.things.VeluxExistingProducts] - isRegistered(String 56:18:5E:5A:0A:29:08:09) returns true.
2020-11-14 15:48:25.574 [TRACE] [binding.velux.internal.VeluxItemType] - getByThingAndChannel(velux:scene,action) returns enum velux:scene/action.
2020-11-14 15:48:25.576 [TRACE] [binding.velux.internal.VeluxItemType] - isToBeRefreshedNow(): returning false, as item is not refreshable.
2020-11-14 15:48:25.576 [TRACE] [nternal.things.VeluxExistingProducts] - get(1) called.
2020-11-14 15:48:25.578 [TRACE] [nternal.things.VeluxExistingProducts] - isRegisteredProductBridgeIndex 1) called.
2020-11-14 15:48:25.581 [TRACE] [binding.velux.internal.VeluxItemType] - getByThingAndChannel(velux:window,position) returns enum velux:window/position.
2020-11-14 15:48:25.581 [TRACE] [nternal.things.VeluxExistingProducts] - isRegistered(String 56:18:5E:5A:0A:29:08:09) returns true.
2020-11-14 15:48:25.584 [TRACE] [g.velux.internal.things.VeluxProduct] - setState(name=Dennis_Velux,index=1) state 5 replaced by 2.
2020-11-14 15:48:25.584 [TRACE] [binding.velux.internal.VeluxItemType] - isToBeRefreshedNow(): returning false, as refresh cycle has not yet come for this item.
2020-11-14 15:48:25.586 [TRACE] [g.velux.internal.things.VeluxProduct] - setCurrentPosition(name=Dennis_Velux,index=1) target 51200 replaced by 31744.
2020-11-14 15:48:25.587 [TRACE] [.internal.handler.VeluxBridgeHandler] - refreshOpenHAB(): loop through properties needing a refresh
2020-11-14 15:48:25.587 [TRACE] [nternal.things.VeluxExistingProducts] - update(): updating by UniqueIndex 56:18:5E:5A:0A:29:08:09.
2020-11-14 15:48:25.589 [TRACE] [nternal.things.VeluxExistingProducts] - update() successfully finished (dirty=true).
2020-11-14 15:48:25.590 [TRACE] [binding.velux.internal.VeluxItemType] - getPropertyEntriesByThing(velux:klf200) returns [velux:klf200/firmware, velux:klf200/ipAddress, velux:klf200/subnetMask, velux:klf200/defaultGW, velux:klf200/DHCP, velux:klf200/WLANSSID, velux:klf200/WLANPassword, velux:klf200/products, velux:klf200/scenes, velux:klf200/check].
2020-11-14 15:48:25.591 [TRACE] [internal.bridge.slip.SlipVeluxBridge] - bridgeDirectCommunicate() [192.168.0.21] GW_OPENHAB_RECEIVEONLY => GW_NODE_STATE_POSITION_CHANGED_NTF => special command => product updated
2020-11-14 15:48:25.592 [TRACE] [internal.bridge.slip.SlipVeluxBridge] - bridgeDirectCommunicate() [192.168.0.21] GW_OPENHAB_RECEIVEONLY => GW_NODE_STATE_POSITION_CHANGED_NTF => special command => continuing
2020-11-14 15:48:25.593 [TRACE] [binding.velux.internal.VeluxItemType] - getByThingAndChannel(velux:klf200,firmware) returns enum velux:klf200/firmware.
2020-11-14 15:48:25.594 [TRACE] [binding.velux.internal.VeluxItemType] - isToBeRefreshedNow(): returning false, as refresh cycle has not yet come for this item.
2020-11-14 15:48:25.594 [TRACE] [x.internal.bridge.slip.io.Connection] - io() on 192.168.0.21: called.
2020-11-14 15:48:25.595 [TRACE] [binding.velux.internal.VeluxItemType] - getByThingAndChannel(velux:klf200,ipAddress) returns enum velux:klf200/ipAddress.
2020-11-14 15:48:25.595 [TRACE] [x.internal.bridge.slip.io.Connection] - io() on 192.168.0.21: receiving bytes.
2020-11-14 15:48:25.596 [TRACE] [binding.velux.internal.VeluxItemType] - isToBeRefreshedNow(): returning false, as refresh cycle has not yet come for this item.
2020-11-14 15:48:25.596 [TRACE] [nternal.bridge.slip.io.SSLconnection] - receive() called.
2020-11-14 15:48:25.597 [TRACE] [binding.velux.internal.VeluxItemType] - getByThingAndChannel(velux:klf200,subnetMask) returns enum velux:klf200/subnetMask.
2020-11-14 15:48:25.597 [TRACE] [e.slip.io.DataInputStreamWithTimeout] - readSlipMessage() => return slip message
2020-11-14 15:48:25.598 [TRACE] [binding.velux.internal.VeluxItemType] - isToBeRefreshedNow(): returning false, as refresh cycle has not yet come for this item.
2020-11-14 15:48:25.599 [TRACE] [nternal.bridge.slip.io.SSLconnection] - receive() finished after having read 20 bytes: C0 00 10 03 02 08 C4 08 01 00 C8 00 02 03 06 02 00 80 99 C0
2020-11-14 15:48:25.601 [TRACE] [x.internal.bridge.slip.io.Connection] - io() on 192.168.0.21: received packet with 20 bytes: C0 00 10 03 02 08 C4 08 01 00 C8 00 02 03 06 02 00 80 99 C0
2020-11-14 15:48:25.602 [TRACE] [binding.velux.internal.VeluxItemType] - getByThingAndChannel(velux:klf200,defaultGW) returns enum velux:klf200/defaultGW.
2020-11-14 15:48:25.603 [TRACE] [x.internal.bridge.slip.io.Connection] - io() on 192.168.0.21: finished.
2020-11-14 15:48:25.603 [TRACE] [binding.velux.internal.VeluxItemType] - isToBeRefreshedNow(): returning false, as refresh cycle has not yet come for this item.
2020-11-14 15:48:25.604 [TRACE] [binding.velux.internal.VeluxItemType] - getByThingAndChannel(velux:klf200,DHCP) returns enum velux:klf200/DHCP.
2020-11-14 15:48:25.604 [TRACE] [ternal.bridge.slip.utils.SlipRFC1055] - decode() for packet size 20 called.
2020-11-14 15:48:25.605 [TRACE] [binding.velux.internal.VeluxItemType] - isToBeRefreshedNow(): returning false, as refresh cycle has not yet come for this item.
2020-11-14 15:48:25.606 [TRACE] [ternal.bridge.slip.utils.SlipRFC1055] - decode() provides payload: 00 10 03 02 08 C4 08 01 00 C8 00 02 03 06 02 00 80 99.
2020-11-14 15:48:25.607 [TRACE] [binding.velux.internal.VeluxItemType] - getByThingAndChannel(velux:klf200,WLANSSID) returns enum velux:klf200/WLANSSID.
2020-11-14 15:48:25.608 [TRACE] [binding.velux.internal.VeluxItemType] - isToBeRefreshedNow(): returning false, as refresh cycle has not yet come for this item.
2020-11-14 15:48:25.608 [TRACE] [ernal.bridge.slip.utils.SlipEncoding] - SlipEncoding(constructor) called for decoding a packet with size 18.
2020-11-14 15:48:25.609 [TRACE] [binding.velux.internal.VeluxItemType] - getByThingAndChannel(velux:klf200,WLANPassword) returns enum velux:klf200/WLANPassword.
2020-11-14 15:48:25.609 [TRACE] [ernal.bridge.slip.utils.SlipEncoding] - getCommand() returns 0x302 .
2020-11-14 15:48:25.611 [TRACE] [binding.velux.internal.VeluxItemType] - isToBeRefreshedNow(): returning false, as refresh cycle has not yet come for this item.
2020-11-14 15:48:25.611 [TRACE] [ernal.bridge.slip.utils.SlipEncoding] - getData() returns 13 bytes: 08 C4 08 01 00 C8 00 02 03 06 02 00 80.
2020-11-14 15:48:25.612 [TRACE] [binding.velux.internal.VeluxItemType] - getByThingAndChannel(velux:klf200,products) returns enum velux:klf200/products.
2020-11-14 15:48:25.614 [TRACE] [binding.velux.internal.VeluxItemType] - isToBeRefreshedNow(): returning false, as refresh cycle has not yet come for this item.
2020-11-14 15:48:25.614 [TRACE] [ernal.bridge.slip.utils.SlipEncoding] - SlipEncoding(constructor) successfully initialized with command 0x302 and data 08 C4 08 01 00 C8 00 02 03 06 02 00 80.
2020-11-14 15:48:25.615 [TRACE] [ernal.bridge.slip.utils.SlipEncoding] - getCommand() returns 0x302 .
2020-11-14 15:48:25.615 [TRACE] [binding.velux.internal.VeluxItemType] - getByThingAndChannel(velux:klf200,scenes) returns enum velux:klf200/scenes.
2020-11-14 15:48:25.616 [TRACE] [binding.velux.internal.VeluxItemType] - isToBeRefreshedNow(): returning false, as refresh cycle has not yet come for this item.
2020-11-14 15:48:25.617 [TRACE] [ernal.bridge.slip.utils.SlipEncoding] - getData() returns 13 bytes: 08 C4 08 01 00 C8 00 02 03 06 02 00 80.
2020-11-14 15:48:25.618 [TRACE] [binding.velux.internal.VeluxItemType] - getByThingAndChannel(velux:klf200,check) returns enum velux:klf200/check.
2020-11-14 15:48:25.619 [TRACE] [binding.velux.internal.VeluxItemType] - isToBeRefreshedNow(): returning false, as refresh cycle has not yet come for this item.
2020-11-14 15:48:25.619 [TRACE] [internal.bridge.slip.SlipVeluxBridge] - bridgeDirectCommunicate() [192.168.0.21] GW_OPENHAB_RECEIVEONLY => GW_COMMAND_RUN_STATUS_NTF => received data => 08 C4 08 01 00 C8 00 02 03 06 02 00 80
2020-11-14 15:48:25.620 [DEBUG] [.internal.handler.VeluxBridgeHandler] - refreshOpenHAB() initiated by Thread[OH-thingHandler-2,5,main] finished cycle 93.
2020-11-14 15:48:25.620 [TRACE] [internal.bridge.slip.SlipVeluxBridge] - bridgeDirectCommunicate() [192.168.0.21] GW_OPENHAB_RECEIVEONLY => GW_COMMAND_RUN_STATUS_NTF => parallelism allowed => continuing
2020-11-14 15:48:25.622 [TRACE] [x.internal.bridge.slip.io.Connection] - io() on 192.168.0.21: called.
2020-11-14 15:48:25.623 [TRACE] [x.internal.bridge.slip.io.Connection] - io() on 192.168.0.21: receiving bytes.
2020-11-14 15:48:25.624 [TRACE] [nternal.bridge.slip.io.SSLconnection] - receive() called.
2020-11-14 15:48:25.626 [TRACE] [e.slip.io.DataInputStreamWithTimeout] - readSlipMessage() => return slip message
2020-11-14 15:48:25.628 [TRACE] [nternal.bridge.slip.io.SSLconnection] - receive() finished after having read 20 bytes: C0 00 10 03 02 08 C4 08 01 00 C8 00 01 03 0F 02 00 80 93 C0
2020-11-14 15:48:25.629 [TRACE] [x.internal.bridge.slip.io.Connection] - io() on 192.168.0.21: received packet with 20 bytes: C0 00 10 03 02 08 C4 08 01 00 C8 00 01 03 0F 02 00 80 93 C0
2020-11-14 15:48:25.630 [TRACE] [x.internal.bridge.slip.io.Connection] - io() on 192.168.0.21: finished.
2020-11-14 15:48:25.632 [TRACE] [ternal.bridge.slip.utils.SlipRFC1055] - decode() for packet size 20 called.
2020-11-14 15:48:25.633 [TRACE] [ternal.bridge.slip.utils.SlipRFC1055] - decode() provides payload: 00 10 03 02 08 C4 08 01 00 C8 00 01 03 0F 02 00 80 93.
2020-11-14 15:48:25.635 [TRACE] [ernal.bridge.slip.utils.SlipEncoding] - SlipEncoding(constructor) called for decoding a packet with size 18.
2020-11-14 15:48:25.636 [TRACE] [ernal.bridge.slip.utils.SlipEncoding] - getCommand() returns 0x302 .
2020-11-14 15:48:25.638 [TRACE] [ernal.bridge.slip.utils.SlipEncoding] - getData() returns 13 bytes: 08 C4 08 01 00 C8 00 01 03 0F 02 00 80.
2020-11-14 15:48:25.639 [TRACE] [ernal.bridge.slip.utils.SlipEncoding] - SlipEncoding(constructor) successfully initialized with command 0x302 and data 08 C4 08 01 00 C8 00 01 03 0F 02 00 80.
2020-11-14 15:48:25.641 [TRACE] [ernal.bridge.slip.utils.SlipEncoding] - getCommand() returns 0x302 .
2020-11-14 15:48:25.643 [TRACE] [ernal.bridge.slip.utils.SlipEncoding] - getData() returns 13 bytes: 08 C4 08 01 00 C8 00 01 03 0F 02 00 80.
2020-11-14 15:48:25.644 [TRACE] [internal.bridge.slip.SlipVeluxBridge] - bridgeDirectCommunicate() [192.168.0.21] GW_OPENHAB_RECEIVEONLY => GW_COMMAND_RUN_STATUS_NTF => received data => 08 C4 08 01 00 C8 00 01 03 0F 02 00 80
2020-11-14 15:48:25.646 [TRACE] [internal.bridge.slip.SlipVeluxBridge] - bridgeDirectCommunicate() [192.168.0.21] GW_OPENHAB_RECEIVEONLY => GW_COMMAND_RUN_STATUS_NTF => parallelism allowed => continuing
2020-11-14 15:48:25.647 [TRACE] [x.internal.bridge.slip.io.Connection] - io() on 192.168.0.21: called.
2020-11-14 15:48:25.648 [TRACE] [x.internal.bridge.slip.io.Connection] - io() on 192.168.0.21: receiving bytes.
2020-11-14 15:48:25.649 [TRACE] [nternal.bridge.slip.io.SSLconnection] - receive() called.
2020-11-14 15:48:25.651 [TRACE] [e.slip.io.DataInputStreamWithTimeout] - readSlipMessage() => return slip message
2020-11-14 15:48:25.652 [TRACE] [nternal.bridge.slip.io.SSLconnection] - receive() finished after having read 9 bytes: C0 00 05 03 04 08 C4 CE C0
2020-11-14 15:48:25.654 [TRACE] [x.internal.bridge.slip.io.Connection] - io() on 192.168.0.21: received packet with 9 bytes: C0 00 05 03 04 08 C4 CE C0
2020-11-14 15:48:25.655 [TRACE] [x.internal.bridge.slip.io.Connection] - io() on 192.168.0.21: finished.
2020-11-14 15:48:25.657 [TRACE] [ternal.bridge.slip.utils.SlipRFC1055] - decode() for packet size 9 called.
2020-11-14 15:48:25.658 [TRACE] [ternal.bridge.slip.utils.SlipRFC1055] - decode() provides payload: 00 05 03 04 08 C4 CE.
2020-11-14 15:48:25.659 [TRACE] [ernal.bridge.slip.utils.SlipEncoding] - SlipEncoding(constructor) called for decoding a packet with size 7.
2020-11-14 15:48:25.661 [TRACE] [ernal.bridge.slip.utils.SlipEncoding] - getCommand() returns 0x304 .
2020-11-14 15:48:25.663 [TRACE] [ernal.bridge.slip.utils.SlipEncoding] - getData() returns 2 bytes: 08 C4.
2020-11-14 15:48:25.664 [TRACE] [ernal.bridge.slip.utils.SlipEncoding] - SlipEncoding(constructor) successfully initialized with command 0x304 and data 08 C4.
2020-11-14 15:48:25.665 [TRACE] [ernal.bridge.slip.utils.SlipEncoding] - getCommand() returns 0x304 .
2020-11-14 15:48:25.667 [TRACE] [ernal.bridge.slip.utils.SlipEncoding] - getData() returns 2 bytes: 08 C4.
2020-11-14 15:48:25.668 [TRACE] [internal.bridge.slip.SlipVeluxBridge] - bridgeDirectCommunicate() [192.168.0.21] GW_OPENHAB_RECEIVEONLY => GW_SESSION_FINISHED_NTF => received data => 08 C4
2020-11-14 15:48:25.669 [TRACE] [internal.bridge.slip.SlipVeluxBridge] - bridgeDirectCommunicate() [192.168.0.21] GW_OPENHAB_RECEIVEONLY => GW_SESSION_FINISHED_NTF => parallelism allowed => continuing
2020-11-14 15:48:25.671 [TRACE] [x.internal.bridge.slip.io.Connection] - io() on 192.168.0.21: called.
2020-11-14 15:48:25.672 [TRACE] [x.internal.bridge.slip.io.Connection] - io() on 192.168.0.21: receiving bytes.
2020-11-14 15:48:25.673 [TRACE] [nternal.bridge.slip.io.SSLconnection] - receive() called.
2020-11-14 15:48:25.675 [TRACE] [e.slip.io.DataInputStreamWithTimeout] - readSlipMessage() => return slip message
2020-11-14 15:48:25.677 [TRACE] [nternal.bridge.slip.io.SSLconnection] - receive() finished after having read 27 bytes: C0 00 17 02 11 01 80 C8 00 7C 00 F7 FF F7 FF F7 FF F7 FF 00 00 9B 6F 00 00 C5 C0
2020-11-14 15:48:25.678 [TRACE] [x.internal.bridge.slip.io.Connection] - io() on 192.168.0.21: received packet with 27 bytes: C0 00 17 02 11 01 80 C8 00 7C 00 F7 FF F7 FF F7 FF F7 FF 00 00 9B 6F 00 00 C5 C0
2020-11-14 15:48:25.679 [TRACE] [x.internal.bridge.slip.io.Connection] - io() on 192.168.0.21: finished.
2020-11-14 15:48:25.681 [TRACE] [ternal.bridge.slip.utils.SlipRFC1055] - decode() for packet size 27 called.
2020-11-14 15:48:25.683 [TRACE] [ternal.bridge.slip.utils.SlipRFC1055] - decode() provides payload: 00 17 02 11 01 80 C8 00 7C 00 F7 FF F7 FF F7 FF F7 FF 00 00 9B 6F 00 00 C5.
2020-11-14 15:48:25.684 [TRACE] [ernal.bridge.slip.utils.SlipEncoding] - SlipEncoding(constructor) called for decoding a packet with size 25.
2020-11-14 15:48:25.685 [TRACE] [ernal.bridge.slip.utils.SlipEncoding] - getCommand() returns 0x211 .
2020-11-14 15:48:25.687 [TRACE] [ernal.bridge.slip.utils.SlipEncoding] - getData() returns 20 bytes: 01 80 C8 00 7C 00 F7 FF F7 FF F7 FF F7 FF 00 00 9B 6F 00 00.
2020-11-14 15:48:25.689 [TRACE] [ernal.bridge.slip.utils.SlipEncoding] - SlipEncoding(constructor) successfully initialized with command 0x211 and data 01 80 C8 00 7C 00 F7 FF F7 FF F7 FF F7 FF 00 00 9B 6F 00 00.
2020-11-14 15:48:25.690 [TRACE] [ernal.bridge.slip.utils.SlipEncoding] - getCommand() returns 0x211 .
2020-11-14 15:48:25.692 [TRACE] [ernal.bridge.slip.utils.SlipEncoding] - getData() returns 20 bytes: 01 80 C8 00 7C 00 F7 FF F7 FF F7 FF F7 FF 00 00 9B 6F 00 00.
2020-11-14 15:48:25.693 [TRACE] [internal.bridge.slip.SlipVeluxBridge] - bridgeDirectCommunicate() [192.168.0.21] GW_OPENHAB_RECEIVEONLY => GW_NODE_STATE_POSITION_CHANGED_NTF => received data => 01 80 C8 00 7C 00 F7 FF F7 FF F7 FF F7 FF 00 00 9B 6F 00 00
2020-11-14 15:48:25.695 [TRACE] [internal.bridge.slip.SlipVeluxBridge] - bridgeDirectCommunicate() [192.168.0.21] GW_OPENHAB_RECEIVEONLY => GW_NODE_STATE_POSITION_CHANGED_NTF => special command => starting
2020-11-14 15:48:25.696 [DEBUG] [nternal.bridge.slip.SCgetHouseStatus] - setResponse(GW_NODE_STATE_POSITION_CHANGED_NTF with 20 bytes of data) called.
2020-11-14 15:48:25.697 [TRACE] [nternal.bridge.slip.SCgetHouseStatus] - setResponse(): handling response GW_NODE_STATE_POSITION_CHANGED_NTF (0x211).
2020-11-14 15:48:25.699 [TRACE] [nternal.bridge.slip.SCgetHouseStatus] - isLengthValid() called for GW_NODE_STATE_POSITION_CHANGED_NTF (0x211) with 20 bytes of data.
2020-11-14 15:48:25.700 [TRACE] [nternal.bridge.slip.SCgetHouseStatus] - isLengthValid() returns true.
2020-11-14 15:48:25.701 [TRACE] [nternal.bridge.slip.SCgetHouseStatus] - setResponse(): ntfNodeID=1.
2020-11-14 15:48:25.702 [TRACE] [nternal.bridge.slip.SCgetHouseStatus] - setResponse(): ntfState=128.
2020-11-14 15:48:25.704 [TRACE] [nternal.bridge.slip.SCgetHouseStatus] - setResponse(): ntfCurrentPosition=51200.
2020-11-14 15:48:25.705 [TRACE] [nternal.bridge.slip.SCgetHouseStatus] - setResponse(): ntfTarget=31744.
2020-11-14 15:48:25.706 [TRACE] [nternal.bridge.slip.SCgetHouseStatus] - setResponse(): ntfRemainingTime=0.
2020-11-14 15:48:25.708 [TRACE] [nternal.bridge.slip.SCgetHouseStatus] - setResponse(): ntfTimeStamp=-1687224320.
2020-11-14 15:48:25.709 [TRACE] [nternal.bridge.slip.SCgetHouseStatus] - setResponse(): finished=true,success=true.
2020-11-14 15:48:25.710 [DEBUG] [nternal.things.VeluxExistingProducts] - update(bridgeProductIndex=1,productState=128,productPosition=51200,productTarget=31744) called.
2020-11-14 15:48:25.712 [TRACE] [nternal.things.VeluxExistingProducts] - isRegisteredProductBridgeIndex 1) called.
2020-11-14 15:48:25.713 [TRACE] [nternal.things.VeluxExistingProducts] - isRegistered(String 56:18:5E:5A:0A:29:08:09) returns true.
2020-11-14 15:48:25.714 [TRACE] [nternal.things.VeluxExistingProducts] - get(1) called.
2020-11-14 15:48:25.715 [TRACE] [nternal.things.VeluxExistingProducts] - isRegisteredProductBridgeIndex 1) called.
2020-11-14 15:48:25.717 [TRACE] [nternal.things.VeluxExistingProducts] - isRegistered(String 56:18:5E:5A:0A:29:08:09) returns true.
2020-11-14 15:48:25.718 [TRACE] [g.velux.internal.things.VeluxProduct] - setState(name=Dennis_Velux,index=1) state 2 replaced by 128.
