kaloschke
(Kaloschke)
November 16, 2020, 8:47am
1
Hello everybody,
as far as I can see, the Weather Binding is currently the only one that you can use without paying or without your own weather station.
I have been using it for years and am very satisfied with it.
But it is only available in version 1.14.0 and is no longer supported in Openhab V3.
Or do I see this wrong?
You can continue running it in OH2 and use the remoteopenhab binding to have access in OH3.
Here is the binding compatibility discussion on GitHub.
opened 06:49PM - 05 Oct 19 UTC
closed 04:51PM - 20 Nov 23 UTC
oh1 migration
This issue contains an overview of all openHAB 1 add-ons and how/if there is an … openHAB 3 version.
_Disclaimer: This list is not a planning or to do list. It just gives an overview of the status of migrations or known other new versions bindings._
_If you want to know if a binding will be available in openHAB 3 and it's not mentioned on the list ask on the openHAB forum. Use the comments to report new or changed entries to the list._
There are 3 tables. The first table contains the openHAB 1 add-ons with no (official) openHAB 3 version, but have been voted on in the poll or are being worked on. The table contains the links to the work-in-progress if known. The second table is with unsupported openHAB 1 bindings that have not be voted on. These bindings have potential very few users and therefor the chance someone will migrate it to openHAB 3 is very low. The third table is with openHAB 1 add-ons that have a known openHAB 3 replacement. When an openHAB 1 binding from the first 2 tables has been migrated it's moved to third table.
In the lists the persistence add-ons are not included because separate work has been done: PR #5275.
The column `supported` in the table means if the add-on was officially supported in openHAB 2. This means it's included in the feature file and known to work with openHAB 2 and show up in PaperUI when legacy mode is activated. If not supported it still might work, but it needs to be installed manually.
The poll results are from the (closed) poll from the openHAB forum: [poll-which-oh1-x-addons-do-you-use](https://community.openhab.org/t/poll-which-oh1-x-addons-do-you-use/79121). Some add-ons have no poll results because those have an openHAB 2 variant and were not in the poll.
The column `Java LOC` is the number of Lines of Code of the add-on. This can give an indication on the complexity of the binding.
The column `Feature Compatible` in the last table mentions if the openHAB 3 bindings lacks some features that where part of the openHAB 1 binding.
This information is compiled to have an overview of the differences and compatibility of different openHAB add-on versions. If something is missing or changed please comment or update this list. If you have or use an openHAB 3 binding but it doesn't have the same features as the openHAB 1 version please also report.
### Add-ons to Migrate
| Add-on | OH3 Add-on | Supported in OH2 | Poll results | Java LOC | Notes |
| **Actions** |=====| =====| =====| =====| =====|
| mios | ~PR #2283~ | supported | 7 | 183 | PR closed |
| openwebif | | unsupported | 2 | 479 | |
| pebble | | supported | 4 | 215 | |
| tinkerforge | Issue #85 | unsupported | 1 | 129 | |
| weather | | unsupported | 9 | 73 | |
| **Bindings** | =====| =====| =====| =====| =====|
| asterisk | | unsupported | 5 | 373 | |
| cardio2e | | supported | 1 | 6540 | |
| cups | yes? | unsupported | 1 | 225 | Renamed as ipp? PR #164|
| davis | | unsupported | 0 | 2307 | |
| ddwrt | | unsupported | 1 | 456 | |
| dmx.artnet | ? | unsupported | 1 | 62 | |
| dmx.lib485 | ? | unsupported | 0 | 51 | |
| dmx.ola | ? | unsupported | | 69 | |
| ebus | | supported | 1 | 2876 | |
| fatekplc | | supported | 1 | 1437 | [Forum topic 113085](https://community.openhab.org/t/fatek-plc-migration-to-openhab-v3/113085)|
| fht | | unsupported | 2 | 745 | |
| freeswitch | | supported | 0 | 637 | |
| fritzaha | | unsupported | 1 | 1257 | |
| fs20 | | supported | 2 | 343 | Depends on cul transport. Supported via RFXCOM binding? |
| garadget | | supported | 4 | 752 |Can be replaced by MQTT |
| gc100ir | | supported | 0 | 1079 | |
| heatmiser | | supported | 0 | 1053 | |
| horizon | | supported | 1 | 371 | |
| intertechno | Supported via RFXCOM binding? | supported | 1 | 519 | Supported via RFXCOM binding? |
| isy | [Branch isy-binding-new](https://github.com/QuailAutomation/openhab2-addons/tree/isy-binding-new) | unsupported | 3 | 1078 | No PR, but this branch seems to contain work on this binding |
| jointspace | | supported | 2 | 445 | |
| k8055 | | supported | 0 | 352 | |
| koubachi | | supported | 0 | 656 | Koubachi service no longer exists. Will not be ported. |
| lightwaverf | | unsupported | 1 | 3717 | [Forum topic 92264](https://community.openhab.org/t/lightwaverf-new-lightwaverf-binding/92264) |
| maxcul/transport.cul | PR #9732 | supported | 4/1 | 2396 /1299 | [Forum topic 112897](https://community.openhab.org/t/migration-of-maxcul-oh1-binding-to-oh3/112897)
| mios | ~PR #2283~ | supported | 7 | 1923 | PR is named vera. Mios seems to be rebranded to vera?<br>PR closed |
| mochadx10 | | supported | 1 | 828 | |
| mystromecopower | ~PR #2756~ | supported | 1 | 639 | PR Closed |
| openenergymonitor | | supported | 5 | 791 | |
| openpaths | | unsupported | 1 | 507 | |
| owserver | | supported | 3 | 424 | |
| panasonictv | PR #11559 | supported | 8 | 214 | |
| piface | | supported | 0 | 634 | |
| plex | PR #12135 | supported | 27 | 1804 | Issue #4949, [Forum topic 111487](https://community.openhab.org/t/plex-binding-for-oh3-will-it-be-ported/111487/4), [Branch: plex](https://github.com/bigbasec/openhab-addons/tree/plex) |
| samsungac | | supported | 0 | 1145 | |
| sapp | | supported | 0 | 1942 | |
| smarthomatic | | unsupported | 1 | 2162 | |
| sonance | | supported | 0 | 444 | |
| stiebelheatpump | ~PR #3483~ | unsupported | 0 | 3228 | PR Closed |
| swegonventilation | | supported | 1 | 804 | |
| tcp | | supported | 25 | 3528 | |
| tinkerforge | [OH2 repo theoweiss](https://github.com/theoweiss/openhab2-addons) | unsupported | 4 | 91952 | No PR, See also: [ThinkerForge Forum](https://www.tinkerunity.org/forum/index.php/topic,5090.45.html)/(#85). |
| ucprelayboard| | supported | 0 | 543 | |
| wago | Supported via the modbus binding | unsupported | 0 | 626 | Supported via the modbus binding |
| weather | | supported | 31 | 3337 | |
| withings | ~PR #9154~ | unsupported | 2 | 783 | PR Closed |
| **IO** |=====| =====| =====| =====| =====|
| caldav | | supported | 24 | 181 | See the icalendar binding |
| gcal | | supported | 12 | 932 | |
| harmonyhub | | unsupported | 11 | 591 | |
| multimedia.tts<br>.freetts | | unsupported | 1 | 54 | |
| multimedia.tts<br>.speechdispatcher | | unsupported | 0 | 134 | |
| transport.xpl| | unsupported | 1 | 73 | This protocol is dead. Will not be ported. |
### Unused Add-ons
This is the table with all openHAB 1 add-ons that have no openHAB 3 replacement, are not part of legacy and had zero votes. It's uncertain if these bindings are still used. If they are used they belong in the table above.
| ciscospark | | unsupported | 0 | 189 | |
| xpl | | unsupported | 0 | 118 | |
| **Bindings** |=====| =====| =====| =====| =====|
| akm868 | | unsupported | 0 | 367 | |
| configadmin | | unsupported | 0 | 245 | |
| diyonxbee | | unsupported | 0 | 519 | |
| ehealth | | unsupported | 0 | 432 | |
| em | | unsupported | 0 | 316 | No readme |
| hms | | unsupported | 0 | 198 | |
| mcp3424 | | unsupported | 0 | 342 | |
| octoller | | unsupported | 0 | 243 | |
| panstamp | | unsupported | 0 | 816 | |
| plcbus | | unsupported | 0 | 932 | |
| powerdoglocalapi | | unsupported | 0 | 532 | |
| primare | | unsupported | 0 | 1774 | |
| rpircswitch | | unsupported | 0 | 336 | |
| s300th | | unsupported | 0 | 305 | |
| sallegra | | unsupported | 0 | 377 | |
| wr3223 | [Code wr32243](https://github.com/frami/org.openhab.binding.wr3223)| unsupported | 0 | 1776 | frami/org.openhab.binding.wr3223
| xpl | | unsupported | 0 | 267 | This protocol is dead. Will not be ported.|
| zibase | | unsupported | 0 | 613 | |
### <a name="migrated">Migrated Add-ons</a>
This is the table with all openHAB 1 add-ons that have an official openHAB 3 version.
| Add-on | OH3 Add-on | Feature Compatible | Poll results | Java LOC | Notes
| astro | yes | | 34 | 131 |
| dscalarm | yes | | 4 | 111 |
| ecobee | ~PR #6823~ | | 8 | 293 |
| harmonyhub | yes | | 15 | 126 |
| homematic | yes | | 4 | 82 |
| mail | yes | | | 187 |
| mqtt | yes | | | 112 |
| prowl | ~PR #10967~ | | 2 | 129 | [Forum topic 111478](https://community.openhab.org/t/oh3-prowl-support/111478)
| pushbullet | yes | | | 466 |
| pushsafer | ~PR #10790~ | | 1 | 184 |
| satel | yes | | | 187 |
| squeezebox | yes | | 8 | 434 |
| telegram | ~PR #5677~ | | 47 | 369 | |
| twitter | ~PR #10241~ | | 2 | 319 | |
| xbmc | yes | | 10 | 72 | Replaced by Kodi Binding
| xmpp | yes | | 3 | 443 |
| alarmdecoder | ~PR #7189~ | | 3 |890 |
| anel | yes | | 3 | 907 | |
| astro | yes | | | 2563 |
| autelis | yes | | 0 | 300 |
| bticino | ~PR #6213~ | no | 0 | 2521 | Name: openwebnet, Misses Temperature Control and CEN commands |
| benqprojector| ~PR #10341~ | | 1 | 605 | |
| bluetooth | yes | | 5 | 398 |
| caldav-command | ~PR #6453~ | no | 23 | 469 | Implemented as iCal, which offers similar features, but read-only |
| caldav-personal | ~PR #6453~ | no | 32 | 606 | |
| comfoair | ~PR #7052~ | yes | 9 | 3100 | |
| cups | yes? | | 1 | 377 | Renamed as ipp? PR #164
| daikin | yes | | 1 | 1553 |
| denon | yes | | 9 | 5233 |
| digitalstrom | yes | | 0 | 1826 |
| dmx | yes | | | 3368 |
| dscalarm | yes | | 3 | 1581 |
| dsmr | yes | | | 2121 |
| ecobee | ~PR #6823~ | |9 |6181 |
| ecotouch | ~PR #10010~ | supported | 2 | 1308 |
| ekey | ~PR #10996~| | 0 | 374 | |
| energenie | ~PR #6461~ | | 2 | 482 |
| enigma2 | ~PR #7514~ | | 3 | 520 |
| enphaseenergy| ~PR #9883~ | | 2 | 438 | Renamed enphase [Forum topic #44449](https://community.openhab.org/t/new-binding-enphase-envoy-solar-system-gateway/44449) |
| enocean | yes | | | 509 |
| epsonprojector | ~PR #9021~ | | 5 | 1853 | |
| exec | yes | no | | 745 |
| freebox | yes | | 0 | 625 |
| fritzboxtr064| ~PR #8523~ | | 52 | 1870 |
| gpio (io) | ~PR #1334~ | | 18 | 494 (795) | |
| harmonyhub | yes | | 14 | 786 |
| hdanywhere | yes | | 0 | 360 |
| homematic | yes | | | 450 |
| http | ~PR #8521~ | | 95 | 995 | |
| hue | yes | | 18 | 4651 |
| iec6205621meter | yes | | 1 | 732 | smartmeter binding |
| ihc | yes | | | 878 |
| insteonhub | | | 1 | 1246 | Replaced by OH1 insteonPLM |
| insteonplm | ~PR #6911~ | | 13 | 6637 | New binding is called insteon. PR merged |
| ipx800 | ~PR #5457~ | | 1 | 1397 | Renamed to GCE |
| irtrans | yes | | | 2724 |
| km200 | yes | | 2 | 855 |
| knx | yes | | | 2272 |
| lcn | ~PR #7509~ | | 1 | 6384 |
| lgtv | yes | no | 7 | 3131 | LGWebOs and LG Serial OH3 bindings use a different protocol, so might not be compatible
| mailcontrol | yes | | 3 | 1936 |
| maxcube | yes | | 2 | 634 |
| mcp23017 | yes | | 0 | 2853 |
| milight | yes | | | 342 |
| modbus | yes | | | 892 |
| mpd | ~PR #7870~ | | 2 | 869 | |
| mqtt | yes | no | | 12830 |
| mqttitude | yes | | | 1083 |
| myq | ~PR #9347~ | | 7 | 757 | Fullname is ChamberlainMyQ |
| neohub | ~PR #5952~ | | 0 | 467 |
| nest | yes | | | 415 |
| netatmo | yes | | | 2282 |
| networkhealth | yes | | | 3053 |
| networkupstools | ~PR #6192~ | | 26 | 244 |
| nibeheatpump | yes | | | 190 |
| nikobus | ~PR #6021~ | | 9 | 1109 |
| novelanheatpump | ~PR #9669~ | | 1 | 1060 | Renamed to luktronik [Forum topic 70743](https://community.openhab.org/t/migration-of-novelan-luxtronic-binding-to-openhab2/70743)
| ntp | yes | | 12 | 1929 |
| oceanic | yes | | 0 | 179 |
| omnilink | ~PR #8922~ | | 2 | 2293 | |
| onewire | yes | | | 820 |
| onkyo | yes | no | | 1769 | OH3 binding doesn’t support serial connection like in OH1 binding
| opensprinkler | yes | | 5 | 1515 |
| pilight | ~PR #9744~ | | 2 | 1161 | |
| pioneeravr | yes | | 2 | 277 |
| plclogo | yes | | 1 | 1266 |
| plugwise | yes | | | 2189 |
| powermax | yes | | | 3553 |
| pulseaudio | yes | | 2 | 3829 |
| pushover | ~PR #8586~ | | 30 | 669 |
| rfxcom | yes | | 4 | 1281 |
| rme | yes | | 0 | 8382 |
| rwesmarthome | yes | | | 448 |
| sagercaster | ~PR #4754~ | |0 |5542 |
| samsungtv | yes | | 13 | 2094 |
| satel | yes | | | 847 |
| serial | ~PR #8851~ | | 24 | 636 |
| snmp | yes | | 21 | 2979 |
| sonos | yes | | 7 | 668 |
| souliss | ~PR #11083~ | | 1 | 2729 |
| squeezebox | yes | | 8 | 4150 |
| squeezeserver | yes | | 0 | 1168 | Supported by squeezebox
| systeminfo | yes | | | 393 |
| tacmi | ~PR #7768~ | | 1 | 469 |
| tellstick | yes | | | 776 |
| tivo | ~PR #9302~ | | 1 | 120 | |
| upb | ~PR #6742~ | | 0 | 744 |
| urtsi | yes | | | 1658 |
| vdr | ~PR #9947~ | | 1 | 620 | Issue #9931
| velux | ~PR #2531~ | |9 | 8494 |
| wemo | yes | | 4 | 480 |
| wol | ~PR #8336~ | | 42 | 147 | Part of network binding |
| xbmc | yes | | 11 | 1998 | Replaced by Kodi Binding |
| yamahareceiver | yes | | 5 | 577 |
| zwave | yes | | | 18948 |
| multimedia.tts.googletts | yes | | 3 | 229 |
| multimedia.tts.macintalk | yes | | 0 | 35 |
| multimedia.tts.marytts | yes | | 2 | 70 |
| transport.mqtt | yes | | 46 | 604 |
| **Other** |=====| =====| =====| =====| =====|
| expire | ~PR openhab/openhab-core/pull/1803~ | | 95 | 239 | Added as core framework feature |
kaloschke
(Kaloschke)
November 16, 2020, 11:38am
3
Thank you very much for this information.
Using that binding, Items in OH2 become channels on the OH2 Bridge in OH3. you can then link OH3 Items to those channels.
rlkoshak
(Rich Koshak)
November 16, 2020, 4:39pm
5
OpenWeatherMap does not require a subscription or paying…yet. There is a binding for OWM that works in OH 3.
maihacke
(Simon Spielmann)
January 21, 2021, 4:45pm
6
Sadly, that’s not true. You have to own a device to use the OWM API. So with OH3 there is no way of using “adequate” weather data without having a weather device or paying a subscription.
Not at all. I don’t have any hardware wheater device and I’m using OWN for years. Never had to pay for the api key. Und with the new OneCall API it is really easy to have daily forecast w/o using a mess of virtual items and rules
rlkoshak
(Rich Koshak)
January 21, 2021, 5:06pm
8
maihacke:
From their own website: Weather API - OpenWeatherMap
Please sign up and use our fast and easy-to-work weather APIs for free.
maihacke
(Simon Spielmann)
January 21, 2021, 5:41pm
9
Yes, but if you sign in they tell you that you need to have a device to generate an API key…
rlkoshak
(Rich Koshak)
January 21, 2021, 5:55pm
10
I’ve had a key for years and maybe I’m grandfathered in but there is absolutely nothing on their page, their FAQ, or the pages I see once I log in that indicates a device is required. Maybe you are accidentally trying to create a key for one of their paid end points or something. Posting a screen shot might be informative. Because what I’m seeing:
From Frequently Asked Questions - OpenWeatherMap
No mention of needing a device.
From my API Keys page:
The plan I’m signed up for:
From the plan pricing page:
Explore OpenWeather's flexible subscription plans for real-time, forecast, and historical weather data.
Discover our range of services including One Call API 3.0, professional collections, special products like Road Risk and
Solar Irradiance APIs,...
No mention of requiring a device.
I can’t see what you are seeing but if they have changed to require a device then they have not applied that to users who already have a key and they’ve failed to update their own website.
NOTE: Weather Underground used to be free but moved to a paid only model unless you have a weather station. Maybe you are looking at the wrong service?
maihacke
(Simon Spielmann)
January 21, 2021, 6:16pm
11
Silly, I mixed up WeatherUnderground and OWM - sorry for the confusion. WU was my favourite provider until they changed their policy.
Regarding OWM, OH doc says:
Attention : The daily forecast is only available for paid accounts (opens new window) .
I remember, said I once experimented with OWM, and this part made it useless for me. But I could exactly remember, how this limited affected my usecase.
rlkoshak
(Rich Koshak)
January 21, 2021, 6:25pm
12
I’m pretty sure the new OneCall API now supports daily forecasts. I never used them so don’t know. The Channel list seems to indicate that it’s supported.
There were some Python libraries released that would aggregate the hourly forecasts into a daily one but I don’t think that’s required any more. I don’t see that “Attention” warning on the pricing page any more either.
I just used that API in a Javascript course with no device. In fact, here is a code example proving the point (not mine).
maihacke
(Simon Spielmann)
January 21, 2021, 6:29pm
14
Maybe then it is just that the OH docs are a bit outdated. I will go for the OWM binding then. Thanks.
Yes, i can confirm that those are working.
One thing that puzzled me, as long as you only have the OWM account thing configured it stays offline until you add another things (that should popup in the inbox)
I can’t show you examples since i’m rebuilding my semantic model and the weather is the last thing to do
rlkoshak
(Rich Koshak)
January 21, 2021, 6:30pm
16
If you would file an issue on the binding that would be great. The OneCall API is a pretty recent addition to the binding. The docs probably just were not updated.
jstro
(John Strong)
April 24, 2021, 3:43pm
18
Sascha, thanks for mentioning that. I could not get OWM to go online and so I gave up on it and removed it. Then I read your mention here that you have to add other things first before it goes online. This crucial bit of info should go in the binding documentation.
paglatz
(Patrick)
October 25, 2021, 10:39pm
19
Hi guys,
i just wanted to know if there is any progress on the integration of the weather binding into OH3. The poll topic had quite a few polls for weather binding and also the table in github mentions, that it might be migrated.
I really love my weather html view and especially it perfectly integrates into openHAB iOS app.
Thanks about any information.
hmerk
(Hans-Jörg Merk)
October 25, 2021, 11:04pm
20
AFAIK, nobody volunteered to bring this binding to openHAB 3 and there are no plans to do so.
