I cannot figure out how to setup rollershutters.
I can get eighter end positions right or the intermittent:
with item setup as:
Rollershutter R_S_W "Roller West [%d %%]" <rollershutter> { zwave="7:invert_state=false" }
I get:
- 0% roller fully opened (as expected)
- 100% roller fully closed (as expected)
- 25% roller 3/4 closed (wrong, should be 1/4 closed)
- 75% roller 1/4 closed (wrong, should be 3/4 closed)
When I change setting from 25% to 75% roller goes up.
I tried the other version:
Rollershutter R_S_W "Roller West [%d %%]" <rollershutter> { zwave="7:invert_state=true" }
with reversed motor wires to match up and down arrows and I got:
- 100% roller fully opened (wrong, should be closed)
- 100% roller fully closed (wrong, should be opened)
- 25% roller 1/4 closed (as expected)
- 75% roller 1/3 closed (as expected)
In both cases icons reflect the percentage values.
I saw simmilar case with the other binding here: Rollershutter STATE invert
The z-wave binding is in version 1.8, as in 1.7 definitions for my Philio PAN08 were missing.
In the log I see entries like:
NODE 8: No converter found for item = R_S_W, endpoint = 0, ignoring event.
Any hints?
