WTRFID Mini Keypad RFID/Z-Wave
I just bought a WTRFID Mini RFID Keypad with Z-Wave. The keypad is already in the Zwave database:
https://github.com/openhab/org.openhab.binding.zwave/blob/master/ESH-INF/thing/wintop_wtrfid_0_0.xml
I included it successfully into my Zwave network. So far, so good :slight_smile:
Question 1: it uses the USER_CODE command class, Chris already added it to the Zwave binding. In the Paper UI it isn’t possible to configure some user codes, the USER_CODE command class doesn’t show up when I edit the thing.
However, in Habmin it’s there and I can enter and save user codes. Why isn’t it shown in Paper UI?
Question 2: So I configured a user code in order to disable the alarm. When I enter the code, it doesn’t seem to work, and the debug log of the Zwave binding shows the following.
22:56:00.068 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 28: Incoming command class USER_CODE
22:56:00.068 [DEBUG] [mmandclass.ZWaveUserCodeCommandClass] - NODE 28: Received UserCode Request
22:56:00.068 [DEBUG] [mmandclass.ZWaveUserCodeCommandClass] - NODE 28: USER_CODE_REPORT 0 is AVAILABLE
22:56:00.068 [DEBUG] [mmandclass.ZWaveUserCodeCommandClass] - NODE 28: UserCode(0) length is too long (12 bytes)
22:56:00.068 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 28: Got an event from Z-Wave network: ZWaveUserCodeValueEvent
22:56:00.068 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 28: Got a value event from Z-Wave network, endpoint = 0, command class = USER_CODE, value =
22:56:00.218 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 28: Application Command Request (ALIVE:DONE)
I’m wondering if the log message ā€œUserCode(0) length is too long (12 bytes)ā€ maybe is the problem… I read that the stored user code is only 10 bytes long, but maybe this is a new version of the device, and now the code is 12 bytes long?
Does anybody have an idea how I could proceed with this issue? Or does someone else got that device up and running at home?
Best regards,
Christian
After some further research I found this in @chris Code: org.openhab.binding.zwave/src/main/java/org/openhab/binding/zwave/internal/protocol/commandclass/ZWaveUserCodeCommandClass.java at main Ā· openhab/org.openhab.binding.zwave Ā· GitHub
Line 47:
public static final int USER_CODE_MAX_LENGTH = 10;
Line 113:
                if (size > USER_CODE_MAX_LENGTH) {
                            logger.debug("NODE {}: UserCode({}) length is too long ({} bytes)", getNode().getNodeId(), id, size);
                            size = USER_CODE_MAX_LENGTH;
This sounds like the source of my problem, right?
Are there some instructions around how to build the binding myself? Do I just have to build a JAR file out of the changed code and put this in the addons directory?
Christian
The ZWave protocol states -:
These fields contain the user code. Minimum code length is 4 and maximum 10 ASCII digits.
This is from the current spec, so I don’t think the binding is wrong. What command class version does this device report it’s using?
      <commandClass>USER_CODE</commandClass>
      <userCodeCommandClass>
        <version>1</version>
        <instances>1</instances>
        <versionSupported>1</versionSupported>
Is that what you’re looking for?
Christian
Yep - thanks - this is consistent with the documentation. So I think 10 bytes is the maximum as per the protocol - why do you think this device allows 12 bytes?
Well, when I read the RFID code or enter the user code via the keypad, this log message is generated… so I thought it might be the keypad sends 12 bytes instead of 10 bytes.
Fyi, this is the trace log:
openhab> log:set trace org.openhab.binding.zwave
openhab> log:tail zwave | grep "NODE 28"
15:26:16.425 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 28: Application Command Request (INITIALIZING:PING)
15:26:16.425 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 28: Node is ALIVE. Init stage is PING.
15:26:16.425 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 28: Node Status event during initialisation - Node is ALIVE
15:26:16.425 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 28: Node advancer - PING: queue length(0), free to send(true)
15:26:16.425 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 28: Node advancer: loop - PING try 1: stageAdvanced(false)
15:26:16.425 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 28: Node advancer: PING - send NoOperation
15:26:16.425 [DEBUG] [ndclass.ZWaveNoOperationCommandClass] - NODE 28: Creating new message for command No Operation
15:26:16.425 [TRACE] [wave.internal.protocol.SerialMessage] - NODE 28: Creating empty message of class = SendData (0x13), type = Request (0x00)
15:26:16.425 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 28: Node advancer - queued packet. Queue length is 1
15:26:16.426 [TRACE] [alization.ZWaveNodeInitStageAdvancer] - NODE 28: Node Status event during initialisation processed
15:26:16.426 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 28: Got an event from Z-Wave network: ZWaveNodeStatusEvent
15:26:16.426 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 28: Setting ONLINE
15:26:16.426 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 28: Sending REQUEST Message = 01 08 00 13 1C 01 00 25 1E C2
15:26:16.426 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 28: Node Status event - Node is ALIVE
15:26:16.426 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 28: Incoming command class USER_CODE
15:26:16.426 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 28: Command class USER_CODE not found, trying to add it.
15:26:16.426 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 28: Creating new instance of command class USER_CODE
15:26:16.426 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 28: Command class USER_CODE, endpoint null created
15:26:16.426 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 28: Adding command class USER_CODE
15:26:16.426 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 28: Adding command class USER_CODE to the list of supported command classes.
15:26:16.426 [TRACE] [ssage.ApplicationCommandMessageClass] - NODE 28: Found Command Class USER_CODE, passing to handleApplicationCommandRequest
15:26:16.426 [DEBUG] [mmandclass.ZWaveUserCodeCommandClass] - NODE 28: Received UserCode Request
15:26:16.426 [DEBUG] [mmandclass.ZWaveUserCodeCommandClass] - NODE 28: USER_CODE_REPORT 0 is AVAILABLE
15:26:16.426 [DEBUG] [mmandclass.ZWaveUserCodeCommandClass] - NODE 28: UserCode(0) length is too long (12 bytes)
15:26:16.426 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 28: CC event during initialisation stage IDLE
15:26:16.427 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 28: Got an event from Z-Wave network: ZWaveUserCodeValueEvent
15:26:16.427 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 28: Got a value event from Z-Wave network, endpoint = 0, command class = USER_CODE, value =
15:26:16.435 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 28: Sent Data successfully placed on stack.
15:26:16.514 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 28: Application Command Request (ALIVE:DETAILS)
15:26:16.514 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 28: Incoming command class WAKE_UP
15:26:16.514 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 28: Command class WAKE_UP not found, trying to add it.
15:26:16.514 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 28: Creating new instance of command class WAKE_UP
15:26:16.514 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 28: Command class WAKE_UP, endpoint null created
15:26:16.514 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 28: Adding command class WAKE_UP
15:26:16.514 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 28: Adding command class WAKE_UP to the list of supported command classes.
15:26:16.514 [TRACE] [ssage.ApplicationCommandMessageClass] - NODE 28: Found Command Class WAKE_UP, passing to handleApplicationCommandRequest
15:26:16.514 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 28: Received Wake Up Request
15:26:16.514 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 28: Received WAKE_UP_NOTIFICATION
15:26:16.514 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 28: Is awake with 0 messages in the wake-up queue.
15:26:16.514 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 28: Wakeup during initialisation.
15:26:16.514 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 28: Node advancer - DETAILS: queue length(1), free to send(false)
15:26:16.514 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 28: Node advancer - queued packet. Queue length is 1
15:26:16.514 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 28: Got an event from Z-Wave network: ZWaveWakeUpEvent
15:26:16.923 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 28: SendData Request. CallBack ID = 30, Status = Transmission complete and ACK received(0)
15:26:16.923 [WARN ] [l.serialmessage.SendDataMessageClass] - NODE 28: Already processed another send data request for this callback Id, ignoring.
15:26:17.515 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 28: No more messages, go back to sleep
15:26:17.515 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 28: Creating new message for application command WAKE_UP_NO_MORE_INFORMATION
15:26:17.515 [TRACE] [wave.internal.protocol.SerialMessage] - NODE 28: Creating empty message of class = SendData (0x13), type = Request (0x00)
^C
I checked the device manual - it states -:
NOTE: Code length must be 4 to 10 ASCII digits.
That’s right, and there are only 10 digits stored:
          <entry>
            <int>1</int>
            <userCode>
              <state>OCCUPIED</state>
              <code>1234&#x0;&#x0;&#x0;&#x0;&#x0;&#x0;</code>
              <outer-class reference="../../../.."/>
            </userCode>
          </entry>
In this case I entered ā€˜1234’ as the user code, the remaining 6 digits are substituted with
&#x0;
But when I press the ā€˜Home’ button, enter ā€˜1234’ and press the ā€˜Enter’ key, the above log message (12 bytes) is displayed… same thing when pressing ā€˜Home’ and placing the RFID chip in front of the reader.
Can you provide a debug log showing the data and I’ll take a look here.
Isn’t this the debug log above? And thanks for having a look into it!!!
I don’t know if you can read German, but here’s a site about the keypad with FHEM and some additional code-outputs:
Well, it is part of a debug log, but you filtered out the parts I need.
No - I started to learn when I was working in Bremen a few years back, but never got far enough. I have a friend who knows German well though (Mr Google Translate!).
OK, which part exactly do you need?
Here’s some more debug logging
debug.xml (221.1 KB)
I want the part that you’ve pasted, but without the filtering. It looks like you have grepped on ā€œNode 28:ā€?
Again, this looks like it’s filtered data - sorry…
Yes, I filtered node 28, do you need the whole Zwave log?
Christian
No - I don’t need the whole log. Just the part around where you’ve already provided is fine, but without the filtering. The filtering is removing information that is needed.
OK, I hope this is sufficient, the node woke up and I performed some RFID actions.
debug.xml (121.3 KB)
Thanks again!
Thanks - that’s fine.
It looks like the device is only sending 10 bytes so the binding must be using the wrong numbers.
