Made me think of this.
Wow!!!
(Donāt show my wife, I donāt think her eyes can roll back any further)
With a DMX to Servo controller, that would be so easy to make with SPi LEDs and the DMX binding
Today i finished up my input rack for openhab ( i prefer hard wired door/motion sensors where possible) i bought a few omron plc input modules and a corresponding backplane and reverse engineered the pins of the backplane to allow me to pull in channel status into a arduino nano which uses serial link to python, then python to mqtt ( might try and use serial binding at some point)
Hereās another hour or so of my time, trying to get my head around the rules a bit more.
Sadly I donāt think Iām going to be winning an awards any time soon.
I once āWonā the award of āMost Improved Dancerā at a training session, but I suspect that was because I started from a VERY VERY VERY low point.
Anyway, the mission today was to harvest the core facts from a BBC Weather RSS feed and turn it into something short that can scroll across a Velbus Glass Panel.
Iāve put the rule and other useful information here :- [SOLVED] BBC weather RSS Latest Title split to <64 characters for Velbus OLED (AKA Splitting Strings)
FYI
If you want to learn about how to split strings and use the different parts, please do read all of the posted topic, @rlkoshak takes great care and goes into the fine detail of how splitting strings works.
I really feel Iāve learnt a lot from this experience.
nice, what are you flashing the with for use with openhab
I flashed them with Tasmota firmware so I can control them via MQTT / openHAB.
Not today, but this week.
Pushover recently added support for animated GIFs, so I altered my front door notifications to include short clips.
Converted GIF sample:
notification sample (animated on phone):
While I was at it, I created a custom landing page to get a live view and control the front door lock:
Cross-posting writeup from here: Blue Iris integration- HTTP binding, REST api - #22 by roy_liao
In the theme of cameras, I flashed hacked firmware on Xiaomi Dafang to replace my raspbery wifi cam based on motioneyeos (xiaomi is cheaper and seems easier to use, also prettier and have a better IR capabilities plus option to remove IR filter on demand. And of course the best thing for automation, it has MQTT status and commands.
So while testing it as a replacement I made a slow cooker observatory, so that I can turn off the slow cooker if meet looks done, while we are on the move. Took 5min to set all up, and 15min to take photo and write this down
And the results of automation. Salt, pepper, not a single drop of water and after 3.5h on high (+1h cooldown) you get the tender and delicious beef cooked in its own juices.
And best of all, it is all automated, one timer rule and no interaction needed.
maybe this is a binding for you instead of using the serial binding: SimpleBinary Binding Ā· openhab/openhab1-addons Wiki Ā· GitHub. Every item is supported and you do not need any conversion rule or
REGEX expression. It works quite well on openHAB2 too!
No pics, because its ājust codeā, but i have started switching over to jsr223 rules and moved some of my multimedia and light scenes over to javascript files.
The learning curve is a bit flat, but the rules seem to run already smoother, even if i have to save them several times while improving them.
So my first impressions are, that it will be worth the effort and that it isnāt that complicated after you have made the first progress.
And it will put you in a better position for future versions of OH. I need to do the same but havenāt had a chance to take the plunge yet. Are you using Lewieās library? What made you decide to use JavaScript?
I bet a quick lessons learned/this is my experience moving over post would be very much appreciated, if not a full tutorial.
How so?
Live got something in mind already and hopefully have some spare time for this.
Javascript:
I am digging into vue currently, i am doing web development with php and js for private usage for a longer time.
I love brackets^^
I am using an adpted version of lewies library currently.
I have added the timer and trigger part and removed all stuff that is erroring currently.
The smooth is aiming especially for the startup part of openHAB and while developing.
When i am changing rules dsl files they mostly have some delay after saving them.
Also there is a bug that fires the startup rules every time a rules file changes, which also causes some laod and delay.
With the js rules i can adapt the rule, save it and it gets refreshed immediately.
So smooth for me, means the progress/process during development.
Exactly what I was looking for Indeed, I keep the files small and keep the start-up rules in mytask.startup.rules file while the code sits in the mytask.rules file.
Depending on the contents of the file and how many of the āprimative issueā exists in the file, some rules are near instant and some take an while to kick in.
Iāll take the plunge and start new features in new rules.
What did I automate / build today? Nothing with pictures but added functionality;
Came home a few days ago to find out SWAMBO had left and left the iron on. It was there, ticking away on the board. With dogs in the house this could have lead to a disaster.
Seeing as I have full scene control based on presence and time of day (Day-Home, Day-Away, Night-Home, Night-Away) and I also monitor and log many of the electrical circuits in the house I thought I could protect against this.
To do this with ML would be cooler butā¦
When a scene changes to one of the away scenes OH starts a timer, waits for 5 minutes and gets the average power consumed for the last 5 minutes.
This is then compared to the last 7-day average for the same scene..
If the 5-minute average is more than 10% higher than the 7-day average then it sends me an alert (email).
Iām still testing the numbers to see for false alarms etc but the grounding is good.
Once the framework is working I could conceivably even shut down circuits to try and protect things.
While I enjoy the flexibility this gives me I am wanting to move away from rigid rules like this and more into using ML to do anomoly detection with various feeds. But thatās a way aways yet
This is fascinating.
Iād love to understand how you do this, but as my mind is happier with wires and cables, I fear itās way beyond my abilities, but fascinating none the less.
Good luck
Iāll post the code bits up at some point. Actually very straight forward. The āwires and cablesā are the fun part. Iām wanting to put CTs on to each circuit to monitor everything
Now thatās something I do know about
This Velbus input device can support 4 x 20ma CT coils.
https://www.velbus.eu/products/view?id=437464
https://www.velbus.eu/images/products/0/vmb4an.jpg
Iāve currently got it on test with these coils, and a few other sensors.
http://www.ebay.co.uk/ulk/itm/332675409469
This Velbus module isnāt currently supported in the publicly available openHAB2 binding, but there is a development version that does
This is a xiaofang camera not Dafang, am I right? Which hack did you used which has MQTT support?
