Xpath
Continuing the discussion from Möhlenhoff Alpha BUS - Solution:
Hi all togehter,
I’m preaty new to openHAB and have some problems with the same heating system from Möhlenhoff.
Firstof all I got it running but the log file give me some warnings and I have now clue why…
this ist the warning:
waring
As far as I understand is there a problem with the XPATH expression.
Channel → State Transformation
XPATH:/Devices/Device/HEATAREA[@nr='2']/T_ACTUAL/text()
Item → XPath Expression
/*[name()='Devices']/*[name()='Device']/*[name()='HEATAREA']/*[name()='T_ACTUAL']/text()
I would aprichiate if somebody can help me!
Thank you.
That error message comes from a profile, a modifier you chose to apply to a channel-to-Item link.
If you’re doing your transformation in the channel then you do not usually want to do another with a profile. You certainly don’t want to apply XPATH if you’ve already done that in the channel.
