I want to integrate my Z wave network with OH2 running on my network. I have read the integration notes of Z-wave binding, but it requires a Z-wave stick which is not available here in India (With Legal India Freqancy - other US/UK modules are available), so is there any other way with which I can Integrate my existing Z wave with OH?
A Z-Wave network requires a controller if you are going to use it for more than just connecting devices as peers. There is no other way for IpenHAB or any other software to control a Z-Wave network without a controller.
The Z-Wave system is divided into worldwide regions based on what frequencies are legal to be used.
Using Z-Wave equipment designed for a different region in India is illegal and cannot be discussed on this forum.
Hi,@ Bruce_Osborne
I already have a controller and I already have the whole setup, the only thing Zwave lacks is poor control over media so wanted to use openhab for that, so I am using a leagal controller only but it is not supported by openhab.
All controllers are exactly the same - they all come from Silabs (or Sigma - Silabs bought Sigma last year) and they all work exactly the same (unless you have one of the newest Silabs 700 series which will not work).
Hogar also have a usb controller, I think I should give it a go!!! The Other controller I mentioned earlier doesn’t connect directly to the pi running OH, so I tried using USB to USB connector, but that didn’t work.
The HC Plus is Z-Wave Plus but only handles up to 60 devices?
I thought the Z-Wave specification limit was higher than that. Sounds suspicious to me…
The main way to integrate with a hub like that would be if it supports MQTT.
All ZWave devices use the same chipset (well, there are now 3 or so generations, but from a controller perspective they are all the same with the same API).
This device should be the same unless this company has effectively created a gateway which sits between the ZWave chip and the outside world, this exposing a different API (as boxes like Vera, or the Fibaro Homecentre do).
But it is a Smarthome Hub (~Gateway) like Vera or Fibaro Homecentre or Wink Hub! They could be running as serial Z-Wave Controller with Openhab??? I don’t think so!
Any mains powered Z-Wave device usually also acts as a Z-Wave repeater. There are also some devices sold that are solely repeaters.
I am using a mains powered light switch as a repeater in my house. My plugin sockets also act as repeaters, I hope to extend the range outside my house to a receptacle that is located in the front yard of my house.
