2015-12-05 21:59:23.837 [DEBUG] [eController$ZWaveReceiveThread:1481]- Receive Message = 01 24 00 04 00 0B 1E 8F 01 04 03 80 03 64 09 71 05 00 00 00 FF 06 16 00 05 31 05 03 01 1A 06 31 05 01 0A 00 5A 7C
2015-12-05 21:59:23.849 [DEBUG] [b.z.i.protocol.ZWaveController:1163]- Receive queue TAKE: Length=0
2015-12-05 21:59:23.857 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ]- Assembled message buffer = 01 24 00 04 00 0B 1E 8F 01 04 03 80 03 64 09 71 05 00 00 00 FF 06 16 00 05 31 05 03 01 1A 06 31 05 01 0A 00 5A 7C
2015-12-05 21:59:23.860 [DEBUG] [eController$ZWaveReceiveThread:1405]- Receive queue ADD: Length=0
2015-12-05 21:59:23.867 [DEBUG] [b.z.i.protocol.ZWaveController:1164]- Process Message = 01 24 00 04 00 0B 1E 8F 01 04 03 80 03 64 09 71 05 00 00 00 FF 06 16 00 05 31 05 03 01 1A 06 31 05 01 0A 00 5A 7C
2015-12-05 21:59:23.874 [DEBUG] [b.z.i.protocol.ZWaveController:192 ]- Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 0B 1E 8F 01 04 03 80 03 64 09 71 05 00 00 00 FF 06 16 00 05 31 05 03 01 1A 06 31 05 01 0A 00 5A
2015-12-05 21:59:23.877 [DEBUG] [ApplicationCommandMessageClass:38 ]- NODE 11: Application Command Request (ALIVE:GET_CONFIGURATION)
2015-12-05 21:59:23.881 [DEBUG] [ApplicationCommandMessageClass:56 ]- NODE 11: Incoming command class MULTI_CMD
2015-12-05 21:59:23.884 [DEBUG] [.ZWaveMultiCommandCommandClass:60 ]- NODE 11: Received Multi-Command Request
2015-12-05 21:59:23.889 [DEBUG] [.ZWaveMultiCommandCommandClass:92 ]- NODE 11: Incoming command class BATTERY
2015-12-05 21:59:23.892 [DEBUG] [.ZWaveMultiCommandCommandClass:113 ]- NODE 11: Calling handleApplicationCommandRequest.
2015-12-05 21:59:23.895 [DEBUG] [i.p.c.ZWaveBatteryCommandClass:81 ]- NODE 11: Received Battery Request
2015-12-05 21:59:23.898 [DEBUG] [i.p.c.ZWaveBatteryCommandClass:96 ]- NODE 11: Battery report value = 100
2015-12-05 21:59:23.901 [DEBUG] [b.z.i.protocol.ZWaveController:635 ]- Notifying event listeners: ZWaveCommandClassValueEvent
2015-12-05 21:59:23.906 [DEBUG] [.z.internal.ZWaveActiveBinding:433 ]- ZwaveIncomingEvent
2015-12-05 21:59:23.910 [DEBUG] [.z.internal.ZWaveActiveBinding:450 ]- NODE 11: Got a value event from Z-Wave network, endpoint = 0, command class = BATTERY, value = 100
2015-12-05 21:59:23.915 [DEBUG] [.ZWaveMultiCommandCommandClass:92 ]- NODE 11: Incoming command class ALARM
2015-12-05 21:59:23.919 [DEBUG] [.ZWaveMultiCommandCommandClass:113 ]- NODE 11: Calling handleApplicationCommandRequest.
2015-12-05 21:59:23.923 [DEBUG] [z.i.p.c.ZWaveAlarmCommandClass:82 ]- NODE 11: Received Alarm Request
2015-12-05 21:59:23.926 [DEBUG] [z.i.p.c.ZWaveAlarmCommandClass:94 ]- NODE 11: Alarm report - Value = 0
2015-12-05 21:59:23.931 [DEBUG] [z.i.p.c.ZWaveAlarmCommandClass:112 ]- NODE 11: Alarm Type = General (0)
2015-12-05 21:59:23.935 [DEBUG] [b.z.i.protocol.ZWaveController:635 ]- Notifying event listeners: ZWaveAlarmValueEvent
2015-12-05 21:59:23.938 [DEBUG] [.z.internal.ZWaveActiveBinding:433 ]- ZwaveIncomingEvent
2015-12-05 21:59:23.941 [DEBUG] [.z.internal.ZWaveActiveBinding:450 ]- NODE 11: Got a value event from Z-Wave network, endpoint = 0, command class = ALARM, value = 0
2015-12-05 21:59:23.946 [DEBUG] [.ZWaveMultiCommandCommandClass:92 ]- NODE 11: Incoming command class SENSOR_MULTILEVEL
2015-12-05 21:59:23.950 [DEBUG] [.ZWaveMultiCommandCommandClass:113 ]- NODE 11: Calling handleApplicationCommandRequest.
2015-12-05 21:59:23.954 [DEBUG] [veMultiLevelSensorCommandClass:97 ]- NODE 11: Received Sensor Multi Level Request
2015-12-05 21:59:23.958 [DEBUG] [veMultiLevelSensorCommandClass:131 ]- NODE 11: Sensor Multi Level REPORT received
2015-12-05 21:59:23.961 [DEBUG] [veMultiLevelSensorCommandClass:141 ]- NODE 11: Sensor Type = Luminance(3), Scale = 0
2015-12-05 21:59:23.965 [DEBUG] [veMultiLevelSensorCommandClass:150 ]- NODE 11: Sensor Value = 26
2015-12-05 21:59:23.969 [DEBUG] [b.z.i.protocol.ZWaveController:635 ]- Notifying event listeners: ZWaveMultiLevelSensorValueEvent
2015-12-05 21:59:23.973 [DEBUG] [.z.internal.ZWaveActiveBinding:433 ]- ZwaveIncomingEvent
2015-12-05 21:59:23.977 [DEBUG] [.z.internal.ZWaveActiveBinding:450 ]- NODE 11: Got a value event from Z-Wave network, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 26
2015-12-05 21:59:23.993 [DEBUG] [.ZWaveMultiCommandCommandClass:92 ]- NODE 11: Incoming command class SENSOR_MULTILEVEL
2015-12-05 21:59:23.997 [DEBUG] [.ZWaveMultiCommandCommandClass:113 ]- NODE 11: Calling handleApplicationCommandRequest.
2015-12-05 21:59:24.000 [DEBUG] [veMultiLevelSensorCommandClass:97 ]- NODE 11: Received Sensor Multi Level Request
2015-12-05 21:59:24.013 [DEBUG] [veMultiLevelSensorCommandClass:131 ]- NODE 11: Sensor Multi Level REPORT received
2015-12-05 21:59:24.017 [DEBUG] [veMultiLevelSensorCommandClass:141 ]- NODE 11: Sensor Type = Temperature(1), Scale = 1
2015-12-05 21:59:24.021 [DEBUG] [veMultiLevelSensorCommandClass:150 ]- NODE 11: Sensor Value = 9E+1
2015-12-05 21:59:24.034 [DEBUG] [b.z.i.protocol.ZWaveController:635 ]- Notifying event listeners: ZWaveMultiLevelSensorValueEvent
2015-12-05 21:59:24.038 [DEBUG] [.z.internal.ZWaveActiveBinding:433 ]- ZwaveIncomingEvent
2015-12-05 21:59:24.048 [DEBUG] [.z.internal.ZWaveActiveBinding:450 ]- NODE 11: Got a value event from Z-Wave network, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 9E+1
2015-12-05 21:59:24.058 [DEBUG] [ApplicationCommandMessageClass:85 ]- Transaction not completed: node address inconsistent.
2015-12-05 21:59:24.102 [DEBUG] [eController$ZWaveReceiveThread:1481]- Receive Message = 01 24 00 04 00 0B 1E 8F 01 04 03 80 03 64 09 71 05 00 00 00 FF 06 17 00 05 31 05 03 01 1C 06 31 05 01 0A 00 5A 7B
2015-12-05 21:59:24.146 [DEBUG] [b.z.i.protocol.ZWaveController:1163]- Receive queue TAKE: Length=0
2015-12-05 21:59:24.152 [DEBUG] [eController$ZWaveReceiveThread:1405]- Receive queue ADD: Length=0
2015-12-05 21:59:24.157 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ]- Assembled message buffer = 01 24 00 04 00 0B 1E 8F 01 04 03 80 03 64 09 71 05 00 00 00 FF 06 17 00 05 31 05 03 01 1C 06 31 05 01 0A 00 5A 7B
2015-12-05 21:59:24.167 [DEBUG] [b.z.i.protocol.ZWaveController:1164]- Process Message = 01 24 00 04 00 0B 1E 8F 01 04 03 80 03 64 09 71 05 00 00 00 FF 06 17 00 05 31 05 03 01 1C 06 31 05 01 0A 00 5A 7B
2015-12-05 21:59:24.199 [DEBUG] [b.z.i.protocol.ZWaveController:192 ]- Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 0B 1E 8F 01 04 03 80 03 64 09 71 05 00 00 00 FF 06 17 00 05 31 05 03 01 1C 06 31 05 01 0A 00 5A
2015-12-05 21:59:24.202 [DEBUG] [ApplicationCommandMessageClass:38 ]- NODE 11: Application Command Request (ALIVE:GET_CONFIGURATION)
2015-12-05 21:59:24.209 [DEBUG] [ApplicationCommandMessageClass:56 ]- NODE 11: Incoming command class MULTI_CMD
2015-12-05 21:59:24.229 [DEBUG] [.ZWaveMultiCommandCommandClass:60 ]- NODE 11: Received Multi-Command Request
2015-12-05 21:59:24.240 [DEBUG] [.ZWaveMultiCommandCommandClass:92 ]- NODE 11: Incoming command class BATTERY
2015-12-05 21:59:24.247 [DEBUG] [.ZWaveMultiCommandCommandClass:113 ]- NODE 11: Calling handleApplicationCommandRequest.
2015-12-05 21:59:24.264 [DEBUG] [i.p.c.ZWaveBatteryCommandClass:81 ]- NODE 11: Received Battery Request
2015-12-05 21:59:24.268 [DEBUG] [i.p.c.ZWaveBatteryCommandClass:96 ]- NODE 11: Battery report value = 100
2015-12-05 21:59:24.271 [DEBUG] [b.z.i.protocol.ZWaveController:635 ]- Notifying event listeners: ZWaveCommandClassValueEvent
2015-12-05 21:59:24.275 [DEBUG] [.z.internal.ZWaveActiveBinding:433 ]- ZwaveIncomingEvent
2015-12-05 21:59:24.279 [DEBUG] [.z.internal.ZWaveActiveBinding:450 ]- NODE 11: Got a value event from Z-Wave network, endpoint = 0, command class = BATTERY, value = 100
2015-12-05 21:59:24.290 [DEBUG] [.ZWaveMultiCommandCommandClass:92 ]- NODE 11: Incoming command class ALARM
2015-12-05 21:59:24.296 [DEBUG] [.ZWaveMultiCommandCommandClass:113 ]- NODE 11: Calling handleApplicationCommandRequest.
2015-12-05 21:59:24.303 [DEBUG] [z.i.p.c.ZWaveAlarmCommandClass:82 ]- NODE 11: Received Alarm Request
2015-12-05 21:59:24.307 [DEBUG] [z.i.p.c.ZWaveAlarmCommandClass:94 ]- NODE 11: Alarm report - Value = 0
2015-12-05 21:59:24.314 [DEBUG] [z.i.p.c.ZWaveAlarmCommandClass:112 ]- NODE 11: Alarm Type = General (0)
2015-12-05 21:59:24.318 [DEBUG] [b.z.i.protocol.ZWaveController:635 ]- Notifying event listeners: ZWaveAlarmValueEvent
2015-12-05 21:59:24.334 [DEBUG] [.z.internal.ZWaveActiveBinding:433 ]- ZwaveIncomingEvent
2015-12-05 21:59:24.338 [DEBUG] [.z.internal.ZWaveActiveBinding:450 ]- NODE 11: Got a value event from Z-Wave network, endpoint = 0, command class = ALARM, value = 0
2015-12-05 21:59:24.343 [DEBUG] [.ZWaveMultiCommandCommandClass:92 ]- NODE 11: Incoming command class SENSOR_MULTILEVEL
2015-12-05 21:59:24.346 [DEBUG] [.ZWaveMultiCommandCommandClass:113 ]- NODE 11: Calling handleApplicationCommandRequest.
2015-12-05 21:59:24.353 [DEBUG] [veMultiLevelSensorCommandClass:97 ]- NODE 11: Received Sensor Multi Level Request
2015-12-05 21:59:24.364 [DEBUG] [veMultiLevelSensorCommandClass:131 ]- NODE 11: Sensor Multi Level REPORT received
2015-12-05 21:59:24.368 [DEBUG] [veMultiLevelSensorCommandClass:141 ]- NODE 11: Sensor Type = Luminance(3), Scale = 0
2015-12-05 21:59:24.372 [DEBUG] [veMultiLevelSensorCommandClass:150 ]- NODE 11: Sensor Value = 28
2015-12-05 21:59:24.386 [DEBUG] [b.z.i.protocol.ZWaveController:635 ]- Notifying event listeners: ZWaveMultiLevelSensorValueEvent
2015-12-05 21:59:24.389 [DEBUG] [.z.internal.ZWaveActiveBinding:433 ]- ZwaveIncomingEvent
2015-12-05 21:59:24.393 [DEBUG] [.z.internal.ZWaveActiveBinding:450 ]- NODE 11: Got a value event from Z-Wave network, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 28
2015-12-05 21:59:24.422 [DEBUG] [.ZWaveMultiCommandCommandClass:92 ]- NODE 11: Incoming command class SENSOR_MULTILEVEL
2015-12-05 21:59:24.432 [DEBUG] [.ZWaveMultiCommandCommandClass:113 ]- NODE 11: Calling handleApplicationCommandRequest.
2015-12-05 21:59:24.453 [DEBUG] [veMultiLevelSensorCommandClass:97 ]- NODE 11: Received Sensor Multi Level Request
2015-12-05 21:59:24.457 [DEBUG] [veMultiLevelSensorCommandClass:131 ]- NODE 11: Sensor Multi Level REPORT received
2015-12-05 21:59:24.464 [DEBUG] [veMultiLevelSensorCommandClass:141 ]- NODE 11: Sensor Type = Temperature(1), Scale = 1
2015-12-05 21:59:24.475 [DEBUG] [veMultiLevelSensorCommandClass:150 ]- NODE 11: Sensor Value = 9E+1
2015-12-05 21:59:24.491 [DEBUG] [b.z.i.protocol.ZWaveController:635 ]- Notifying event listeners: ZWaveMultiLevelSensorValueEvent
2015-12-05 21:59:24.503 [DEBUG] [.z.internal.ZWaveActiveBinding:433 ]- ZwaveIncomingEvent
2015-12-05 21:59:24.514 [DEBUG] [.z.internal.ZWaveActiveBinding:450 ]- NODE 11: Got a value event from Z-Wave network, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 9E+1
2015-12-05 21:59:24.526 [DEBUG] [ApplicationCommandMessageClass:85 ]- Transaction not completed: node address inconsistent.
2015-12-05 21:59:26.024 [DEBUG] [eController$ZWaveReceiveThread:1481]- Receive Message = 01 06 00 49 81 00 00 31
2015-12-05 21:59:26.030 [DEBUG] [b.z.i.protocol.ZWaveController:1163]- Receive queue TAKE: Length=0
2015-12-05 21:59:26.034 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ]- Assembled message buffer = 01 06 00 49 81 00 00 31
2015-12-05 21:59:26.037 [DEBUG] [eController$ZWaveReceiveThread:1405]- Receive queue ADD: Length=0
2015-12-05 21:59:26.041 [DEBUG] [b.z.i.protocol.ZWaveController:1164]- Process Message = 01 06 00 49 81 00 00 31
2015-12-05 21:59:26.045 [DEBUG] [b.z.i.protocol.ZWaveController:192 ]- Message: class = ApplicationUpdate (0x49), type = Request (0x00), payload = 81 00 00
2015-12-05 21:59:26.049 [DEBUG] [.ApplicationUpdateMessageClass:112 ]- NODE 255: Application update request. Node Info Request Failed.
2015-12-05 21:59:26.055 [ERROR] [.ApplicationUpdateMessageClass:116 ]- NODE 255: Got Node Info Request Failed. Requeueing
2015-12-05 21:59:26.059 [DEBUG] [b.z.i.protocol.ZWaveController:620 ]- Enqueueing message. Queue length = 2
2015-12-05 21:59:26.063 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:63 ]- Sent message Message: class = RequestNodeInfo (0x60), type = Request (0x00), payload = 0B
2015-12-05 21:59:26.068 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:64 ]- Recv message Message: class = ApplicationUpdate (0x49), type = Request (0x00), payload = 81 00 00
2015-12-05 21:59:26.071 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:65 ]- Checking transaction complete: class=ApplicationUpdate, expected=ApplicationUpdate, cancelled=true
2015-12-05 21:59:26.121 [DEBUG] [z.internal.ZWaveNetworkMonitor:315 ]- Network Monitor: Queue length is 2 - deferring network monitor functions.
2015-12-05 21:59:26.164 [WARN ] [WaveController$ZWaveSendThread:1318]- NODE 255: Too many retries. Discarding message: Message: class = RequestNodeInfo (0x60), type = Request (0x00), payload = 0B
2015-12-05 21:59:26.167 [DEBUG] [WaveController$ZWaveSendThread:1211]- Took message from queue for sending. Queue length = 1
2015-12-05 21:59:26.171 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ]- Assembled message buffer = 01 04 00 60 0B 90
2015-12-05 21:59:26.175 [DEBUG] [WaveController$ZWaveSendThread:1268]- NODE 255: Sending REQUEST Message = 01 04 00 60 0B 90
2015-12-05 21:59:26.188 [DEBUG] [eController$ZWaveReceiveThread:1481]- Receive Message = 01 04 01 60 01 9B
2015-12-05 21:59:26.193 [DEBUG] [b.z.i.protocol.ZWaveController:1163]- Receive queue TAKE: Length=0
2015-12-05 21:59:26.197 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ]- Assembled message buffer = 01 04 01 60 01 9B
2015-12-05 21:59:26.200 [DEBUG] [eController$ZWaveReceiveThread:1405]- Receive queue ADD: Length=0
2015-12-05 21:59:26.205 [DEBUG] [b.z.i.protocol.ZWaveController:1164]- Process Message = 01 04 01 60 01 9B
2015-12-05 21:59:26.209 [DEBUG] [b.z.i.protocol.ZWaveController:192 ]- Message: class = RequestNodeInfo (0x60), type = Response (0x01), payload = 01
2015-12-05 21:59:26.213 [DEBUG] [.s.RequestNodeInfoMessageClass:38 ]- Request node info successfully placed on stack.
2015-12-05 21:59:26.218 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:63 ]- Sent message Message: class = RequestNodeInfo (0x60), type = Request (0x00), payload = 0B
2015-12-05 21:59:26.222 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:64 ]- Recv message Message: class = RequestNodeInfo (0x60), type = Response (0x01), payload = 01
2015-12-05 21:59:26.226 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:65 ]- Checking transaction complete: class=RequestNodeInfo, expected=ApplicationUpdate, cancelled=false
2015-12-05 21:59:28.301 [DEBUG] [eController$ZWaveReceiveThread:1481]- Receive Message = 01 10 00 04 00 0B 0A 8F 01 01 06 31 05 01 0A 00 59 05
2015-12-05 21:59:28.308 [DEBUG] [b.z.i.protocol.ZWaveController:1163]- Receive queue TAKE: Length=0
2015-12-05 21:59:28.313 [DEBUG] [eController$ZWaveReceiveThread:1405]- Receive queue ADD: Length=0
2015-12-05 21:59:28.316 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ]- Assembled message buffer = 01 10 00 04 00 0B 0A 8F 01 01 06 31 05 01 0A 00 59 05
2015-12-05 21:59:28.323 [DEBUG] [b.z.i.protocol.ZWaveController:1164]- Process Message = 01 10 00 04 00 0B 0A 8F 01 01 06 31 05 01 0A 00 59 05
2015-12-05 21:59:28.329 [DEBUG] [b.z.i.protocol.ZWaveController:192 ]- Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 0B 0A 8F 01 01 06 31 05 01 0A 00 59
2015-12-05 21:59:28.332 [DEBUG] [ApplicationCommandMessageClass:38 ]- NODE 11: Application Command Request (ALIVE:GET_CONFIGURATION)
2015-12-05 21:59:28.336 [DEBUG] [ApplicationCommandMessageClass:56 ]- NODE 11: Incoming command class MULTI_CMD
2015-12-05 21:59:28.340 [DEBUG] [.ZWaveMultiCommandCommandClass:60 ]- NODE 11: Received Multi-Command Request
2015-12-05 21:59:28.343 [DEBUG] [.ZWaveMultiCommandCommandClass:92 ]- NODE 11: Incoming command class SENSOR_MULTILEVEL
2015-12-05 21:59:28.347 [DEBUG] [.ZWaveMultiCommandCommandClass:113 ]- NODE 11: Calling handleApplicationCommandRequest.
2015-12-05 21:59:28.350 [DEBUG] [veMultiLevelSensorCommandClass:97 ]- NODE 11: Received Sensor Multi Level Request
2015-12-05 21:59:28.352 [DEBUG] [veMultiLevelSensorCommandClass:131 ]- NODE 11: Sensor Multi Level REPORT received
2015-12-05 21:59:28.356 [DEBUG] [veMultiLevelSensorCommandClass:141 ]- NODE 11: Sensor Type = Temperature(1), Scale = 1
2015-12-05 21:59:28.359 [DEBUG] [veMultiLevelSensorCommandClass:150 ]- NODE 11: Sensor Value = 89
2015-12-05 21:59:28.363 [DEBUG] [b.z.i.protocol.ZWaveController:635 ]- Notifying event listeners: ZWaveMultiLevelSensorValueEvent
2015-12-05 21:59:28.366 [DEBUG] [.z.internal.ZWaveActiveBinding:433 ]- ZwaveIncomingEvent
2015-12-05 21:59:28.369 [DEBUG] [.z.internal.ZWaveActiveBinding:450 ]- NODE 11: Got a value event from Z-Wave network, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 89
2015-12-05 21:59:28.385 [DEBUG] [ApplicationCommandMessageClass:85 ]- Transaction not completed: node address inconsistent.
2015-12-05 21:59:31.181 [WARN ] [WaveController$ZWaveSendThread:1318]- NODE 255: Too many retries. Discarding message: Message: class = RequestNodeInfo (0x60), type = Request (0x00), payload = 0B
2015-12-05 21:59:31.184 [DEBUG] [WaveController$ZWaveSendThread:1211]- Took message from queue for sending. Queue length = 0
2015-12-05 21:59:31.188 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ]- Assembled message buffer = 01 04 00 60 0B 90
2015-12-05 21:59:31.192 [DEBUG] [WaveController$ZWaveSendThread:1268]- NODE 255: Sending REQUEST Message = 01 04 00 60 0B 90
2015-12-05 21:59:31.204 [DEBUG] [eController$ZWaveReceiveThread:1481]- Receive Message = 01 04 01 60 01 9B
2015-12-05 21:59:31.209 [DEBUG] [b.z.i.protocol.ZWaveController:1163]- Receive queue TAKE: Length=0
2015-12-05 21:59:31.213 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ]- Assembled message buffer = 01 04 01 60 01 9B
2015-12-05 21:59:31.217 [DEBUG] [eController$ZWaveReceiveThread:1405]- Receive queue ADD: Length=0
2015-12-05 21:59:31.221 [DEBUG] [b.z.i.protocol.ZWaveController:1164]- Process Message = 01 04 01 60 01 9B
2015-12-05 21:59:31.225 [DEBUG] [b.z.i.protocol.ZWaveController:192 ]- Message: class = RequestNodeInfo (0x60), type = Response (0x01), payload = 01
2015-12-05 21:59:31.228 [DEBUG] [.s.RequestNodeInfoMessageClass:38 ]- Request node info successfully placed on stack.
2015-12-05 21:59:31.232 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:63 ]- Sent message Message: class = RequestNodeInfo (0x60), type = Request (0x00), payload = 0B
2015-12-05 21:59:31.236 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:64 ]- Recv message Message: class = RequestNodeInfo (0x60), type = Response (0x01), payload = 01
2015-12-05 21:59:31.239 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:65 ]- Checking transaction complete: class=RequestNodeInfo, expected=ApplicationUpdate, cancelled=false
2015-12-05 21:59:31.244 [DEBUG] [eController$ZWaveReceiveThread:1481]- Receive Message = 01 06 00 49 81 00 00 31
2015-12-05 21:59:31.250 [DEBUG] [b.z.i.protocol.ZWaveController:1163]- Receive queue TAKE: Length=0
2015-12-05 21:59:31.254 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ]- Assembled message buffer = 01 06 00 49 81 00 00 31
2015-12-05 21:59:31.257 [DEBUG] [eController$ZWaveReceiveThread:1405]- Receive queue ADD: Length=0
2015-12-05 21:59:31.261 [DEBUG] [b.z.i.protocol.ZWaveController:1164]- Process Message = 01 06 00 49 81 00 00 31
2015-12-05 21:59:31.264 [DEBUG] [b.z.i.protocol.ZWaveController:192 ]- Message: class = ApplicationUpdate (0x49), type = Request (0x00), payload = 81 00 00
2015-12-05 21:59:31.268 [DEBUG] [.ApplicationUpdateMessageClass:112 ]- NODE 255: Application update request. Node Info Request Failed.
2015-12-05 21:59:31.272 [WARN ] [.ApplicationUpdateMessageClass:120 ]- NODE 255: Node Info Request Failed 3x. Discarding message: Message: class = RequestNodeInfo (0x60), type = Request (0x00), payload = 0B
2015-12-05 21:59:31.276 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:63 ]- Sent message Message: class = RequestNodeInfo (0x60), type = Request (0x00), payload = 0B
2015-12-05 21:59:31.282 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:64 ]- Recv message Message: class = ApplicationUpdate (0x49), type = Request (0x00), payload = 81 00 00
2015-12-05 21:59:31.285 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:65 ]- Checking transaction complete: class=ApplicationUpdate, expected=ApplicationUpdate, cancelled=true
2015-12-05 21:59:34.392 [DEBUG] [eController$ZWaveReceiveThread:1481]- Receive Message = 01 24 00 04 00 0B 1E 8F 01 04 03 80 03 64 09 71 05 00 00 00 FF 06 16 00 05 31 05 03 01 0F 06 31 05 01 0A 00 59 6A
2015-12-05 21:59:34.403 [DEBUG] [b.z.i.protocol.ZWaveController:1163]- Receive queue TAKE: Length=0
2015-12-05 21:59:34.411 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ]- Assembled message buffer = 01 24 00 04 00 0B 1E 8F 01 04 03 80 03 64 09 71 05 00 00 00 FF 06 16 00 05 31 05 03 01 0F 06 31 05 01 0A 00 59 6A
2015-12-05 21:59:34.414 [DEBUG] [eController$ZWaveReceiveThread:1405]- Receive queue ADD: Length=0
2015-12-05 21:59:34.422 [DEBUG] [b.z.i.protocol.ZWaveController:1164]- Process Message = 01 24 00 04 00 0B 1E 8F 01 04 03 80 03 64 09 71 05 00 00 00 FF 06 16 00 05 31 05 03 01 0F 06 31 05 01 0A 00 59 6A
2015-12-05 21:59:34.429 [DEBUG] [b.z.i.protocol.ZWaveController:192 ]- Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 0B 1E 8F 01 04 03 80 03 64 09 71 05 00 00 00 FF 06 16 00 05 31 05 03 01 0F 06 31 05 01 0A 00 59
2015-12-05 21:59:34.432 [DEBUG] [ApplicationCommandMessageClass:38 ]- NODE 11: Application Command Request (ALIVE:GET_CONFIGURATION)
2015-12-05 21:59:34.436 [DEBUG] [ApplicationCommandMessageClass:56 ]- NODE 11: Incoming command class MULTI_CMD
2015-12-05 21:59:34.439 [DEBUG] [.ZWaveMultiCommandCommandClass:60 ]- NODE 11: Received Multi-Command Request
2015-12-05 21:59:34.442 [DEBUG] [.ZWaveMultiCommandCommandClass:92 ]- NODE 11: Incoming command class BATTERY
2015-12-05 21:59:34.448 [DEBUG] [.ZWaveMultiCommandCommandClass:113 ]- NODE 11: Calling handleApplicationCommandRequest.
2015-12-05 21:59:34.452 [DEBUG] [i.p.c.ZWaveBatteryCommandClass:81 ]- NODE 11: Received Battery Request
2015-12-05 21:59:34.457 [DEBUG] [i.p.c.ZWaveBatteryCommandClass:96 ]- NODE 11: Battery report value = 100
2015-12-05 21:59:34.461 [DEBUG] [b.z.i.protocol.ZWaveController:635 ]- Notifying event listeners: ZWaveCommandClassValueEvent
2015-12-05 21:59:34.464 [DEBUG] [.z.internal.ZWaveActiveBinding:433 ]- ZwaveIncomingEvent
2015-12-05 21:59:34.468 [DEBUG] [.z.internal.ZWaveActiveBinding:450 ]- NODE 11: Got a value event from Z-Wave network, endpoint = 0, command class = BATTERY, value = 100
2015-12-05 21:59:34.473 [DEBUG] [.ZWaveMultiCommandCommandClass:92 ]- NODE 11: Incoming command class ALARM
2015-12-05 21:59:34.476 [DEBUG] [.ZWaveMultiCommandCommandClass:113 ]- NODE 11: Calling handleApplicationCommandRequest.
2015-12-05 21:59:34.480 [DEBUG] [z.i.p.c.ZWaveAlarmCommandClass:82 ]- NODE 11: Received Alarm Request
2015-12-05 21:59:34.484 [DEBUG] [z.i.p.c.ZWaveAlarmCommandClass:94 ]- NODE 11: Alarm report - Value = 0
2015-12-05 21:59:34.487 [DEBUG] [z.i.p.c.ZWaveAlarmCommandClass:112 ]- NODE 11: Alarm Type = General (0)
2015-12-05 21:59:34.492 [DEBUG] [b.z.i.protocol.ZWaveController:635 ]- Notifying event listeners: ZWaveAlarmValueEvent
2015-12-05 21:59:34.495 [DEBUG] [.z.internal.ZWaveActiveBinding:433 ]- ZwaveIncomingEvent
2015-12-05 21:59:34.499 [DEBUG] [.z.internal.ZWaveActiveBinding:450 ]- NODE 11: Got a value event from Z-Wave network, endpoint = 0, command class = ALARM, value = 0
2015-12-05 21:59:34.503 [DEBUG] [.ZWaveMultiCommandCommandClass:92 ]- NODE 11: Incoming command class SENSOR_MULTILEVEL
2015-12-05 21:59:34.506 [DEBUG] [.ZWaveMultiCommandCommandClass:113 ]- NODE 11: Calling handleApplicationCommandRequest.
2015-12-05 21:59:34.510 [DEBUG] [veMultiLevelSensorCommandClass:97 ]- NODE 11: Received Sensor Multi Level Request
2015-12-05 21:59:34.514 [DEBUG] [veMultiLevelSensorCommandClass:131 ]- NODE 11: Sensor Multi Level REPORT received
2015-12-05 21:59:34.518 [DEBUG] [veMultiLevelSensorCommandClass:141 ]- NODE 11: Sensor Type = Luminance(3), Scale = 0
2015-12-05 21:59:34.522 [DEBUG] [veMultiLevelSensorCommandClass:150 ]- NODE 11: Sensor Value = 15
2015-12-05 21:59:34.526 [DEBUG] [b.z.i.protocol.ZWaveController:635 ]- Notifying event listeners: ZWaveMultiLevelSensorValueEvent
2015-12-05 21:59:34.529 [DEBUG] [.z.internal.ZWaveActiveBinding:433 ]- ZwaveIncomingEvent
2015-12-05 21:59:34.533 [DEBUG] [.z.internal.ZWaveActiveBinding:450 ]- NODE 11: Got a value event from Z-Wave network, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 15
2015-12-05 21:59:34.545 [DEBUG] [.ZWaveMultiCommandCommandClass:92 ]- NODE 11: Incoming command class SENSOR_MULTILEVEL
2015-12-05 21:59:34.552 [DEBUG] [.ZWaveMultiCommandCommandClass:113 ]- NODE 11: Calling handleApplicationCommandRequest.
2015-12-05 21:59:34.556 [DEBUG] [veMultiLevelSensorCommandClass:97 ]- NODE 11: Received Sensor Multi Level Request
2015-12-05 21:59:34.564 [DEBUG] [veMultiLevelSensorCommandClass:131 ]- NODE 11: Sensor Multi Level REPORT received
2015-12-05 21:59:34.568 [DEBUG] [veMultiLevelSensorCommandClass:141 ]- NODE 11: Sensor Type = Temperature(1), Scale = 1
2015-12-05 21:59:34.588 [DEBUG] [veMultiLevelSensorCommandClass:150 ]- NODE 11: Sensor Value = 89
2015-12-05 21:59:34.592 [DEBUG] [b.z.i.protocol.ZWaveController:635 ]- Notifying event listeners: ZWaveMultiLevelSensorValueEvent
2015-12-05 21:59:34.604 [DEBUG] [.z.internal.ZWaveActiveBinding:433 ]- ZwaveIncomingEvent
2015-12-05 21:59:34.607 [DEBUG] [.z.internal.ZWaveActiveBinding:450 ]- NODE 11: Got a value event from Z-Wave network, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 89
2015-12-05 21:59:34.613 [DEBUG] [ApplicationCommandMessageClass:85 ]- Transaction not completed: node address inconsistent.
2015-12-05 21:59:36.071 [DEBUG] [eController$ZWaveReceiveThread:1481]- Receive Message = 01 06 00 49 81 00 00 31
2015-12-05 21:59:36.077 [DEBUG] [b.z.i.protocol.ZWaveController:1163]- Receive queue TAKE: Length=0
2015-12-05 21:59:36.082 [DEBUG] [eController$ZWaveReceiveThread:1405]- Receive queue ADD: Length=0
2015-12-05 21:59:36.086 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ]- Assembled message buffer = 01 06 00 49 81 00 00 31
2015-12-05 21:59:36.090 [DEBUG] [b.z.i.protocol.ZWaveController:1164]- Process Message = 01 06 00 49 81 00 00 31
2015-12-05 21:59:36.095 [DEBUG] [b.z.i.protocol.ZWaveController:192 ]- Message: class = ApplicationUpdate (0x49), type = Request (0x00), payload = 81 00 00
2015-12-05 21:59:36.098 [DEBUG] [.ApplicationUpdateMessageClass:112 ]- NODE 255: Application update request. Node Info Request Failed.
2015-12-05 21:59:36.102 [WARN ] [.ApplicationUpdateMessageClass:120 ]- NODE 255: Node Info Request Failed 3x. Discarding message: Message: class = RequestNodeInfo (0x60), type = Request (0x00), payload = 0B
2015-12-05 21:59:36.106 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:63 ]- Sent message Message: class = RequestNodeInfo (0x60), type = Request (0x00), payload = 0B
2015-12-05 21:59:36.110 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:64 ]- Recv message Message: class = ApplicationUpdate (0x49), type = Request (0x00), payload = 81 00 00
2015-12-05 21:59:36.114 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:65 ]- Checking transaction complete: class=ApplicationUpdate, expected=ApplicationUpdate, cancelled=true
2015-12-05 21:59:36.197 [WARN ] [WaveController$ZWaveSendThread:1318]- NODE 255: Too many retries. Discarding message: Message: class = RequestNodeInfo (0x60), type = Request (0x00), payload = 0B
