I had the same Problem, adding a rfid tag to OH
I use a Zipato Mini Keypad RFID / ZWAVE
The Keypad has the Node ID 4
=============== node4.xml =======================
ROUTING_SLAVE
ENTRY_CONTROL
NOT_USED
0xf4d909c4
4
4
0x97
0x4501
0x6131
false
=============== END node4.xml ==================
i solved it in the following way
Problem 1)
how to get the Code from the RFID Tag:
ZWave Binding runs in Debug Level
Try to use the Tag at te mini Keypad
returns a payload with the key from the RFID Tag
====================LOG Begin ==============================
2017-04-01 18:18:02.156 [DEBUG] [ve.internal.protocol.ZWaveController:209] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 04 0E 6
3 03 00 00 8F C1 4A 10 3D 50 01 04 00 00
2017-04-01 18:18:02.157 [DEBUG] [ssage.ApplicationCommandMessageClass:42] - NODE 4: Application Command Request (ALIVE:DONE)
2017-04-01 18:18:02.158 [DEBUG] [alization.ZWaveNodeInitStageAdvancer:188] - NODE 4: Starting initialisation from DONE
2017-04-01 18:18:02.159 [DEBUG] [ve.internal.protocol.ZWaveController:1140] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@1847bf2 already regis
tered
2017-04-01 18:18:02.160 [DEBUG] [ssage.ApplicationCommandMessageClass:152] - NODE 4: Incoming command class USER_CODE
2017-04-01 18:18:02.161 [DEBUG] [mmandclass.ZWaveUserCodeCommandClass:99] - NODE 4: Received UserCode Request
2017-04-01 18:18:02.161 [DEBUG] [mmandclass.ZWaveUserCodeCommandClass:111] - NODE 4: USER_CODE_REPORT 0 is AVAILABLE
2017-04-01 18:18:02.164 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread:302] - Receive Message = 01 08 00 04 00 04 02 84 07 76
2017-04-01 18:18:02.166 [DEBUG] [ve.internal.protocol.ZWaveController:564] - Notifying event listeners: ZWaveUserCodeValueEvent
2017-04-01 18:18:02.171 [DEBUG] [ding.zwave.handler.ZWaveThingHandler:931] - NODE 4: Got an event from Z-Wave network: ZWaveUserCodeValueEvent
2017-04-01 18:18:02.173 [DEBUG] [ding.zwave.handler.ZWaveThingHandler:940] - NODE 4: Got a value event from Z-Wave network, endpoint = 0, command class = USER_CODE, value =
====================Log End ===========================================================
This is the Log File after using the unknown RFID Tag at the key PAD
payload=00 04 0E 63 03 00 00 8F C1 4A 10 3D 50 01 04 00 00
This is the TAG ID: 8F C1 4A 10 3D 50 01 04 00 00
I checked it again and entered a KeyCode via the keybord These keys were 1 4 2 3 1 4 2 3
=======================Log Begin ======================================================
2017-04-01 16:34:26.568 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 04 0E 63 03
00 00 31 34 32 33 31 34 32 33 00 00
2017-04-01 16:34:26.569 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 4: Application Command Request (ALIVE:DONE)
2017-04-01 16:34:26.569 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 4: Starting initialisation from DONE
2017-04-01 16:34:26.570 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@12ec829 already registered
2017-04-01 16:34:26.570 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 4: Incoming command class USER_CODE
2017-04-01 16:34:26.571 [DEBUG] [mmandclass.ZWaveUserCodeCommandClass] - NODE 4: Received UserCode Request
2017-04-01 16:34:26.571 [DEBUG] [mmandclass.ZWaveUserCodeCommandClass] - NODE 4: USER_CODE_REPORT 0 is AVAILABLE
2017-04-01 16:34:26.571 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveUserCodeValueEvent
=======================Log End ============================================================================
Key Payload payload=00 04 0E 63 03 00 00 31 34 32 33 31 34 32 33 00 00
TAG Payload payload=00 04 0E 63 03 00 00 8F C1 4A 10 3D 50 01 04 00 00
Problem 2)
Send the User Code to the Keypad
i patched in 2.0.0 Snapshot the the ZwaveUserCodeCommandClass
here is mey changed Method
===============Begin SNIP ====================
public SerialMessage setUserCode(int id, String code) {
boolean codeIsZeros = false;
boolean isHexCode=false;
logger.info(“############# code is “+code+”#############################”);
if (!StringUtils.isEmpty(code)) {
code=code.trim();
} else {
code=“”;
if (code.startsWith(“0x”)) {
isHexCode = true;
} else {
// Zeros means delete the code
try {
codeIsZeros = Integer.parseInt(code) == 0;
} catch (NumberFormatException e) {
logger.debug(“NODE {}: Error parsing user code. Code will be removed”);
if (codeIsZeros) {
code = ""; // send no code since we will set UserIdStatusType.AVAILBLE
} // END else ((code.startsWith("x")))
if (codeIsZeros || userCodeIsValid(code)|| isHexCode) {
logger.debug("NODE {}: {} user code for {}", this.getNode().getNodeId(),
codeIsZeros ? "Removing" : "Setting", id);
SerialMessage message = new SerialMessage(this.getNode().getNodeId(), SerialMessageClass.SendData,
SerialMessageType.Request, SerialMessageClass.SendData, SerialMessagePriority.Get);
ByteArrayOutputStream outputData = new ByteArrayOutputStream();
outputData.write((byte) this.getNode().getNodeId());
outputData.write(4 + code.length());
outputData.write((byte) getCommandClass().getKey());
outputData.write(USER_CODE_SET);
outputData.write(id); // identifier, must be 1 or higher
if (codeIsZeros) {
outputData.write(UserIdStatusType.AVAILABLE.key); // status
} else {
outputData.write(UserIdStatusType.OCCUPIED.key); // status
try {
if (isHexCode) {
code=code.replace("0x","");
int len=code.length();
if (! (len%2 == 0)) {
logger.info("code length must be a vielfaches of 2");
return null;
int countBytes=len;
for (int i1=0;i1< countBytes;i1=i1+2) {
int i3=i1+2;
String byteString=code.substring(i1,i3);
byte byteToWrite=(byte)Integer.parseInt(byteString,16);
outputData.write(byteToWrite);
logger.info("########### write "+byteString);
} else {
for (Byte aCodeDigit : code.getBytes("UTF-8")) {
outputData.write(aCodeDigit);
} catch (UnsupportedEncodingException e) {
logger.error("Got UnsupportedEncodingException", e);
message.setMessagePayload(outputData.toByteArray());
return message;
return null;
=============== END SNIP =====================
I compiled the zawave Binding and put i into my openhab / open the karaf console and update the bundle
and set the usercode with habmin for the Keypad the usercode 2
0x8FC14A103D5001040000
================================================ BEGIN LOG ====================================================
2017-04-01 18:24:58.811 [DEBUG] [ding.zwave.handler.ZWaveThingHandler:498] - NODE 4: Configuration update received
2017-04-01 18:24:58.833 [DEBUG] [ding.zwave.handler.ZWaveThingHandler:514] - NODE 4: Configuration update usercode_2 to 0x8FC14A103D5001040000
2017-04-01 18:24:58.835 [INFO ] [mmandclass.ZWaveUserCodeCommandClass:175] - ############# code is 0x8FC14A103D5001040000#############################
2017-04-01 18:24:58.836 [DEBUG] [mmandclass.ZWaveUserCodeCommandClass:248] - NODE 4: Ignoring user code 0x8FC14A103D5001040000: was 22 digits but must be between 4 and 10
2017-04-01 18:24:58.838 [DEBUG] [mmandclass.ZWaveUserCodeCommandClass:197] - NODE 4: Setting user code for 2
2017-04-01 18:24:58.839 [INFO ] [mmandclass.ZWaveUserCodeCommandClass:225] - ########### write 8F
2017-04-01 18:24:58.841 [INFO ] [mmandclass.ZWaveUserCodeCommandClass:225] - ########### write C1
2017-04-01 18:24:58.842 [INFO ] [mmandclass.ZWaveUserCodeCommandClass:225] - ########### write 4A
2017-04-01 18:24:58.843 [INFO ] [mmandclass.ZWaveUserCodeCommandClass:225] - ########### write 10
2017-04-01 18:24:58.845 [INFO ] [mmandclass.ZWaveUserCodeCommandClass:225] - ########### write 3D
2017-04-01 18:24:58.846 [INFO ] [mmandclass.ZWaveUserCodeCommandClass:225] - ########### write 50
2017-04-01 18:24:58.848 [INFO ] [mmandclass.ZWaveUserCodeCommandClass:225] - ########### write 01
2017-04-01 18:24:58.849 [INFO ] [mmandclass.ZWaveUserCodeCommandClass:225] - ########### write 04
2017-04-01 18:24:58.850 [INFO ] [mmandclass.ZWaveUserCodeCommandClass:225] - ########### write 00
2017-04-01 18:24:58.852 [INFO ] [mmandclass.ZWaveUserCodeCommandClass:225] - ########### write 00
2017-04-01 18:24:58.853 [DEBUG] [ve.internal.protocol.ZWaveController:547] - Message queued. Queue length = 1. Queue={}
2017-04-01 18:24:58.855 [DEBUG] [mmandclass.ZWaveUserCodeCommandClass:158] - NODE 4: Creating new message for application command USER_CODE_GET(2)
===================================== END LOG ==================================
Now i can use my Tag and asking the keypad for used codes returns the right HEX Code
I have marked the RFID code >>>>>>>8F C1 4A 10 3D 50 01 04 00 00<<<<<< to see it better in the Log
=============================== Begin Log ====================================
2017-04-01 18:25:50.797 [DEBUG] [ve.internal.protocol.ZWaveController:1320] - Receive queue TAKE: Length=0
2017-04-01 18:25:50.800 [DEBUG] [wave.internal.protocol.SerialMessage:255] - Assembled message buffer = 01 14 00 04 00 04 0E 63 03 02 01 >>>>>>>8F C1 4A 10 3D 50 01 04 00 00<<<<<< FA
2017-04-01 18:25:50.803 [DEBUG] [ve.internal.protocol.ZWaveController:1321] - Process Message = 01 14 00 04 00 04 0E 63 03 02 01 8F C1 4A 10 3D 50 01 04 00 00 FA
2017-04-01 18:25:50.805 [DEBUG] [ve.internal.protocol.ZWaveController:209] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 04 0E 63 03 02 01 8F C1 4A 10 3D 50 01 04 00 00
2017-04-01 18:25:50.807 [DEBUG] [ssage.ApplicationCommandMessageClass:42] - NODE 4: Application Command Request (ALIVE:DONE)
2017-04-01 18:25:50.808 [DEBUG] [alization.ZWaveNodeInitStageAdvancer:188] - NODE 4: Starting initialisation from DONE
2017-04-01 18:25:50.809 [DEBUG] [ve.internal.protocol.ZWaveController:1140] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@1847bf2 already registered
2017-04-01 18:25:50.810 [DEBUG] [ssage.ApplicationCommandMessageClass:152] - NODE 4: Incoming command class USER_CODE
2017-04-01 18:25:50.811 [DEBUG] [mmandclass.ZWaveUserCodeCommandClass:99] - NODE 4: Received UserCode Request
2017-04-01 18:25:50.812 [DEBUG] [mmandclass.ZWaveUserCodeCommandClass:111] - NODE 4: USER_CODE_REPORT 2 is OCCUPIED
2017-04-01 18:25:50.813 [DEBUG] [mmandclass.ZWaveUserCodeCommandClass:128] - NODE 4: USER_CODE_REPORT 2 is OCCUPIED [��J^P=P^A^D^@^@]
2017-04-01 18:25:50.814 [DEBUG] [ve.internal.protocol.ZWaveController:564] - Notifying event listeners: ZWaveUserCodeValueEvent
2017-04-01 18:25:50.815 [DEBUG] [ding.zwave.handler.ZWaveThingHandler:931] - NODE 4: Got an event from Z-Wave network: ZWaveUserCodeValueEvent
2017-04-01 18:25:50.817 [DEBUG] [ding.zwave.handler.ZWaveThingHandler:940] - NODE 4: Got a value event from Z-Wave network, endpoint = 0, command class = US
================================ END LOG =====================================
Now i can use the RFID Tag like a usercode with pressing keys on the keypad
@chris:
is it possible to show the key code in HEX and ASCII
ad to use the Hex Input (showd in my patched Version) for the next Versions
Yes a read the Documentation, but in my opinion it is not so clear to use only 10 Ascii DIGITS
in my case also 10 Hex Digits working to
the Zipato Documentation says
"After sending the User Code Set , including a Unique User Indentifier (UID) the in use State (0x01) and the TAG Code
or a keypad sequence using ascii codes. the mini keypad will accept the code and notify other devices using the alarm command class. ...."
It seems to be that only the keypad sequence is in asccii code
thanks in advance
Alexander
