Trying to get some brightness problem resolved with my Zipato RGBW lamp. It seems to be resolved according this thread
I tried to update my zwave binding in karaf
bundle:stop
bundle:uninstall org.openhab.binding.zwave
bundle:install https://openhab.ci.cloudbees.com/job/openHAB2-Bundles/lastBuild/artifact/bindings/org.openhab.binding.zwave/target/org.openhab.binding.zwave-2.0.0-SNAPSHOT.jar
bundle:start
and when I do a list, I see:
200 | Installed | 80 | 2.0.0.201612272212 | ZWave Binding
However:
- When I use the Basic UI web interface it the brightness is still low and I can’t get it to full brightness (I have a reference lamp still running on OH1 which is much brighter).
- When I try to change the items on the lamp java errors are all over the place and it shows binding-wave:2.0.0.b4 (see snippet blow).
- When I look in the Paper UI, I see binding-wave-2.0.0.4b.
21:40:34.118 [ERROR] [ve.internal.protocol.ZWaveController] - Exception during ZWave thread: Input 2. {}
java.lang.NullPointerException
at org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveColorCommandClass.processColorReport(ZWaveColorCommandClass.java:182)[191:org.openhab.binding.zwave:2.0.0.b4]
at org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveColorCommandClass.handleApplicationCommandRequest(ZWaveColorCommandClass.java:104)[191:org.openhab.binding.zwave:2.0.0.b4]
at org.openhab.binding.zwave.internal.protocol.serialmessage.ApplicationCommandMessageClass.handleRequest(ApplicationCommandMessageClass.java:119)[191:org.openhab.binding.zwave:2.0.0.b4]
at org.openhab.binding.zwave.internal.protocol.ZWaveController.handleIncomingRequestMessage(ZWaveController.java:242)[191:org.openhab.binding.zwave:2.0.0.b4]
at org.openhab.binding.zwave.internal.protocol.ZWaveController.handleIncomingMessage(ZWaveController.java:208)[191:org.openhab.binding.zwave:2.0.0.b4]
at org.openhab.binding.zwave.internal.protocol.ZWaveController.access$7(ZWaveController.java:202)[191:org.openhab.binding.zwave:2.0.0.b4]
at org.openhab.binding.zwave.internal.protocol.ZWaveController$ZWaveInputThread.run(ZWaveController.java:1298)[191:org.openhab.binding.zwave:2.0.0.b4]
I hope the answers to the following questions can help me further:
- what version of the binding am I running?
- where are the files for the different UI’s located? I can update them manually.
- what is the best way to update the packages.
Other things I tried that failed:
- The solution in this thread. It resulted in ‘no sitemap found’ or ‘file not found’ in all available UI’s
- Put the latest jar file in the addons directory. Had no result whatsoever.
