Hi
Based on the stack trace, I suspect that OpenHAB cannot access the USB adapter. The error happens, by opening the serial port. Have you checked, if the serial-to-usb adapter is really available at “/dev/ttyUSB0”? The user, which is used to run OpenHAB, has the permission to access the USB adapter?
# What is the result of this commands?
ls -l /dev/ttyUSB*
ls -l /sys/class/tty/ttyU*
# Which groups the OpenHAB user have?
groups <openhab user>
Hi again,
I’m still using the DeLock adapter cable the guys suggested on OH 3.
Now I seem to have everything connected like expected but getting the following according to the logs:
2022-02-15 23:18:31.925 [INFO ] [internal.controller.WR3223Controller] - Connected to WR3223 over serial port /dev/ttyUSB0.
2022-02-15 23:18:33.953 [ERROR] [internal.controller.WR3223Controller] - Communication error to WR3223.
java.io.EOFException: null
at java.io.DataInputStream.readByte(DataInputStream.java:272) ~[?:?]
at org.openhab.binding.wr3223.internal.client.AbstractWR3223Connector.readAnswer(AbstractWR3223Connector.java:230) ~[bundleFile:?]
at org.openhab.binding.wr3223.internal.client.AbstractWR3223Connector.read(AbstractWR3223Connector.java:119) ~[bundleFile:?]
at org.openhab.binding.wr3223.internal.controller.WR3223Controller.checkIfCommandIsAvailable(WR3223Controller.java:336) ~[bundleFile:?]
at org.openhab.binding.wr3223.internal.controller.WR3223Controller.run(WR3223Controller.java:142) [bundleFile:?]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:305) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:305) [?:?]
Hello Ralph
Is there an update of the binding for OH4 necessary? I hadn’t found time to delve into OH4 until now. But if there is an update of the Binding required, I will do it.
2023-08-13 20:00:12.430 [ERROR] [Events.Framework ] - FrameworkEvent ERROR
org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.wr3223 [312]
Unresolved requirement: Import-Package: org.openhab.core.io.transport.serial
at org.eclipse.osgi.container.Module.start(Module.java:463) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel$2.run(ModuleContainer.java:1847) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor$1$1.execute(EquinoxContainerAdaptor.java:136) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1840) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1783) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1745) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1667) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:345) ~[org.eclipse.osgi-3.18.0.jar:?]
2023-08-13 20:00:18.109 [WARN ] [org.apache.felix.fileinstall ] - Error while starting bundle: file:/usr/share/openhab/addons/org.openhab.binding.wr3223-3.0.1.jar
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:445) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundle(DirectoryWatcher.java:1260) ~[?:?]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundles(DirectoryWatcher.java:1233) ~[?:?]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startAllBundles(DirectoryWatcher.java:1221) ~[?:?]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.doProcess(DirectoryWatcher.java:515) ~[?:?]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.process(DirectoryWatcher.java:365) ~[?:?]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.run(DirectoryWatcher.java:316) ~[?:?]
Hi Ralph
It looks like that is a system OH Core Bundle “Serial Transport” missing. Can you try to install the “Serial Binding”? This is officially binding, and it also uses the “Serial Transport” Core Binding.
If this not work, try to connect to the OH console (The Console | openHAB) and check with the command “bundle:list” if the “Serial Transport” binding is installed. If not, you can try with the “bundle:install” command to install it.
