Wifi LED Binding using Magic Home
I connected my MAgic Home device for controlling the RGBWW LED strip by the following method I learned from th eOpenHab community and it is as follos:
1.emphasized text_Power up the LED Strip
2. open PAPER UI and install the WIFI LED Binding
3. in PaperUI inside THINGS should be something like “AK001-ZJ100” (WiFi LED Device) with corresponding MAC-Adress
4. click on it and u see something like: “wifiled:wifiled:A020A61D34BD:power”
The problem I’m facing is I can control the power of the LED strip via OpenHAB, but I can’t change the color of the LED Strip and brightness of the White LED. I can control it over the Magic Home Pro App.
My items file is as follows
//RGB Light
Switch MyWiFiLight_power "Power-LED" (Light) {channel="wifiled:wifiled:600194955766:power"}
Dimmer MyWiFiLight_white "White-LED" (Light) {channel="wifiled:wifiled:600194955766:white"}
Color  MyWiFiLight_color "Color-LED" (Light) {channel="wifiled:wifiled:600194955766:color"}
My Sitemap file:
Colorpicker item=MyWiFiLight_color
Switch item=MyWiFiLight_power
Slider item=MyWiFiLight_white
could you tell us, what controller your are using ? do you know the exact LD… Number of it ?
try changing the device to another LD-Device in PaperUI and see if this works
PaperUI -> Configuration -> Things -> Edit -> RGB Strip Controller - SHOW MORE -> Protocoll -> LD .....
Thank you so much… LDA no. was the problem…
could you please help me how to change the color via “Alexa” …?
I tried adding “Switchable” command as follows in the items file but color changing is not working
Switch MyWiFiLight_power "Color Light" (Light) [ "Switchable" ] {channel="wifiled:wifiled:600194955766:power"}
Dimmer MyWiFiLight_white "Warm Light" (Light) [ "Switchable" ] {channel="wifiled:wifiled:600194955766:white"}
Color  MyWiFiLight_color "Color" (Light) [ "Switchable" ] {channel="wifiled:wifiled:600194955766:color"}
is only for HOMEKIT / Siri - this is not for Alexa
i say “alexa turn desk led to red” and it works
check if your alexa already knows your device ( alexa app on phone → smart home ) there you see the name of the device and you can change it, if you like to
notice: you need the “magic home skill” for alexa installed to find and change it
then it should work
I try to change other LD device , but only power on/off work in LD382A but White & white2 cannot work …
did you managed to work? I have the same isuue - On Off is working nothing else!
have you a resolution yet?
I found a resoltution.
Try to map the color thing/item und use the Brightness there.
Yours
Bernhard
