I’m replacing a ceiling/roof window at my house and have the option to select an electrical window from Fakro or Velux. Is there anyone here with experience of using any of them with openhab that could help me select which one to go with?
MDAR
2
I’ve just configured some Velux Integra windows for a client.
As far as I can make out, there is no way to directly control them over TCP (for example).
Fakro I don’t know but I’d suggest to not go with Velux as they’ll lock you into their proprietary solution, the iohomecontrol stuff being the worst in this regard I’ve ever seen to date.
You’ll be having a hard time when there’s a need for repair or replacement and seamless integration into OH.
Get the windows with the motor only (without the RF receiver parts and controller). Hook them up to an actuator of some standards based HA system such as KNX or ZWave (probably the latter as that’s wireless and cheaper to start with).
Hi Markus
I have no knowledge of any of the windows, but it appears as the Fakro window is available with a z-wave module. That’s not proprietary, right? My original plan was to go with the Fakro window, but the contractor suggested the Velux window instead since it’s designed to better withstand moisture (bathroom installation).
Not quite true.
There is a Velux binding for the KLF200. But it´s limited to 32 scenes only.
Howvever - News are coming, Velux have made an new firmware for the KLF200, with a “real” API. This looks really promising.
Regard wether to select Velux or Fakro.. Fakro have Z-wave windows. I havnt tried though. But at least this is a very good supported interface for working with openhab. I would contact Fakro and ask to get a communication module to test with a Z-wave controller. I dont know if these windows have been added to the database yet, but that should be the least.
Indeed, seems that it should work with any ZWave controller such as your openHAB box (to have a RaZberry board or Aeon USB stick, search the forum, there’s many posts on ZWave).
And since that’ll allow for automating opening those windows to ventilate your bathroom, they will have to withstand a lot less moisture
MDAR
9
Thanks for the heads up
Where can I find this Velux binding your talking about?
Fakro supports Z-Wave for the roller shutters, blinds and window opening actuator. They stick to Z-Wave, they don’t use Z-Wave Plus.
I use an inexpensive Z-Wave ZME EU USB stick.
You can either use a ZWP10 remote (5 channels x 2) and use the Z-Wave USB stick as slave (include it from the ZWP10 remote), or you can configure the Z-Wave USB stick as master (but then I’d recommend using a Z-Wave management tool). In the latter case, there’s no real need for getting the ZWP10 remote, unless you also want to operate the windows, blinds or roller shutters without OpenHAB.
The Fakro roller shutters will calibrate their “fully up” and “fully down” positions automatically. You can only fully open, fully close or stop the blinds. You can’t set a percentage value for partial opening/closing the blinds. Or at least, I couldn’t yet find a way to get them working.
One note: it appears that the Fakro roller shutters are being identified as 12V ZWS window actuators. That’s mostly a cosmetic problem as they will work, even though they’re incorrectly reported.
That’s what you should do. Devices will send notifications to the master only.
Habmin should be able to do the trick for you.
If you refer to the “12V” in the name but have 230VAC ones please correct this in the database.
Rename it to ZWS12_ZWS230 or just ZWS as it seems they are both using the same identifier.
Eventually also add a device entry for the remote if you have one.
I just quickIy looked at the DB but noticed that entry 325 sort of looked incomplete to me.
There also was another entry I think #777 to have the same (?) name but way more data.
But no need to take action if #325 works for you.
Someone has to be the first to add a device. Can you add it to the database and upload your .xml.
Then get an updated openHAB snapshot to contain that DB update.
