Hello community!
After lengthy research I thought I’d address the elephant in the room: The KLF 200 has been discontinued by Velux. It is very hard to get hold of one now and will be almost impossible soon. Since the thread [velux] New OpenHAB2 binding - feedback welcome! has become really, really long I thought I’d start a new one.
The situation is that my KLF 200 has died. Since I needed a solution soon I ordered a Velux Gateway (KIG 300) to be at least able to integrate my roller shutters via Apple Homekit. Unfortunately this has ended openHAB integration for me.
There is the KLF 150 which seems to be the official successor. I did not want to order one out of the blue just to find out it is not compatible with the openHAB binding. For starters, it no longer has an easily accessible LAN port. I am not sure if it has one at all, tbh. Information is scarce as Velux are not really community friendly. I read somewhere that there is one internally, but only “for use by Velux”. Also the API seems to be gone. Has anyone tried to use the KLF 150 with the openHAB Velux binding an can confirm that it works (or not)?
That leaves me with the question what you guys suggest I should do to get my Velux devices back into openHAB. Since I already own the Velux Gateway: Is there any way to control that Gateway via openHAB? There already is a Github issue to make openHAB act as HAP (HomeKit Accessory Protocol) client (not a server!) but there doesn’t seem to be a solution in the foreseeable future.
I read some things about integration via Somfy, but tbh. I could not make heads or tails of it. It seemed very complicated to me.
Any advice would be greatly appreciated. ![]()
Cheers
Jens
