I have a few rules in which I check if my rollershutters are closed or if it is after sunset.
Since today I run with openHAB 2.4 and try to solve all the warnings as I have a few rules which do not get fired anymore (since the upgrade) and I a don’t know yet why.
Here is such an example rule:
rule "Motion Podest"
Item Bewegung_EG_Treppe_Podest received command
//logInfo("Motion Rule", " Es wurde Bewegung hier erkannt ")
if(receivedCommand==ON) {
// motion detected
// if
// -> Rollladen_Flure.state==100 (means rollershutter is down)
// or
// -> after sunset
// then
// turn on light
if ((Rollladen_Flure.state==100) || (now.isAfter((Sunset_Time.state as DateTimeType).calendar.timeInMillis)) ) {
sendCommand(Licht_OG_Flur_LED_Podest, ON)
} else if(receivedCommand==OFF) {
// for now do nothing here ...
This now gives me this warning when saving the file:
“The method getCalendar() from the type DateTimeType is deprecated”
… plus this rule does not get fired anymore
I did check the item itself and can see that it “turns ON” in openHAB when there is motion.
But first I would like to get rid of the deprecated warning as there must be a better way to do this.
I hope that once I have fixed those warnings the file does not produce this warning anymore “Validation issues found in configuration model ‘motion_sensor.rules’, using it anyway” which also irritates me as it does not clearly say what went wrong and if those rules will be ignored or still used.
Thanks for helping.
@Bruce_Osborne - how you know I did not search? I have like 20 tabs open in my browser and did not just read the post you forwarded but also others posts.
I might be to dumb to follow that post & somehow have the feeling it did not really answer the question. This is why I was posting my question.
This other thread ended in October 2018.
Instead of pointing me to that thread which I already read before it would have been more helpful to
a) give me a hint how to solve the “after sunset” problem more intelligent
or
b) rewrite my problematic “getCalendar” statement with what the solution might be.
I appreciate any help.
I’ll re-read that mentioned post again and see if that really is a elegant solution.
[Sorry if that post sounds a little harsh .. I am just a little frustrated as every time I do an update of OH .. I have to fix things as something essential always brakes. I really like OH … still it is hard to do updates.]
Well then it might sometimes be better to not reply to an post you feel in not necessary than to frustrate people.
As said before i appreciate the hard work of the community and I fully understand that not all is working flawlessly but still it should be allowed to ask a question or ask for help when there seems to be no solution.
So next time I will add links to the post that I have read and feel they did not help to solve my problem.
