The device is in the database, but maybe you have one with a slightly different ID. Suppliers tend to use a number of different IDs so we need to know what yours are.
If you take a look in HABmin the device attributes should show the type/id - we ned to know this information.
Sorry - this doesn’t have the information. I need the type and id - these should also be displayed.
However, it’s also possible that the device hasn’t completed initialiation since the version is showing 0. Please make sure it’s woken up a few times, and that there’s a node2.xml file in the userdata/zwave folder.
hmmm… I can see there is no node2.xml file… only a node1.
I have now tried to remove the ZW120-C from the controller. Then Openhab shows ‘offline’ for node 2’. And then reconnect - and the same… unknow device.
I do believe I have followed the manual exactly ;-)… Will take a look again tomorrow.
But, has anyone experience with the OH2, z-stick Gen5 and ZW120-C ?
Does any one know, if there exist a tool, so I from a mac can plugin the zStick and see if that one believes the node is configured correctly ? (I haven’t been able to google anything).
Make sure that you wake up the device a few times with it close to the controller - the device needs to be woken up a few times so that the binding can download all the data. This must be done in close proximity to the controller.
I have a ZW120 here and it is working fine. If yours doesn’t work, then please ensure that you get a debug log so we can see what’s not working.
I now got the “ZW120 Door/Window sensor Gen5” registered
inside OpenHab – Paper UI . when I ‘remove’ the magnet, I get an event in the
event.log file, so I guess the configuration are all well. The configuration
trick was, that after following the instructions, then do it again, this time
with the controller in “SerialAPI-Mode”.
Now it is working. Thanks for the help and support.
And this takes me to the next challenge. How to get the right text
displayed in the UI/sitemap.
I only get either 1 or 0 or On or OFF.
I had hoped that I could use a map to translate these
values into ‘Åben’ and ‘Lukket’… but I’m getting ignored by the system !!!
