Amazing how you get the Xiaomi devices talking to openhab. I’m a big fan and can finally get in touch now.
Just for the details, I live in a smoggy environment and own some Xiaomi devices that measure and clean the air in the house. Your binding offers me a great overview when and when not to go outside with my kids (taken from the outside measurements). So “Thanks!”.
Now my questions
After successfully have added some Xiaomi Air Purifier 2 models I now went ahead and added a Xiaomi Air Purifier 2S. This one does not seem to be be properly discovered and have a challenges getting the binding to talk properly with the new 2S model.
Most I tried can be found here: Xiaomi Robot Vacuum Binding
Quick summary of my efforts:
Discovery mechanism: miio discover (nodeJs). Output:
Device ID:
Model info: Unknown
Address:
Token: ???
Support: Unknown
Note: Device ID and Address where properly filled. Just deleted for this example.
Using a token of another older air purifier I’ve tried the following models:
zhimi.airpurifier.m1
zhimi.airpurifier.m2
zhimi.airpurifier.mc1
zhimi.airpurifier.v6
All coming back with the well known “Padding” issue in the log.
When opening the “Thing” in Openhab, all channels are properly shown and the Items are linked. The device is online. Every try has been performed with deleting the device, and adding it. Never just changing the config.
Binding version from market place is the 1.0 version. Openhab used is 2.3.0-1
It would be great if you could support me. Let me know if I can provide any information you need to pinpoint the issue.
Each device had it own token, I think your need to find the token from your new device (of you are on Android that means downgrading your app)
Device ID and address don’t need token, hence that works, padding error is happening mostly in case of wrong tokens
I understand the token is the missing part, however the “mii discovery” method (Miio command line tool described here: https://www.home-assistant.io/components/vacuum.xiaomi_miio/#retrieving-the-access-token) did not reveal the token for the new device. The “???” was the exact literal output of that discovery. IOW no token was discovered This method worked fine with the older Purifier 2, hence tried to use that token as suggested in this other post.
npm update -g did not fix the mii disovery either and the token output remains “???”
I’ve no access to an android device at this time, but will try to search one to try your suggestions.
Any other suggestions welcome.
Found an old android lying around. Went through the process and could abstract the token. Thanks a lot!!!
But, then we come to the point that it says: “Database entry for model ‘zhimi.airpurifier.mc1’ cannot be found.”
Also the channels are very incomplete (SSI, BSSI, etc)
This comes back to the earlier support request for this device from @11131.
Do you have a nightly/snapshot I can test (if this is the right question to ask)?
Thanks in advance for your support.
Baseline: IP and token added with default Model ID
Log: Mi IO Device model Mi Air Purifier mc1 (zhimi.airpurifier.mc1) identified as: miio:unsupported, thingtype miio:basic. Does not matches thingtype miio:unsupported. Unexpected, unless unless manual override.
Channels:
Very basic
This model Id is used with the older Xiaomi Air Purifier 2.
Log:
Clean! As you mentioned before. This was due to the wrong token. Now with the proper token the Padding messages are not given (in the 5 minutes timeframe I was checking)
Channels:
Same as Xiaomi Air Purifier 2 (so would vote this is the mode Id closest to the new 2S)
Even stronger, now with the new token the data from the channel can actually be used. I got my items configured and data is coming in properly.
Edit: It seems that not all items are receiving proper data with this model Id used for the 2S. Missing are e.g. purifyvolume and usedhours. The channels are shown in the Thing though.
Summary:
I suppose only the zhimi.airpurifier.mc1 needs to be added to the db, with the channels copied from zhimi.airpurifier.m1.
it is added now with the channels of m1. Should be available in the market for updating in approx 40 min
note, best to delete your thing and let it be discovered again to ensure it is being picked up well.
After upgrading from OpenHab 2.3 to 2.4, my purifiers started to beep randomly every few hours or so. Sounds pretty much like a mode switch. Was there new behavior introduced to sync states between OH and the devices? I don’t mind in the living room, but it’s kinda less cool in the bed room.
If there’s something new done in handling them, then it turns out it might be crashing the firmware. My two purifiers are different hardware and firmware revisions, and one stops quickly and then restarts. The beeping isn’t some mode setting but apparently the firmware restarting.
There was an update in the 2.4 version recently (week or 2 ago) that addressed this issue. every 1000 refreshes I reset the id, seems some devices did not like that the id started again from 0.
I added Air Purifier in PaperUI as “basic thing”, I think this is wrong becouse I have only 2 channels! What I should to do to add properly this thing?
I preffer add things by conf-files, but I can use PaperUI too.
Recent binding should support this, however, small workaround would be to configure / overwrite the model in the config to zhimi.airpurifier.m1 (you can experiment as well with zhimi.airpurifier.v6 or with v1). You can use text based configs as well…
