I have just migrated to OpenHAB version 3. In the openhab.log I see different warnings from the velux addon every time a scene is activated. e.g. :
2021-01-05 10:49:21.457 [WARN ] [al.handler.utils.Thing2VeluxActuator] - mapThing2Velux(): in velux:scene:home:Dachfenster_Storen2_Auf:action cannot find a uniqueIndex, aborting.
2021-01-05 10:49:21.457 [WARN ] [al.handler.utils.Thing2VeluxActuator] - mapThing2Velux(): in velux:scene:home:Dachfenster_Fenster2_Auf:action cannot find a uniqueIndex, aborting.
2021-01-05 10:49:21.458 [WARN ] [al.handler.utils.Thing2VeluxActuator] - mapThing2Velux(): in velux:scene:home:Dachfenster_Fenster2_Zu:action cannot find a uniqueIndex, aborting.
Is there something wrong/missing in my configuration? The configuartion was made manually created via config files as followed. KLF is running the latest firmware.
Switch Dachfenster_Storen1_Auf_Szenenstart âDachfenster Gang Storen öffnenâ { channel=âvelux:scene:home:Dachfenster_Storen1_Auf:actionâ }
Switch Dachfenster_Storen1_Zu_Szenenstart âDachfenster Gang Storen schliessenâ { channel=âvelux:scene:home:Dachfenster_Storen1_Zu:actionâ }
Switch Dachfenster_Storen1_Licht_Szenenstart âDachfenster Gang Storen Lichtâ { channel=âvelux:scene:home:Dachfenster_Storen1_Licht:actionâ }
Switch Dachfenster_Storen2_Auf_Szenenstart âDachfenster Bad Storen öffnenâ { channel=âvelux:scene:home:Dachfenster_Storen2_Auf:actionâ }
Switch Dachfenster_Storen2_Zu_Szenenstart âDachfenster Bad Storen schliessenâ { channel=âvelux:scene:home:Dachfenster_Storen2_Zu:actionâ }
Switch Dachfenster_Storen2_Licht_Szenenstart âDachfenster Bad Storen Lichtâ { channel=âvelux:scene:home:Dachfenster_Storen2_Licht:actionâ }
Switch Dachfenster_Storen_Auf_Szenenstart âDachfenster Alle Storen öffnenâ { channel=âvelux:scene:home:Dachfenster_Storen_Auf:actionâ }
Switch Dachfenster_Storen_Zu_Szenenstart âDachfenster Alle Storen schliessenâ { channel=âvelux:scene:home:Dachfenster_Storen_Zu:actionâ }
Switch Dachfenster_Storen_Licht_Szenenstart âDachfenster Alle Storen Lichtâ { channel=âvelux:scene:home:Dachfenster_Storen_Licht:actionâ }
Switch Dachfenster_Fenster1_Auf_Szenenstart âDachfenster Gang öffnenâ { channel=âvelux:scene:home:Dachfenster_Fenster1_Auf:actionâ }
Switch Dachfenster_Fenster1_Zu_Szenenstart âDachfenster Gang schliessenâ { channel=âvelux:scene:home:Dachfenster_Fenster1_Zu:actionâ }
Switch Dachfenster_Fenster2_Auf_Szenenstart âDachfenster Bad öffnenâ { channel=âvelux:scene:home:Dachfenster_Fenster2_Auf:actionâ }
Switch Dachfenster_Fenster2_Zu_Szenenstart âDachfenster Bad schliessenâ { channel=âvelux:scene:home:Dachfenster_Fenster2_Zu:actionâ }
Switch Dachfenster_Fenster_Auf_Szenenstart âDachfenster Alle öffnenâ { channel=âvelux:scene:home:Dachfenster_Fenster_Auf:actionâ }
Switch Dachfenster_Fenster_Zu_Szenenstart âDachfenster Alle schliessenâ { channel=âvelux:scene:home:Dachfenster_Fenster_Zu:actionâ }
Rollershutter Dachfenster_Storen_Bad_Position âDachfenster Storen Bad Position [%.0f %%]â {channel=âvelux:rollershutter:home:Dachfenster_Storen_Bad:positionâ}
Rollershutter Dachfenster_Storen_Gang_Position âDachfenster Storen Gang Position [%.0f %%]â {channel=âvelux:rollershutter:home:Dachfenster_Storen_Gang:positionâ}
Rollershutter Dachfenster_Fenster_Bad_Position âDachfenster Fenster Bad Position [%.0f %%]â {channel=âvelux:window:home:Dachfenster_Fenster_Bad:positionâ}
Rollershutter Dachfenster_Fenster_Gang_Position âDachfenster Fenster Gang Position [%.0f %%]â {channel=âvelux:window:home:Dachfenster_Fenster_Gang:positionâ}
âSTATUSâ, âFIRMWAREâ, and âIPADDRESSâ are not valid Channels; although âstatusâ (lowercase) is. âAddressâ, and âFirmwareâ, are Properties, and âipAddressâ is also a Configuration Parameter.
You get the error on Dachfenster_Storen1_Auf (say), so check if the respective scene name Storen_Gang_rauf is actually listed in MainUI in the Scenes Property of your Bridge.
Thing scene Dachfenster_Storen1_Auf âDachfenster_Storen1_Aufâ [sceneName=âStoren_Gang_raufâ ]
The output of the command âopenhab:things show velux:klf200:homeâ in the openhab console shows the following. What worries me is the content of the âcheckâ property. In the KLF200 the names of the scenes are exactly defined as stated in my thing objects.
openhab> openhab:things show velux:klf200:home
UID: velux:klf200:home
Type: velux:klf200
Label: Velux KLF200
Status: ONLINE
Properties:
connectionSuccess : Wed Jan 06 11:13:42 CET 2021
address : 192.168.15.31
vendor : Velux
defaultGW : 192.168.15.1
scenes : 15_members:_Scene_"Storen_Gang_runter"_(index_15)_with_non-silent_mode_and_0_actions,Scene_"Fenster_Gang_auf"_(index_6)_with_non-silent_mode_and_0_actions,Scene_"Storen_Bad_runter"_(index_0)_with_non-silent_mode_and_0_actions,Scene_"Storen_Alle_Licht"_(index_13)_with_non-silent_mode_and_0_actions,Scene_"Storen_Alle_rauf"_(index_3)_with_non-silent_mode_and_0_actions,Scene_"Fenster_Alle_zu"_(index_9)_with_non-silent_mode_and_0_actions,Scene_"Storen_Alle_runter"_(index_11)_with_non-silent_mode_and_0_actions,Scene_"Storen_Bad_rauf"_(index_1)_with_non-silent_mode_and_0_actions,Scene_"Fenster_Gang_zu"_(index_7)_with_non-silent_mode_and_0_actions,Scene_"Storen_Gang_rauf"_(index_16)_with_non-silent_mode_and_0_actions,Scene_"Fenster_Bad_auf"_(index_4)_with_non-silent_mode_and_0_actions,Scene_"Fenster_Alle_auf"_(index_8)_with_non-silent_mode_and_0_actions,Scene_"Storen_Gang_Licht"_(index_2)_with_non-silent_mode_and_0_actions,Scene_"Fenster_Bad_zu"_(index_5)_with_non-silent_mode_and_0_actions,Scene_"Storen_Bad_Licht"_(index_12)_with_non-silent_mode_and_0_actions
check : IntegritĂ€tsprĂŒfung fehlgeschlagen. Nachfolgende Szenen werden nicht verwendet: [Storen_Gang_runter, Fenster_Gang_auf, Storen_Bad_runter, Storen_Alle_Licht, Storen_Alle_rauf, Fenster_Alle_zu, Storen_Alle_runter, Storen_Bad_rauf, Fenster_Gang_zu, Storen_Gang_rauf, Fenster_Bad_auf, Fenster_Alle_auf, Storen_Gang_Licht, Fenster_Bad_zu, Storen_Bad_Licht]
subnetMask : 255.255.255.0
firmware : Software version 0.2.0.0.71.0, Hardware version 5.14.3
DHCP : OFF
connectionAttempt : Wed Jan 06 11:13:42 CET 2021
products : 4_members:_Product_"Fenster_Gang"_/_SLIDER_WINDOW_(bridgeIndex=2,serial=xx:xx:xx:xx:xx:xx:xx:xx,position=C800),Product_"Storen_Gang"_/_SLIDER_SHUTTER_(bridgeIndex=4,serial=xx:xx:xx:xx:xx:xx:xx:xx,position=8425),Product_"Fenster_Bad"_/_SLIDER_WINDOW_(bridgeIndex=0,serial=xx:xx:xx:xx:xx:xx:xx:xx,position=0104),Product_"Storen_Bad"_/_SLIDER_SHUTTER_(bridgeIndex=1,serial=xx:xx:xx:xx:xx:xx:xx:xx,position=73AF)
would it be possible to create a exception table for older devices that they are update more frequently?
I am using an 7 year old rullershutter that seems not to send a GW_NODE_STATE_POSITION_CHANGED_NTF after moving.
It takes very long until the state is updated in OH when using a velux remote.
Here is the trace log output. By the way, Iâm able to control the rollershutter and window as expected via OpenHAB rules (e.g. by âsendCommand(Dachfenster_Storen_Auf_Szenenstart, ON)â). The problem is only the unexpected log output.
2021-01-06 13:24:43.628 [DEBUG] [.internal.handler.ChannelBridgeCheck] - handleRefresh(velux:klf200:home:check,check,org.openhab.binding.velux.internal.handler.VeluxBridgeHandler@2de94262) called.
2021-01-06 13:24:43.629 [TRACE] [.internal.handler.ChannelBridgeCheck] - handleCommand(): loop through all existing scenes.
2021-01-06 13:24:43.629 [TRACE] [.internal.handler.ChannelBridgeCheck] - handleCommand(): .loop through all handled channels.
2021-01-06 13:24:43.630 [TRACE] [.internal.handler.ChannelBridgeCheck] - handleCommand(): evaluating ChannelUID velux:klf200:home:status.
2021-01-06 13:24:43.630 [TRACE] [.internal.handler.ChannelBridgeCheck] - handleCommand(): ignoring non SCENE_ACTION.
2021-01-06 13:24:43.630 [TRACE] [.internal.handler.ChannelBridgeCheck] - handleCommand(): evaluating ChannelUID velux:scene:home:Dachfenster_Fenster_Auf:action.
2021-01-06 13:24:43.631 [TRACE] [.internal.handler.ChannelBridgeCheck] - handleCommand(): aborting processing as scene name is not set.
2021-01-06 13:24:43.631 [TRACE] [.internal.handler.ChannelBridgeCheck] - handleCommand(): scene Storen_Gang_runter is currently unused.
2021-01-06 13:24:43.631 [TRACE] [.internal.handler.ChannelBridgeCheck] - handleCommand(): .loop through all handled channels.
2021-01-06 13:24:43.631 [TRACE] [.internal.handler.ChannelBridgeCheck] - handleCommand(): evaluating ChannelUID velux:klf200:home:status.
2021-01-06 13:24:43.632 [TRACE] [.internal.handler.ChannelBridgeCheck] - handleCommand(): ignoring non SCENE_ACTION.
2021-01-06 13:24:43.632 [TRACE] [.internal.handler.ChannelBridgeCheck] - handleCommand(): evaluating ChannelUID velux:scene:home:Dachfenster_Fenster_Auf:action.
2021-01-06 13:24:43.632 [TRACE] [.internal.handler.ChannelBridgeCheck] - handleCommand(): aborting processing as scene name is not set.
2021-01-06 13:24:43.633 [TRACE] [.internal.handler.ChannelBridgeCheck] - handleCommand(): scene Fenster_Gang_auf is currently unused.
2021-01-06 13:24:43.633 [TRACE] [.internal.handler.ChannelBridgeCheck] - handleCommand(): .loop through all handled channels.
2021-01-06 13:24:43.633 [TRACE] [.internal.handler.ChannelBridgeCheck] - handleCommand(): evaluating ChannelUID velux:klf200:home:status.
2021-01-06 13:24:43.633 [TRACE] [.internal.handler.ChannelBridgeCheck] - handleCommand(): ignoring non SCENE_ACTION.
2021-01-06 13:24:43.634 [TRACE] [.internal.handler.ChannelBridgeCheck] - handleCommand(): evaluating ChannelUID velux:scene:home:Dachfenster_Fenster_Auf:action.
2021-01-06 13:24:43.634 [TRACE] [.internal.handler.ChannelBridgeCheck] - handleCommand(): aborting processing as scene name is not set.
2021-01-06 13:24:43.634 [TRACE] [.internal.handler.ChannelBridgeCheck] - handleCommand(): scene Storen_Bad_runter is currently unused.
2021-01-06 13:24:43.635 [TRACE] [.internal.handler.ChannelBridgeCheck] - handleCommand(): .loop through all handled channels.
2021-01-06 13:24:43.635 [TRACE] [.internal.handler.ChannelBridgeCheck] - handleCommand(): evaluating ChannelUID velux:klf200:home:status.
2021-01-06 13:24:43.635 [TRACE] [.internal.handler.ChannelBridgeCheck] - handleCommand(): ignoring non SCENE_ACTION.
2021-01-06 13:24:43.636 [TRACE] [.internal.handler.ChannelBridgeCheck] - handleCommand(): evaluating ChannelUID velux:scene:home:Dachfenster_Fenster_Auf:action.
2021-01-06 13:24:43.636 [TRACE] [.internal.handler.ChannelBridgeCheck] - handleCommand(): aborting processing as scene name is not set.
2021-01-06 13:24:43.636 [TRACE] [.internal.handler.ChannelBridgeCheck] - handleCommand(): scene Storen_Alle_Licht is currently unused.
2021-01-06 13:24:43.637 [TRACE] [.internal.handler.ChannelBridgeCheck] - handleCommand(): .loop through all handled channels.
2021-01-06 13:24:43.637 [TRACE] [.internal.handler.ChannelBridgeCheck] - handleCommand(): evaluating ChannelUID velux:klf200:home:status.
2021-01-06 13:24:43.637 [TRACE] [.internal.handler.ChannelBridgeCheck] - handleCommand(): ignoring non SCENE_ACTION.
2021-01-06 13:24:43.638 [TRACE] [.internal.handler.ChannelBridgeCheck] - handleCommand(): evaluating ChannelUID velux:scene:home:Dachfenster_Fenster_Auf:action.
2021-01-06 13:24:43.638 [TRACE] [.internal.handler.ChannelBridgeCheck] - handleCommand(): aborting processing as scene name is not set.
2021-01-06 13:24:43.638 [TRACE] [.internal.handler.ChannelBridgeCheck] - handleCommand(): scene Storen_Alle_rauf is currently unused.
2021-01-06 13:24:43.638 [TRACE] [.internal.handler.ChannelBridgeCheck] - handleCommand(): .loop through all handled channels.
2021-01-06 13:24:43.639 [TRACE] [.internal.handler.ChannelBridgeCheck] - handleCommand(): evaluating ChannelUID velux:klf200:home:status.
2021-01-06 13:24:43.639 [TRACE] [.internal.handler.ChannelBridgeCheck] - handleCommand(): ignoring non SCENE_ACTION.
2021-01-06 13:24:43.639 [TRACE] [.internal.handler.ChannelBridgeCheck] - handleCommand(): evaluating ChannelUID velux:scene:home:Dachfenster_Fenster_Auf:action.
2021-01-06 13:24:43.639 [TRACE] [.internal.handler.ChannelBridgeCheck] - handleCommand(): aborting processing as scene name is not set.
2021-01-06 13:24:43.639 [TRACE] [.internal.handler.ChannelBridgeCheck] - handleCommand(): scene Fenster_Alle_zu is currently unused.
2021-01-06 13:24:43.639 [TRACE] [.internal.handler.ChannelBridgeCheck] - handleCommand(): .loop through all handled channels.
2021-01-06 13:24:43.640 [TRACE] [.internal.handler.ChannelBridgeCheck] - handleCommand(): evaluating ChannelUID velux:klf200:home:status.
2021-01-06 13:24:43.640 [TRACE] [.internal.handler.ChannelBridgeCheck] - handleCommand(): ignoring non SCENE_ACTION.
2021-01-06 13:24:43.640 [TRACE] [.internal.handler.ChannelBridgeCheck] - handleCommand(): evaluating ChannelUID velux:scene:home:Dachfenster_Fenster_Auf:action.
2021-01-06 13:24:43.640 [TRACE] [.internal.handler.ChannelBridgeCheck] - handleCommand(): aborting processing as scene name is not set.
2021-01-06 13:24:43.640 [TRACE] [.internal.handler.ChannelBridgeCheck] - handleCommand(): scene Storen_Alle_runter is currently unused.
2021-01-06 13:24:43.640 [TRACE] [.internal.handler.ChannelBridgeCheck] - handleCommand(): .loop through all handled channels.
2021-01-06 13:24:43.640 [TRACE] [.internal.handler.ChannelBridgeCheck] - handleCommand(): scene Storen_Bad_rauf is currently unused.
2021-01-06 13:24:43.641 [TRACE] [.internal.handler.ChannelBridgeCheck] - handleCommand(): aborting processing as scene name is not set.
2021-01-06 13:24:43.641 [TRACE] [.internal.handler.ChannelBridgeCheck] - handleCommand(): scene Fenster_Gang_zu is currently unused.
2021-01-06 13:24:43.641 [TRACE] [.internal.handler.ChannelBridgeCheck] - handleCommand(): .loop through all handled channels.
2021-01-06 13:24:43.641 [TRACE] [.internal.handler.ChannelBridgeCheck] - handleCommand(): evaluating ChannelUID velux:klf200:home:status.
2021-01-06 13:24:43.641 [TRACE] [.internal.handler.ChannelBridgeCheck] - handleCommand(): ignoring non SCENE_ACTION.
2021-01-06 13:24:43.641 [TRACE] [.internal.handler.ChannelBridgeCheck] - handleCommand(): evaluating ChannelUID velux:scene:home:Dachfenster_Fenster_Auf:action.
2021-01-06 13:24:43.641 [TRACE] [.internal.handler.ChannelBridgeCheck] - handleCommand(): scene Storen_Gang_rauf is currently unused.
2021-01-06 13:24:43.641 [TRACE] [.internal.handler.ChannelBridgeCheck] - handleCommand(): scene Fenster_Bad_auf is currently unused.
2021-01-06 13:24:43.642 [TRACE] [.internal.handler.ChannelBridgeCheck] - handleCommand(): evaluating ChannelUID velux:scene:home:Dachfenster_Fenster_Auf:action.
2021-01-06 13:24:43.642 [TRACE] [.internal.handler.ChannelBridgeCheck] - handleCommand(): aborting processing as scene name is not set.
2021-01-06 13:24:43.642 [TRACE] [.internal.handler.ChannelBridgeCheck] - handleCommand(): scene Fenster_Alle_auf is currently unused.
2021-01-06 13:24:43.642 [TRACE] [.internal.handler.ChannelBridgeCheck] - handleCommand(): .loop through all handled channels.
2021-01-06 13:24:43.642 [TRACE] [.internal.handler.ChannelBridgeCheck] - handleCommand(): evaluating ChannelUID velux:klf200:home:status.
2021-01-06 13:24:43.642 [TRACE] [.internal.handler.ChannelBridgeCheck] - handleCommand(): ignoring non SCENE_ACTION.
2021-01-06 13:24:43.642 [TRACE] [.internal.handler.ChannelBridgeCheck] - handleCommand(): scene Storen_Gang_Licht is currently unused.
2021-01-06 13:24:43.642 [TRACE] [.internal.handler.ChannelBridgeCheck] - handleCommand(): scene Fenster_Bad_zu is currently unused.
2021-01-06 13:24:43.643 [TRACE] [.internal.handler.ChannelBridgeCheck] - handleCommand(): ignoring non SCENE_ACTION.
2021-01-06 13:24:43.643 [TRACE] [.internal.handler.ChannelBridgeCheck] - handleCommand(): evaluating ChannelUID velux:scene:home:Dachfenster_Fenster_Auf:action.
2021-01-06 13:24:43.643 [TRACE] [.internal.handler.ChannelBridgeCheck] - handleCommand(): aborting processing as scene name is not set.
2021-01-06 13:24:43.643 [TRACE] [.internal.handler.ChannelBridgeCheck] - handleCommand(): scene Storen_Bad_Licht is currently unused.
2021-01-06 13:24:43.643 [DEBUG] [.internal.handler.ChannelBridgeCheck] - IntegritĂ€tsprĂŒfung fehlgeschlagen. Nachfolgende Szenen werden nicht verwendet: [Storen_Gang_runter, Fenster_Gang_auf, Storen_Bad_runter, Storen_Alle_Licht, Storen_Alle_rauf, Fenster_Alle_zu, Storen_Alle_runter, Storen_Bad_rauf, Fenster_Gang_zu, Storen_Gang_rauf, Fenster_Bad_auf, Fenster_Alle_auf, Storen_Gang_Licht, Fenster_Bad_zu, Storen_Bad_Licht]
Interesting, thankyou. Your log tells me that there is a bug in the âcheckâ Property code; which seems to have been there for a long time, but apparently this has upset nobody.
Indeed I am pretty sure that the âcheckâ Property is NOT the cause of your problem. And there might not be a real problem at all, but rather just a mis-placed WARN message. However I need further logs to help figure out what is really going wrongâŠ
Thank you for the log. It seems to indicate that your issue is just a mis-placed warning message. I donât have any scenes in my operative KLF200, so I did not notice this warning myself.
I built a new version of the binding which should a) eliminate the warning, and b) fix the âcheckâ property.
My main system is on OH v2.5.x and my OH v3.1.x test system is broken at the moment, so I hope that you can test this new build rigorously for me.
I have installed your patched version yesterday evening. Everything is working as expected so far. No more warn messages, the âcheckâ property no longer contains an error.
I could kick myself. I had a stable system running OpenHAB 2.5.10 stable with the 2.5.11 snapshot Velux plugin. Then I updated to 2.5.11 stable, still using the same snapshot binding and I get a connection refused error:
Yes, a number of times. At first it was blinking white. Power-cycling solved that and initially everything worked fine but when I got home from work all shutters were still openâŠ
If you are still using the same 2.5.11-SNAPSHOT jar (in your addons folder), then nothing has changed. There were no changes in the OH core between 2.5.10 and 2.5.11, and there were no changes in the binding (because you are using the same jar in the addons folder as before).
EDIT: if you âlostâ the V2.5.11-snapshot JAR then it is still here
I think the timer has no impact on any refresh intervall as I can always see quereys after 10000 ms in traces (shortened):
10:29:27.504 [TRACE] [.binding.velux.internal.VeluxItemType] - getByThingAndChannel(velux:klf200,check) returns enum velux:klf200/check.
10:29:27.506 [TRACE] [.binding.velux.internal.VeluxItemType] - isToBeRefreshedNow(): returning false, as refresh cycle has not yet come for this item.
10:29:37.663 [TRACE] [.binding.velux.internal.VeluxItemType] - isToBeRefreshedNow(): returning false, as refresh cycle has not yet come for this item.
10:29:37.665 [DEBUG] [x.internal.handler.VeluxBridgeHandler] - refreshOpenHAB() initiated by Thread[OH-thingHandler-1,5,main] finished cycle 16635.
10:29:47.668 [DEBUG] [x.internal.handler.VeluxBridgeHandler] - refreshOpenHAB() initiated by Thread[OH-thingHandler-5,5,main] starting cycle 16636.
10:29:47.673 [TRACE] [x.internal.handler.VeluxBridgeHandler] - refreshOpenHAB(): processing of possible HSM messages.
But I think the problem is that the old Velux device (2012) that has a different behaviour than the devices from 2018.
The devices from 2018 (Blinds) send a GW_NODE_STATE_POSITION_CHANGED_NTF immediately after moving, the device from 2012 (Blinds with solar power) not.
As I mentioned some time ago here it is also not possible to stop moving of the old device via OH, you came tho the conclusion that it must be the old device
