I am using Domitech bulbs and all are showing this behavour. Originally I thought my problem was UI related:
But after setting zwave-binding to DEBUG i found that my problem stems from the binding sending a “false” state update message, resulting in the items state to change:
//use slider to turn on light, first message sets bulb(and item) to correct state:
2017-05-13 13:52:04.163 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Command received zwave:device:908f55eb:node9:switch_dimmer --> 42
2017-05-13 13:52:04.173 [ItemCommandEvent ] - Item 'Licht_Wohnzimmer_Decke' received command 42
2017-05-13 13:52:04.173 [ItemStateChangedEvent ] - Licht_Wohnzimmer_Decke changed from 0 to 42
//but then for whatever reason zwave sets updates the state to 0:
2017-05-13 13:52:04.242 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 9: Starting initialisation from DONE
2017-05-13 13:52:04.242 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@10876532 already registered
2017-05-13 13:52:04.243 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 9: Incoming command class SWITCH_MULTILEVEL
2017-05-13 13:52:04.243 [DEBUG] [ss.ZWaveMultiLevelSwitchCommandClass] - NODE 9: Received SWITCH_MULTILEVEL command V1
2017-05-13 13:52:04.243 [DEBUG] [ss.ZWaveMultiLevelSwitchCommandClass] - NODE 9: Switch Multi Level report, value = 0
2017-05-13 13:52:04.243 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveCommandClassValueEvent
2017-05-13 13:52:04.243 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2017-05-13 13:52:04.243 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Got a value event from Z-Wave network, endpoint = 0, command class = SWITCH_MULTILEVEL, value = 0
2017-05-13 13:52:04.244 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Updating channel state zwave:device:908f55eb:node9:switch_dimmer to 0 [PercentType]
//which in turn messes up the items state:
2017-05-13 13:52:04.246 [ItemStateChangedEvent ] - Licht_Wohnzimmer_Decke changed from 42 to 0
Unfortunatly i can not say for certain after which update of OH this started. It was working OK initially.
Is anybody else having this problem - or any idea how to fix this?
Many thanks in advance,
Best Regards,
-OLI
