Xiaomi Zigbee devices to MQTT bridge
I got Xiaomi zigbee switches working with zigbee-shepherd and hacked together a simple bridge to MQTT
@AndrewL Did you flash another firmware on the dongle or using the same one used for the binding?
I used CC2531ZNP-Pro-Secure_LinkKeyJoin.hex from here: zstack-1.2.2a.44539/CC2531 at master · mtornblad/zstack-1.2.2a.44539 · GitHub
Is this the same firmware you need for the Zigbee binding?
Can you use the dongle with this and with the Zigbee binding at the same time?
Regards.
Firmware is the same I think. You can’t use one stick with this and the binding at the same time, you would need two sticks.
