I have a weird behavior I can’t explain Got the same famous Web Socket error a while ago. Found this thread, dropped .jar in addons and all was good.
But since the last restart (trying to make ipcamera binding work), the log is full of it again
Checked the version - looks legit (and also tried stoping openhab, remove jar, clearing cache, starting openhab - verifying PaperUI does not show it installed - and putting jar in addons). I’m on openHAB 2.5.0 Release Build atm - if it changes anything.
openhab> bundle:list | grep mazon
291 x Active x 80 x 2.5.6.202008310258 x openHAB Add-ons :: Bundles :: Amazon Echo Control Binding
But the log goes like this. Any ideas appreciated on what I could have done wrong or how to debug. Thank You so much!
UPDATE: I left it like that last night…checking the logs in the morning - have these errors for about an hour, then they disappear. Fine with that for time being; still wondering what to do/if it comes back.
UPDATE2: did another restarte and the error was there, again. I decided it’s time for update:) Cleared cache, upgraded openhab to 2.5.9, installed amazonecho from PaperUI, so far so good. Must have been something wrong at my side
2020-09-05 23:57:15.018 [INFO ] [control.internal.WebSocketConnection] - Web Socket error
java.nio.channels.AsynchronousCloseException: null
at org.eclipse.jetty.client.http.HttpConnectionOverHTTP.close(HttpConnectionOverHTTP.java:181) ~[?:?]
at java.util.ArrayList.forEach(ArrayList.java:1257) [?:1.8.0_222]
at org.eclipse.jetty.client.AbstractConnectionPool.close(AbstractConnectionPool.java:208) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.client.DuplexConnectionPool.close(DuplexConnectionPool.java:237) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.client.HttpDestination.close(HttpDestination.java:385) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.client.HttpClient.doStop(HttpClient.java:260) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.component.AbstractLifeCycle.stop(AbstractLifeCycle.java:93) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.component.ContainerLifeCycle.stop(ContainerLifeCycle.java:180) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.component.ContainerLifeCycle.doStop(ContainerLifeCycle.java:201) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.websocket.client.WebSocketClient.doStop(WebSocketClient.java:371) [bundleFile:9.4.20.v20190813]
at org.openhab.binding.amazonechocontrol.internal.WebSocketConnection.close(WebSocketConnection.java:159) [bundleFile:?]
at org.openhab.binding.amazonechocontrol.internal.WebSocketConnection$2.run(WebSocketConnection.java:184) [bundleFile:?]
at java.util.TimerThread.mainLoop(Timer.java:555) [?:1.8.0_222]
at java.util.TimerThread.run(Timer.java:505) [?:1.8.0_222]
2020-09-05 23:58:25.431 [INFO ] [control.internal.WebSocketConnection] - Web Socket error
