Hi, I’m currently struggling building custom widgets.
There is some nice gauge widgets I found in the community.
when I try to mach what I’ see in the code with the documentation I found that most of the configuration properties are not documented.
so… how do other find these attribute and how to use them?
Thanks Ernst
uid: widget_gauge
tags: []
props:
parameters:
- context: item
description: The current value
label: Item
required: true
type: TEXT
- context: item
description: The target value
label: Target
required: false
type: TEXT
- context: item
description: The min range
label: MinItem
required: false
type: TEXT
- context: item
description: The max range
label: MaxItem
required: false
type: TEXT
- context: number
description: The min value
label: Min
required: false
type: TEXT
- context: number
description: The max value
label: Max
required: false
type: TEXT
- context: string
description: The name
label: Name
required: false
type: TEXT
- context: number
description: The height of widget
label: Height
required: false
type: TEXT
parameterGroups: []
timestamp: Oct 8, 2022, 6:19:35 PM
component: oh-chart
height: =props.height
slots:
series:
- component: oh-data-series
anchor:
itemStyle:
color: "#000"
show: true
axisLabel:
show: false
axisLine:
lineStyle:
color:
- - 1
- "#fff"
shadowBlur: 10
shadowColor: rgba(0, 0, 0, 0.5)
width: 10
axisTick:
show: false
endAngle: -270
pointer:
show: false
radius: 92%
splitLine:
show: false
startAngle: 90
title:
show: false
type: gauge
axisLabel:
show: false
axisLine:
show: false
axisTick:
show: false
data:
- name: =props.name
value: =Number.parseFloat(items[props.target].state)
detail:
show: false
max: =props.max || 100
min: =props.min || 0
pointer:
length: 80%
show: =items[props.target].state !== "-"
radius: 82%
splitLine:
show: false
splitNumber: 6
title:
offsetCenter:
- 0
- -35%
type: gauge
anchor:
itemStyle:
borderColor: "#000"
borderWidth: 2
show: true
axisLabel:
distance: 18
fontSize: 18
axisLine:
lineStyle:
color:
- - =(Number.parseFloat(items[props.minItem].state) - props.min)/(props.max - props.min)
- "#58D9F9"
- - =(Number.parseFloat(items[props.maxItem].state) - props.min)/(props.max - props.min)
- "#7CFFB2"
- - 1
- "#FF6E76"
width: 10
axisTick:
distance: -10
length: 10
data:
- name: =props.name
value: =Number.parseFloat(items[props.item].state)
detail:
fontSize: 18
formatter: ="{value}" + "\n" + items[props.item].state.split(" ")[1]
offsetCenter:
- 0
- 45%
valueAnimation: true
pointer:
icon: path://M2090.36389,615.30999 L2090.36389,615.30999 C2091.48372,615.30999 2092.40383,616.194028 2092.44859,617.312956 L2096.90698,728.755929 C2097.05155,732.369577 2094.2393,735.416212 2090.62566,735.56078 C2090.53845,735.564269 2090.45117,735.566014 2090.36389,735.566014 L2090.36389,735.566014 C2086.74736,735.566014 2083.81557,732.63423 2083.81557,729.017692 C2083.81557,728.930412 2083.81732,728.84314 2083.82081,728.755929 L2088.2792,617.312956 C2088.32396,616.194028 2089.24407,615.30999 2090.36389,615.30999 Z
itemStyle:
color: "#f00"
length: 100%
offsetCenter:
- 0
- 10%
radius: 82%
splitLine:
distance: -10
length: 20
splitNumber: 6
title:
offsetCenter:
- 0
- -35%
type: gauge
