I use the New Pride CSS from @pmpkk, see here, I also started with his matrix theme widgets, see here
My mostly complete widget versions are attached, this is my home, downstairs and weather. I’ve not completed my other screens yet. I ended up creating quite a few virtual items to facilitate the type of information I wanted to display. Yes, it takes far more time than it should but this should give you a good starting point.
home.widget.json (9.5 KB)
downstairs.widget.json (21.3 KB)
weather.widget.json (10.4 KB)
FYI - I’m now also using HABPanel Viewer Kiosk inbetween HABPanel and Fully Kiosk Browser, which is now in single app mode. I find the tablet stays repsonsive rather than freezing, it does add a bit of further lag when you first interact with it after some time but once that’s done it’s all good.
