Worx Landroid Binding
Hi there,
I also have the error
2022-05-04 18:56:44.390 [ERROR] [ternal.webapi.WorxLandroidWebApiImpl] - Error connecting to Worx Landroid WebApi! Error = Error calling Worx Landroid WebApi! HTTP Status = 403
2022-05-04 18:56:44.425 [ERROR] [id.internal.WorxLandroidMowerHandler] - RefreshStatusRunnable 202130267xxxxxxxxxxxxxx: Unknown error
org.openhab.binding.worxlandroid.internal.webapi.WebApiException: Error calling Worx Landroid WebApi! HTTP Status = 403
	at org.openhab.binding.worxlandroid.internal.webapi.request.WebApiRequest.callWebApi(WebApiRequest.java:115) ~[bundleFile:?]
	at org.openhab.binding.worxlandroid.internal.webapi.request.WebApiRequest.callWebApiGet(WebApiRequest.java:79) ~[bundleFile:?]
	at org.openhab.binding.worxlandroid.internal.webapi.request.ProductItemsRequest.call(ProductItemsRequest.java:46) ~[bundleFile:?]
	at org.openhab.binding.worxlandroid.internal.webapi.WorxLandroidWebApiImpl.retrieveUserDevices(WorxLandroidWebApiImpl.java:101) ~[bundleFile:?]
	at org.openhab.binding.worxlandroid.internal.WorxLandroidMowerHandler$1.run(WorxLandroidMowerHandler.java:112) [bundleFile:?]
	at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:305) [?:?]
	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:305) [?:?]
Hej,
just started using this binding and am impressed that it is working really good. Thanks a lot!
Just one question: resetting the blade time (in the app) isn’t reflected in the binding. I have seen this question in other homeautomation integration too, but I can’t find how to fix this for OH.
Does anyone have a suggestion for me?
bests, Sven
Problems since Firmware 3.26
SInce that update i allways get the message that Worx blocks me and i should wait 24 h .
I am using Oh 2.5 and test 3.2 but same Problem on both systems.
Same here, also with 3.26 firmware on Landroid WR141E. I am using OH 3.1.1, tried the v3.1-beta of the addon and also the last final v3.0
Same behaviour, always the error that I should wait 24h
I had the same issue and it turned out that the two values in the bridge just need to be altered to produce less calls to the Worx API.
I set them to: refreshStatusInterval=3600, pollingInterval=3600 and since then I was never blocked again.
This doesn’t mean that the telemetry data is only updated after an hour. The data is still pushed to the binding.
Just to share an info from my side: I also had the situation that I was blocked by Worx. For me it was due to a dumb error in one of my rules that in the end caused a lot of requests to my Landroid. Somehow ā€œmy blockā€ was not removed even after a week.
What did the trick for me was to remove my Landroid from my Account and to just add it again (to the same Worx Account). It worked immediatedly and I even did not loose my 3 years warranty!
I kindly wanted to ask whether this binding is still under development.
It’s working great so far (except for the ā€œRefreshStatusRunnableā€ Errors I get frequently).
I found out about an API extension regarding live torque settings for the mower since firmware version 3.26.
Will this be implemented in a future release?
Hello Nibi,
thank you for your great work. The binding worked straight away from the excellent examples and made my Landroid 167E settings/adjustments a breeze.
I ignore the regular messages in the log (RefreshStatusRunnable: Unknown error) because there are no negative effects to be seen.
I am also interested in the question of whether it is possible to find out which areas the Landroid has processed in the current or last run, i.e. a grid of points in which the mown areas are recognizable. (You can see it even after a few weeks on the lawn itself, but if the interface could deliver the data… :slight_smile:
Best regards from the Black Forest, Germany
Mercur
I’m not sure, whether I’m alone with this problem, but starting yesterday (2022-09-26 22:55) I observe the following error message in my log every 5 minutes:
2022-09-26 22:55:51.361 [ERROR] [ternal.webapi.WorxLandroidWebApiImpl] - Error connecting to Worx Landroid WebApi! Error = Error calling Worx Landroid WebApi! HTTP Status = 404
2022-09-26 22:55:51.411 [ERROR] [id.internal.WorxLandroidMowerHandler] - RefreshStatusRunnable xxxxxxxxxxxxxxxxxxxx: Unknown error
org.openhab.binding.worxlandroid.internal.webapi.WebApiException: org.eclipse.jetty.client.HttpResponseException: HTTP protocol violation: Authentication challenge without WWW-Authenticate header
Except the message, updating the items worked the complete day.
To solve this issue, I just restarted openhab and now the binding does no longer work at all, now I only see the following messages in the log:
2022-09-27 19:02:43.039 [ERROR] [ternal.webapi.WorxLandroidWebApiImpl] - Error connecting to Worx Landroid WebApi! Error = Error calling Worx Landroid WebApi! HTTP Status = 404
2022-09-27 19:03:48.187 [ERROR] [id.internal.WorxLandroidMowerHandler] - handleCommand mower: Lawnie (201830190905000931FD) is offline!
I didn’t touch the configuration and the Android app and the Desktop-App work as expected with the (unchanged) credentials.
I can also login to Login - Worx with this credentials.
Any ideas, what’s going wrong here?
Greetings
Roland
No, same problem here.
Hi @RoRo @sihui
same on my side. Startet on 26.9. at 22:33.
Have allready opened a Issue on @nibi79 Repo : 404 from api.worxlandroid.com Ā· Issue #70 Ā· nibi79/worxlandroid Ā· GitHub
BR
mitch
hi all,
obviously worx has changed something on the login. Unfortunately I can not look at the problem at the moment, maybe next week..sorry
Any update yet? How can community incl. non-experts help you?
You can track the issue here:
https://github.com/nibi79/worxlandroid/issues/70
hi all,
here is a new beta version:
Your feedback is appreciated :smiley:
Quick check / feedback: Triggering cutting border via openhab seams to work, getting back status as well.
Looks like everything is working again. Thank you!
Now that you are working on the binding anyway, maybe you find some time for this… :stuck_out_tongue_winking_eye:
have you got a Version for openhab2 too ? last was 2.5.3-SNAPSHOT. thanks a lot!
sorry not at the moment →
https://github.com/nibi79/worxlandroid/issues/70#issuecomment-1268745227
I have again some issues. Anyone else?
[ERROR] [d.internal.WorxLandroidBridgeHandler] - Connection blocked from Worx, please try again in 24h
chris
