I had a need to control electric heaters via thermostat. I built a virtual thermostat consisting of a temp sensor (Fibaro Universal Binary Sensor FGBS0001 + DS18B20), z-wave switch/socket and some OH rules. DS18B20 temp sensor is either attached to the heater (if I want to control the heater temp, like the for towel hanger in the bathroom), embedded in floor (for floor heating) or is measuring ambient temperature.
Thanks for sharing, the only problem I can see is that if you manually turn off your heater (Sw_Heater_Towels) and the temp sensor is below your threshold, it will just turn back on again, in the second half of your rule.
Here is a very similar rule I use;
rule "Nursery heating"
Item VT_Heating_Mode_Nursery changed or
Item VT_Heating_Setpoint_Nursery changed or
Item FF_Nursery_Temp changed or
Item FF_Nursery_Window changed
// 0="Off", 1="On", 2="Auto"
if (VT_Heating_Mode_Nursery.state == 0) {
// heater off
FF_Nursery_Heater.sendCommand(OFF)
} else if (VT_Heating_Mode_Nursery.state == 1) {
// heater on
FF_Nursery_Heater.sendCommand(ON)
} else if (VT_Heating_Mode_Nursery.state == 2) {
// only fire up the heater if the nursery window is closed
if (FF_Nursery_Window.state == CLOSED) {
// get the current setpoint for the nursery
var Number setpoint = VT_Heating_Setpoint_Nursery.state as DecimalType
// calculate the turn on/off temperatures
var Number turnOnTemp = setpoint - 0.5
var Number turnOffTemp = setpoint + 0.5
// get the current temperature in the nursery
var Number temp = FF_Nursery_Temp.state as DecimalType
// determine whether we need to turn on/off the heater
if (temp <= turnOnTemp) {
// turn on temp has been reached so switch on the heater
} else if (temp >= turnOffTemp) {
// turn off temp has been reached so switch off the heater
} else {
// heater off
Using the following items;
// heating setpoints
Number VT_Heating_Setpoint_Nursery "Nursery Setpoint [%.1f °C]" <degreesc>
// heating modes: 0 - Off, 1 - On, 2 - Auto
Number VT_Heating_Mode_Nursery "Nursery Heating Mode" <heating>
Switch FF_Nursery_Heater "Nursery Heater" <fire> { zwave="32:command=SWITCH_BINARY" }
Number FF_Nursery_Temp "Nursery [%.1f °C]" <temperature> { rfxcom="<14082:Temperature" }
Then finally in my sitemap;
Switch item=VT_Heating_Mode_Nursery label="Heating Mode" mappings=[0="Off", 1="On", 2="Auto"]
Setpoint item=VT_Heating_Setpoint_Nursery label="Target Temperature [%.1f °C]" minValue=16 maxValue=24 step=0.5 visibility=[VT_Heating_Mode_Nursery==2]
Text item=FF_Nursery_Heater
So I can either manually override and set the heater on/off, or set it to auto and adjust the setpoint to control the temp. The Text item=FF_Nursery_Heater just shows the state of the heater, i.e. whether it is on or off.
I have used your code and it works great but im having issues with endpoint temperature set for auto mode its very slow and unresponsive sometimes i have to keep pressing and it wount change right away.
