I need some help setting them up. I am running OpenHABian on a Raspberry PI 3 (OpenHab 2.1.0-1). I already downloaded the “org.openhab.binding.yeelight-2.1.0-SNAPSHOT.jar” and placed it in “/usr/share/openhab2/addon/”.
I setup the 2 items using the Yeelight app and confirmed that the both work. I also set the strip to “Developer Mode” within the app.
The binding is showing in PaperUI but I don’t see anything in my inbox. I added both the light by ip manually, like this:
YEELIGHT://172.20.1.122:55443
Thanks for the help. I changed the items to “Developer Mode” in the app and it could be discovered on my Inbox (PaperUI). Both work now without a problem.
Do you have any example on how to add these as items and things? I want to not use the PaperUI.
I managed to add the following to items:
Dimmer l01_brightness “Bright” {channel=“yeelight:Wonder:0x000000000xxxxxxx:Brightness”}
Color l01_color “Color” {channel=“yeelight:Wonder:0x000000000xxxxxxx:Color”}
Dimmer l01_color_temperature “Color temperature” {channel=“yeelight:Wonder:0x000000000xxxxxxx:Color_Temperature”}
I want to add a on and off switch and the Color section is showing a switch and not a color picker. Can you help?
The binding is called “Yeelight Binding”. You also need to setup the light in the ios or andriod app. You HAVE to enable developer mode. After that you will find the item in your inbox.
I am freakin out ..
First of all - thanks to everybody who is putting work and knowledge in here. Found a lot, but not what I am searching for right now.
I am running openhabian2.2 on a raspberrypi3, that is connected via LAN to my network.
I copied the binding zip-file to the addons-folder, and it shows.
I tried to add a new thing, but there is no way to specify some IP or token.
Maybe thats why it still shows “OFFLINE” while the bulb is running (Color LED Bulb).
In the YEELIGHT App, I set the LAN mode (is it the same as debug mode?). But I can’t get it running.
Has anybody made a tutorial? It is very exhausting to search through all the threads without finding a solution.
I tried to find on youtube and here, but no chance.
So help would be very much appreciated.
PS: I am not very experienced yet. Just get started, so what is obvious to you is not necessarily obvious to me.
Thanks!
