Hi Everybody!
Total noob here. I am trying to simply connect a dome zwave sensor to openhab. I am running the latest version of Open Hab and am using a mac book.
Everything works fine except the device is perpetually offline. It starts to initialize then goes to offline. Here is the log information:
16:20:02.507 [INFO ] [lassic.internal.servlet.WebAppServlet] - Started Classic UI at /classicui/app
16:20:05.051 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - ‘zwave:serial_zstick:bb8210b9’ changed from UNINITIALIZED to INITIALIZING
16:20:05.069 [INFO ] [ding.zwave.handler.ZWaveSerialHandler] - Connecting to serial port ‘/dev/cu.Bluetooth-Incoming-Port’
16:20:05.074 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - ‘zwave:serial_zstick:bb8210b9’ changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
16:20:05.085 [INFO ] [ding.zwave.handler.ZWaveSerialHandler] - Serial port is initialized
16:20:05.094 [INFO ] [ommandclass.ZWaveSecurityCommandClass] - Update networkKey
16:20:05.110 [INFO ] [ave.internal.protocol.ZWaveController] - Starting ZWave controller
16:20:05.111 [INFO ] [ave.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
If anyone can help I will be forever grateful.
