Hello Michael and thanks for your reply.
Here is what the log states at the start of the plugin:
2020-12-23 11:14:57.860 [WARN ] [internal.controller.WR3223Controller] - Command Ta is not supported by the controller.
2020-12-23 11:14:57.963 [WARN ] [internal.controller.WR3223Controller] - Command Tf is not supported by the controller.
2020-12-23 11:14:59.178 [WARN ] [internal.controller.WR3223Controller] - Command T4 is not supported by the controller.
2020-12-23 11:14:59.433 [WARN ] [internal.controller.WR3223Controller] - Command T6 is not supported by the controller.
2020-12-23 11:14:59.725 [WARN ] [internal.controller.WR3223Controller] - Command T8 is not supported by the controller.
2020-12-23 11:15:00.754 [WARN ] [internal.controller.WR3223Controller] - Command SP is not supported by the controller.
2020-12-23 11:15:00.901 [WARN ] [internal.controller.WR3223Controller] - Command RA is not supported by the controller.
2020-12-23 11:15:01.048 [WARN ] [internal.controller.WR3223Controller] - Command D1 is not supported by the controller.
2020-12-23 11:15:01.232 [WARN ] [internal.controller.WR3223Controller] - Command D2 is not supported by the controller.
2020-12-23 11:15:01.342 [WARN ] [internal.controller.WR3223Controller] - Command D3 is not supported by the controller.
2020-12-23 11:15:01.932 [WARN ] [internal.controller.WR3223Controller] - Command LR is not supported by the controller.
2020-12-23 11:15:03.711 [WARN ] [internal.controller.WR3223Controller] - Command SM is not supported by the controller.
2020-12-23 11:15:03.856 [WARN ] [internal.controller.WR3223Controller] - Command SN is not supported by the controller.
2020-12-23 11:15:04.003 [WARN ] [internal.controller.WR3223Controller] - Command DA is not supported by the controller.
2020-12-23 11:15:04.149 [WARN ] [internal.controller.WR3223Controller] - Command DE is not supported by the controller.
2020-12-23 11:15:06.062 [WARN ] [internal.controller.WR3223Controller] - Command WS is not supported by the controller.
2020-12-23 11:15:27.103 [WARN ] [internal.controller.WR3223Controller] - The control device is active! Openhab can only control the WR3223, when the control device is removed. (Bedienteil)
As you see, all of that with the control device still conected.
Regarding the filter message, I thought this routine would be a little more complex than just counting round about 2 mounth…
Thanks so far,
best regards,
Jan
