Z-Wave database update for McoHome - IR Thermostat IR2900-ZW
It is safe to say that ZW db updates are never retroactively applied to earlier OH versions. You will either need to upgrade to 4.1 or use this procedure to add that file to your exiting binding. I’d go with the 4.1 if you are buying new devices because this situation will arise again.
