This binding integrates Viessmann heating devices using the Viessmann API.
It provides information similar to what you can get through the ViCare mobile app.
Please note this binding is unofficial and not endorsed by Viessmann in any way.
Requirements
This binding requires OpenHAB 4.0. For earlier versions of OpenHAB please refer to previous versions of this binding on
the community marketplace discussion for the corresponding binding version.
Upgrading from OpenHAB 3.4
It is advisable to remove previous versions of the plugin before upgrading OpenHAB.
However if you have upgraded to OpenHAB 4.0 and still have the old binding installed, remove it from the
Settings->Bindings admin page. This may fail, in which case you will need to log into the OpenHAB shell
and run
feature:list | grep qub
If the feature is still installed, remove it with
feature:uninstall com.qubular.openhab-binding-vicare-feature
However if removal of the feature did not succeed, the bundles may also need to be removed. If the following
bundle:list | grep qub
shows that the bundles are still installed, then remove them as follows
bundle:uninstall com.qubular.openhab-binding-vicare-bundle
bundle:uninstall com.qubular.vicare-osgi
Once the old binding is fully removed, you can install the new version from the Settings->Bindings page
There is no need to add or remove any of the Things they will still work with the new binding.
Supported Devices
This binding has only been developed against a Vitodens 100-W in a fairly
basic configuration, however it should be able to work against a range of other Viessmann heating and ventilation
devices including heat pumps and solar heating, although not all features on these may be supported yet.
Supported Features
Below is an incomplete summary of the main features supported - depending on your boiler model and/or heating
configuration some or all of these may or may not be present:
- Read and write of active heating circuit operating mode.
- Temperature sensors
- Temperature setpoints (read/write)
- Supply temperature max/min limit (read/write)
- Burner status
- Burner modulation
- Burner statistics (hours and starts)
- Circulation pump status
- Frost protection status
- Basic text properties: device serial number etc.
- DHW, Heating and Total consumption statistics
- Program mode temperature settings
- DHW Heating status
- DHW Charging active
- DHW Hot water storage temperature
- DHW Primary and Circulation Pump Status
- DHW target temperature (read/write)
- DHW One time charge mode (read/write)
- DHW Temperature Hysteresis (read/write)
- Holiday program settings (read-only)
- Holiday-at-home program settings (read-only)
- Heating curve settings
- Heating circuit names
- Heating circuit operating mode (read/write)
- Heating circuit supply temperature
- Extended heating mode
- Solar production statistics
- Solar collector temperature
- Solar circuit pump status
- Heat pump compressor status
- Heat pump compressor statistics
- Heat pump primary and secondary supply temperature sensors
- Ventilation operating mode and operating program
- Ventilation holiday program (read-only)
- Heating buffer temperature sensors
Generic Device Support
The has generic read-only support for unrecognised devices which will report read-only
values for boolean, string and numeric properties.
Configuring
In order to use the binding, you will need to have a Viessmann API account and
configure it with the redirect URL for your OpenHAB installation and then authorise
the binding. Follow the instructions in openhab at http://<Your OpenHAB>/vicare/setup
Create an instance of the Viessmann API Bridge thing, and configure it with your Client ID
which you should obtain from the Viessmann Developer portal. The developer portal should be
configured with the redirect URI shown on the setup page. Then you should be able to
authorise the Viessmann binding by clicking on the Authorise button on the setup page.
After authorising the binding, then it should automatically discover any heating devices you have
and they will appear in your Inbox.
Note that the API is rate-limited to 1450 requests per day, or approximately once every 60 seconds;
exceeding the threshold incurs a lockout for the rest of the day.
The default polling interval is configured to 90 seconds to leave some headroom for additional requests.
If you have multiple heating devices configured then you may need to increase the polling interval.
Changelog
4.0.3
- Fix for #57 Rework prefetching
- Add generic read-only support for unrecognised devices and boolean, string and numeric properties
4.0.2
- Fixed #55 Karaf refreshes binding on restart and unloads it
- Fix for #57 Threading issues and log spam after HTTP connection EOF
- Fix for #56 support for heating.buffer.sensors.temperature.main temperature value
4.0.1
- Fixed #48 Slow startup of Viessmann binding under 4.0.0
- Fixed #50 Viessmann bridge can’t be added
- Fixed #54 Feature endpoint now returns incorrect payload
4.0.0
This version introduces support for OpenHAB 4.0
