I thought that I need 2.5.6 on openhabian.
How do I install the 2.5.6 for amazon binding? Is there are link to “steps to install”? I am not so familiar on that area
Did anyone else see that when removing / adding the included non working binding it also disconnected / reconnected their z-wave network?
After around 12 hours openhab was also completely inaccessible, however my system (a qnap nas) was not affected
Temp jar has fixed the issue, now just got to remember to remove it and add from the ui when it gets merged
First you have to get rid of the 2.5.0 version that you have. Look in your addons.cfg for that jar
EDIt - sorry, look in your /addons folder for that jar
LastVoiceCommand appears to have stopped working again as of this morning. Anyone else having this issue?
Edit: I should add that I’m running the latest Openhabian 2.5.6-2 on RPi4Nd have the AmazonEcho binding 2.5.6-SNAPSHOT binding linked above installed. Before the fix I had the websocket error but since then everything has been working fine until today.
Thanks for the suggestion. I have checked my login status at openhab:8080/amazonechocontrol/
and also disabled and re-linked the openHAB skill in the Alexa app - still no joy
Good to know this isn’t happening on other setups so I can investigate further into mine.
Right, I’ve discovered the problem, and it’s a weird one! On my set up, I rely quite heavily on LastVoiceCommand (LVC) to trigger certain events. I
also expose dummy switches to Alexa so that she doesn’t say “I can’t find a device called…”.
What seems to have happened is that Amazon have changed the procedure for reporting on the LVC channel. It now seems to only reports commands which are not linked to a switch being triggered. For example saying, “Alexa, volume up”, or “Alexa, play music”, or “Alexa, what’s the weather like today” (and most other sentences) show up under LVM. But if you say, “Alexa, turn the lights on”, it doesn’t! This breaks a lot of rules I’ve created
Has anyone else noticed the change? As I said above, this occurred overnight and I discovered the problem yesterday morning.
I didn’t use LVC up to now, but upgrading to 2.5.7 might be a solution for you. @J-N-K and @Trinitus01 have been working on it, @richaardvark did a lot of testing. Searching for “last voice” and looking at the latest results should help. There is more than one thread, where LVC has been dicussed.
Thanks @yab or the reference. I hadn’t seen that thread until now. I’ve read it through and updated to 2.5.7. Ironically, I’m not getting any errors after updating java and openHAB, but this particular issue persists.
After a few more tests it seems to be very specific; my echo devices do not report LastVoiceCommand if the command relates to any potential smartphone devices, even if they don’t exist in your system. For example, previously I was testing lights, lamps etc. (which are present in my system) but the same thing happens when I ask alexa to “open the blinds” (which are not in my system). This does not get reported at all.
I’m starting to think that this is a security-focused update to the binding or potentially on the alexa server. Perhaps I need to start a new thread or post on the one you linked to.
Can anyone else verify that the same issue is happening on their setup? To reiterate, most commands are reported by LVC, but not if they relate to smart home devices.
Edit: This appears to be another issue, not related to the websocket error. Thread started here.
