Many users reporting that language check with VSCode is very slow. I can confirm it on RPI3b and on Rock64.
I am wondering is the problem is not with LSP implementation only, but with how it is used in VSC.
I can see that for every character typed the LSP check is issued. This is queued for all characters entered.
Better it would be to do an delta check periodically e.g. every 15-30s.
Can somebody have a look of possibilities at VSCode to do so.
Sadly no.
We didn’t make any progress further than opening some issues in different repositories.
The client configuration part is done here:
Maybe the workspace API can start a check on “save” instead of watching for every change.
Every change could be fine if the server part is runnig on the same machine, but is obviously critical in our case where the server part is running with the openHAB instance.
i have the same problems. I played a bit with a JS LSP a while ago so i know that there are two ways to transmit the changes:
incremental
full
Full always sends the complete changed file which causes a lot of traffic and a lot of parsing.
Incremental only sends the changed parts and the server side takes care of merging that into the initial opened file.
Vscode LSP docs explain it a bit better here:
From my vscode experience i know that you can not use both modes at the same time so the server needs to be configured to use incremental instead of full transmission.
I can not find your lsp code, so maybe you can point me to it, so i can have a look what you guys do in your LSP.
And there incremental is set already. I’m currently not at home so i can not play around with my setup, but maybe i will find some time over the weekend to investigate a bit more.
i just found one possible issue that slows down the LSP. The LSP seems to load the items from the rest API http://host:port/rest/items. So if the call to the rest api is slow, the LSP is also slow.
This thread helped me a bit out about this:
I also have the echo binding installed. So i made measurements… With 2 or 3 Items from my Echo i measured around 1.5-1.7s to load all the items from the rest api. When i removed the echo items it went down to 0.5s.
Then i tested both with vscode again and its much faster without the echo dot items.
So maybe its not a LSP issue but a problem with the REST api for some items.
There are several config options for the VSC extension:
// Enables communication with Language Server Protocol - installed in openHAB as 'misc-lsp' add-on
"openhab.lspEnabled": true
// Takes completions from Language Server instead of REST API
"openhab.restCompletions": true
"openhab.useRestApi": true
Have you tried to play with these?
For example: disable REST API and use only LSP (lspEnabled=true & restCompletions=false)?
I am not 100% sure about the restCompletions since the description is misleading versus the name of the parameter
yes i played a bit. When useRestApi=false then its the same as LSP disabled. Only local stuff is taken into account.
There was no noticable difference between restCompletions=true or false. Timewise it looked the same to me, no idea what happens internally.
So from outside without further investigation it looks like it always uses the items from the REST api. But i will look into it a bit more in detail tomorrow, maybe i can make out the difference between restCompletions true/false…
I had to restart vscode for settings to have any effect. It was indeed the REST api that slows down the auto completion. Here i explain it a bit more in detail:
There already has been an issue on this, but unfortunately it was closed. Hopefully Kuba will read it and maybe reopen it.
Just some information for those, who don’t follow the github repo that frequently.
Code completions are coming from the rest api in the current extension version.
This is one reason for the high loads, so it would be a solution/workaround to disable them temporary.
This can already be done with the following setting.
It has to be set to false. Caution: The description over there is wrong!
We recognized that during our investigation.
I have already opened a (wip) pull request for some smaller changes/fixes, which will correct this description too.
Also thanks to @MHerbst and @Rangarid, who are currently helping out actively to get some progress for the urgent problems.
We made a big step forward with identifying some problem sources and had already some good discussion and ideas on how to solve some of them on mid term.
Thanks, I think I misunderstood. This setting applies to the VSC running on the remote machine.
I was wondering if the VSC support can be turned off on the openhab installation side.
I am running openhab on a rpi3b, but I am not using VSC, so I wanted to turn it off.
The one thing though I now see is the following error during startup:
2018-12-15 11:43:52.218 [ERROR] [org.eclipse.smarthome.model.lsp ] - FrameworkEvent ERROR - org.eclipse.smarthome.model.lsp
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.model.lsp [130]
Unresolved requirement: Import-Package: org.eclipse.lsp4j.jsonrpc
at org.eclipse.osgi.container.Module.start(Module.java:444) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1634) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1614) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1585) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1528) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) [?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) [?:?]
I’m not sure if that will create any problems down the road?
