Try querying the Thing definition through the REST API. That is how the UI added and accesses the Thing.
Here is the (redacted) response to querying my example, above.
"statusInfo": {
"status": "ONLINE",
"statusDetail": "NONE"
"editable": true,
"label": "Christmas Tree Plug",
"bridgeUID": "zwave:serial_zstick:[NetworkId]",
"configuration": {
"config_20_1": 1,
"config_21_1": 0,
"binding_cmdrepollperiod": 1500,
"action_failed": false,
"group_1": [
"controller"
"action_remove": false,
"binding_pollperiod": 86400,
"config_173_4": 300,
"config_172_4": 300,
"action_heal": false,
"switchall_mode": 255,
"config_174_4": 300,
"action_reinit": false,
"config_171_4": 30,
"config_151_2": 50,
"config_152_1": 10,
"config_27_1": 1,
"config_24_1": 1,
"node_id": 18
"properties": {
"zwave_class_basic": "BASIC_TYPE_ROUTING_SLAVE",
"zwave_class_generic": "GENERIC_TYPE_SWITCH_BINARY",
"zwave_frequent": "false",
"zwave_neighbours": "1,4,5,11,15",
"modelId": "ZEN15",
"zwave_version": "1.4",
"zwave_listening": "true",
"zwave_plus_devicetype": "NODE_TYPE_ZWAVEPLUS_NODE",
"manufacturerId": "027A",
"manufacturerRef": "0101:000D",
"dbReference": "758",
"zwave_deviceid": "13",
"zwave_nodeid": "18",
"zwave_lastheal": "2020-01-09T07:48:59Z",
"vendor": "Zooz",
"defaultAssociations": "1",
"zwave_routing": "true",
"zwave_plus_roletype": "ROLE_TYPE_SLAVE_ALWAYS_ON",
"zwave_beaming": "true",
"zwave_secure": "false",
"zwave_class_specific": "SPECIFIC_TYPE_POWER_SWITCH_BINARY",
"zwave_manufacturer": "634",
"zwave_devicetype": "257"
"UID": "zwave:device:[NetworkId]:node18",
"thingTypeUID": "zwave:zooz_zen15_00_000",
"channels": [
"linkedItems": [
"tree_plug"
"uid": "zwave:device:[NetworkId]:node18:switch_binary",
"id": "switch_binary",
"channelTypeUID": "zwave:switch_binary",
"itemType": "Switch",
"kind": "STATE",
"label": "Switch",
"description": "Switch the power on and off",
"defaultTags": [],
"properties": {
"binding:*:OnOffType": "COMMAND_CLASS_SWITCH_BINARY,COMMAND_CLASS_BASIC"
"configuration": {}
"linkedItems": [],
"uid": "zwave:device:[NetworkId]:node18:scene_number",
"id": "scene_number",
"channelTypeUID": "zwave:scene_number",
"itemType": "Number",
"kind": "STATE",
"label": "Scene Number",
"description": "Triggers when a scene button is pressed",
"defaultTags": [],
"properties": {
"binding:*:DecimalType": "COMMAND_CLASS_SCENE_ACTIVATION"
"configuration": {}
"linkedItems": [],
"uid": "zwave:device:[NetworkId]:node18:meter_voltage",
"id": "meter_voltage",
"channelTypeUID": "zwave:meter_voltage",
"kind": "STATE",
"label": "Electric meter (volts)",
"description": "Indicates the instantaneous voltage",
"defaultTags": [],
"properties": {
"binding:*:DecimalType": "COMMAND_CLASS_METER;type=E_V"
"configuration": {}
"linkedItems": [],
"uid": "zwave:device:[NetworkId]:node18:meter_current",
"id": "meter_current",
"channelTypeUID": "zwave:meter_current",
"kind": "STATE",
"label": "Electric meter (amps)",
"description": "Indicates the instantaneous current consumption",
"defaultTags": [],
"properties": {
"binding:*:DecimalType": "COMMAND_CLASS_METER;type=E_A"
"configuration": {}
"linkedItems": [],
"uid": "zwave:device:[NetworkId]:node18:meter_kwh",
"id": "meter_kwh",
"channelTypeUID": "zwave:meter_kwh",
"kind": "STATE",
"label": "Electric meter (kWh)",
"description": "Indicates the energy consumption (kWh)",
"defaultTags": [],
"properties": {
"binding:*:DecimalType": "COMMAND_CLASS_METER;type=E_KWh"
"configuration": {}
"linkedItems": [],
"uid": "zwave:device:[NetworkId]:node18:meter_watts",
"id": "meter_watts",
"channelTypeUID": "zwave:meter_watts",
"kind": "STATE",
"label": "Electric meter (watts)",
"description": "Indicates the instantaneous power consumption",
"defaultTags": [],
"properties": {
"binding:*:DecimalType": "COMMAND_CLASS_METER;type=E_W"
"configuration": {}
"linkedItems": [],
"uid": "zwave:device:[NetworkId]:node18:meter_reset",
"id": "meter_reset",
"channelTypeUID": "zwave:meter_reset",
"kind": "STATE",
"label": "Reset Meter",
"description": "Reset the meter",
"defaultTags": [],
"properties": {
"binding:*:OnOffType": "COMMAND_CLASS_METER"
"configuration": {}
I would guess quickly the Thing might look like
Thing "Christmas Tree Plug" zwave:device:[NetworkId]:node18 or similar
