Hello Daniel,
Artikelnummer 3266
60 Euro + shipping (Switzerland 32 Euro)
Best regards
U. Drost
Hello Daniel,
Artikelnummer 3266
Best regards
U. Drost
Thank you!
Hello Daniel
I createt a pre-release of the plugin for OH3. I’m not testet it, because my setup at home still use OH2.5.
Best regards
Michael
Thanks for your great effort here.
I just ordered the serial adapter cable from the manufacturer.
Is it possible to switch Kühlfunktion on/off?
I don‘t know. I don‘t have an integrated heat pump.
Kind regards
Uwe Drost
I also don’t have an integrated heat pump, but the necessary channel exists. See channel ID “cooling_mode” under GitHub - frami/org.openhab.binding.wr3223 at feature/oh3-upgrade
my controller states “Status: unkown” in the Things-Section.
How can I determine if I really have a connection issue?
btw: my “Bedienteil” (Touch-Display) is connected to X1. So you cannot have both type of controllers: serial and X1?
I’m also trying to get this thing to work.
Have you tried to ssh into your open hab?
ssh -p 8101 openhab@YOUROPENHABIP
enter your password and type bundle:list
Check if the status of openHAB Add-ons :: Bundles :: WR3223 Binding
is Active
In my case a dependency / bundle was missing. I think it was openHAB Core :: Bundles :: Serial Transport
Yeah, I think it’s there although my terminal is cutting half of the info:
235 │ Active │ 80 │ 2.5.0 │ openHAB Core :: Bundles :: Seri
236 │ Active │ 80 │ 2.5.0 │ openHAB Core :: Bundles :: Seri
237 │ Active │ 80 │ 2.5.0 │ openHAB Core :: Bundles :: Seri
I’m using this cable and connected it like described
https://www.delock.de/produkte/G_83786/merkmale.html?setLanguage=en
But status says: Status: UNKNOWN
In openhab.log I can find
2021-08-31 20:46:17.487 [INFO ] [internal.controller.WR3223Controller] - Connected to WR3223 over serial port /dev/ttyUSB0.
but also
021-08-31 20:48:21.405 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
java.util.ConcurrentModificationException: null
at java.util.HashMap$KeySpliterator.forEachRemaining(HashMap.java:1561) ~[?:1.8.0_292]
at java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:482) ~[?:1.8.0_292]
at java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:472) ~[?:1.8.0_292]
at java.util.stream.ReduceOps$ReduceOp.evaluateSequential(ReduceOps.java:708) ~[?:1.8.0_292]
at java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234) ~[?:1.8.0_292]
at java.util.stream.ReferencePipeline.collect(ReferencePipeline.java:566) ~[?:1.8.0_292]
at org.eclipse.smarthome.io.transport.serial.internal.SerialPortRegistry.getPortProvidersForPortName(SerialPortRegistry.java:86) ~[?:?]
at org.eclipse.smarthome.io.transport.serial.internal.SerialPortManagerImpl.getIdentifier(SerialPortManagerImpl.java:85) ~[?:?]
at org.openhab.binding.wr3223.internal.client.SerialWR3223Connector.connect(SerialWR3223Connector.java:45) ~[?:?]
at org.openhab.binding.wr3223.internal.controller.WR3223Controller.initConnection(WR3223Controller.java:314) ~[?:?]
at org.openhab.binding.wr3223.internal.controller.WR3223Controller.run(WR3223Controller.java:136) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) ~[?:1.8.0_292]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) ~[?:1.8.0_292]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) ~[?:1.8.0_292]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) ~[?:1.8.0_292]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_292]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_292]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_292]
I’d appreciate any help on this. Thanks!
Hi
Based on the stack trace, I suspect that OpenHAB cannot access the USB adapter. The error happens, by opening the serial port. Have you checked, if the serial-to-usb adapter is really available at “/dev/ttyUSB0”? The user, which is used to run OpenHAB, has the permission to access the USB adapter?
# What is the result of this commands?
ls -l /dev/ttyUSB*
ls -l /sys/class/tty/ttyU*
# Which groups the OpenHAB user have?
groups <openhab user>
Does the OH3 binding work?
I‘haven‘t migrated yet my system.
Regards
Uwe
Hello Uwe
Yes, it works, but I doesn’t migrate it to the office repository. You can get it from here: https://github.com/frami/org.openhab.binding.wr3223/releases/tag/v3.0.1-alpha.2
Best regards,
Michael
Thank you Michael, it works very well indeed.
Kind regards
Uwe
Hi again,
I’m still using the DeLock adapter cable the guys suggested on OH 3.
Now I seem to have everything connected like expected but getting the following according to the logs:
2022-02-15 23:18:31.925 [INFO ] [internal.controller.WR3223Controller] - Connected to WR3223 over serial port /dev/ttyUSB0.
2022-02-15 23:18:33.953 [ERROR] [internal.controller.WR3223Controller] - Communication error to WR3223.
java.io.EOFException: null
at java.io.DataInputStream.readByte(DataInputStream.java:272) ~[?:?]
at org.openhab.binding.wr3223.internal.client.AbstractWR3223Connector.readAnswer(AbstractWR3223Connector.java:230) ~[bundleFile:?]
at org.openhab.binding.wr3223.internal.client.AbstractWR3223Connector.read(AbstractWR3223Connector.java:119) ~[bundleFile:?]
at org.openhab.binding.wr3223.internal.controller.WR3223Controller.checkIfCommandIsAvailable(WR3223Controller.java:336) ~[bundleFile:?]
at org.openhab.binding.wr3223.internal.controller.WR3223Controller.run(WR3223Controller.java:142) [bundleFile:?]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:305) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:305) [?:?]
W3223.cfg
serialPort=/dev/ttyUSB0
controllerAddr=1
refresh=15000
in a channel it is stating NULL
Any help appreciated. X1 is unplugged.
Are there any missing dependencies for the serial port to use?
Running on a RPi 4, 32 Bit
Nevermind!
Because I’ve got some experiencing with flashing esp chips, I tried switching RX and TX. Now it is working and values come through perfectly. Great!
Hello Michael,
will there be a OH4 version of this binding?
Hello Ralph
Is there an update of the binding for OH4 necessary? I hadn’t found time to delve into OH4 until now. But if there is an update of the Binding required, I will do it.
The binding ist not working in OH4
2023-08-13 20:00:12.430 [ERROR] [Events.Framework ] - FrameworkEvent ERROR
org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.wr3223 [312]
Unresolved requirement: Import-Package: org.openhab.core.io.transport.serial
at org.eclipse.osgi.container.Module.start(Module.java:463) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel$2.run(ModuleContainer.java:1847) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor$1$1.execute(EquinoxContainerAdaptor.java:136) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1840) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1783) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1745) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1667) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:345) ~[org.eclipse.osgi-3.18.0.jar:?]
2023-08-13 20:00:18.109 [WARN ] [org.apache.felix.fileinstall ] - Error while starting bundle: file:/usr/share/openhab/addons/org.openhab.binding.wr3223-3.0.1.jar
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:445) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundle(DirectoryWatcher.java:1260) ~[?:?]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundles(DirectoryWatcher.java:1233) ~[?:?]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startAllBundles(DirectoryWatcher.java:1221) ~[?:?]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.doProcess(DirectoryWatcher.java:515) ~[?:?]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.process(DirectoryWatcher.java:365) ~[?:?]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.run(DirectoryWatcher.java:316) ~[?:?]
Hi Ralph
It looks like that is a system OH Core Bundle “Serial Transport” missing. Can you try to install the “Serial Binding”? This is officially binding, and it also uses the “Serial Transport” Core Binding.
If this not work, try to connect to the OH console (The Console | openHAB) and check with the command “bundle:list” if the “Serial Transport” binding is installed. If not, you can try with the “bundle:install” command to install it.
Hi Michael,
its now working with the serial binding loaded. thanks
