My System: Raspberry Pi 3, Rasbian, OpenHAB 2.5.11, Z-Stick Gen 5, JRE: OpenJDK 1.8.0_152
I just tried to setup a Honeywell / Jasco ZW4103 and it is coming up as an unknown device. Searching I found the following post that seems to suggest this is in the DB.
The link in the post points to the old DB website. When I search the DB I don’t find anything. I took the ID out of the old URL and putting it on the end of the new website URL which seemed to get the page being discussed (link below). This seems to be the GE version of this plug. (maybe this is the wrong DB page)
openhab> list | grep ZWave
241 │ Active │ 80 │ 2.5.11 │ openHAB Add-ons :: Bundles :: ZWave Binding
Based on
My understanding is that Manufacture ID was used to match the Z-Wave device. Maybe I am reading it wrong but the Honeywell ID is 0x39 and the DB has 0063 for the entry you posted. Even if this is a hexadecimal to decimal conversion they don’t match 0x39 => 57.
Seems that you are suggesting that the xml fields <deviceId> and <deviceType> need to be in the DB field Type. As well as <applicationVersion> maps to the DB field Firmware version. These are in sync DB and xml File.
I excluded and reincluded the device with ALL on in the logs. The log has the following entry
2020-12-18 19:08:26.451 [TRACE] [nhab.binding.zwave.discovery.ZWaveDiscoveryService] - NODE 63: Checking zwave:ge_28169_05_000
2020-12-18 19:08:26.852 [WARN ] [nhab.binding.zwave.discovery.ZWaveDiscoveryService] - NODE 63: Device discovery could not resolve to a thingType! 0039:5052:3038::5.25
If you wish to do that here is the guide. Otherwise one of us should be able to do that. If you make an account there, be sure to submit a ticket to get database edit access.
I have an account already but haven’t made an entry yet. Just tried to created one with the following
Label: ZW4103
Description: Z-Wave Plug-in Smart Switch
XML: pasted in the XML in the node xml file in the first post
When submitting I get a dialog in the upper right corner of the page with “Error”. No further explanation provided on what the error might be. Thoughts?
Good to know about the creation of DB entries even if it throws an Error. Once clicking your link I saw the validation error on the Manufacturing in the Label → I guessed that might have been the issue and retried with just the device name → potentially it was already created and errored out for that reason the second time.
DB entry updated, xml exported, and installed on my OpenHAB instance. Everything Works. I’ve submitted it for review in the DB.
I am having the same unknown device issue with my ZW4103. I am running OH 2.5.11 release build. The device is not listed under supported things in the z-wave binding. I see the database entry on OpenSmartHouse and that it has an approval date followed by an OH-3.0.0 tag. Does this mean I need to upgrade to OH3 to pick up the supported thing or can I somehow upgrade the binding?
17 months later, I’m circling back around to this topic.
Recently purchased the Jasco 28169 ZW4103 and I think it is not in the Zwave DB… at least for openhab3.
Should I search for and follow the correct approach to have this created in the OH3x version DB?
Thanks,
Todd
It is in the database - there is no “openhab 3 database”
You device has a slightly different device id though so the question is if yours i s the same - if so, it just needs adding to the list in the database.
So I finally opened up the sheet that came with this device…
It is JASCO
28172-3
ZW4104
I MUST have fat-fingered this initially.
I don’t see this in the DB, either.
Your reference numbers (20562:12345) are 5052:3039 in Hex and MFG is 99 (63 in hex). Take a look to see if that device has all the parameters in your manual
Thanks Bob.
I’ve been trying to find a viable way to locate the device XML in my installation to no avail.
I believe this is what is required for this new device: (added manually to this post)
If I were you I would go to the database and check out the parameters and endpoints of the device I pointed out versus your manual. If they match you can simply add 5052:3039 to the list of references.
If not, you will need to find the XML it should be in openhab-userdata/zwave, but that depends on how you installed OH.
If you do not have Db access follow the guide provided above.
