mhilbush
(Mark)
42
The build is done. However… I would recommend against installing a snapshot release after and including build 1427.
See this post. Depending on what DateTime methods you use in your rules, those rules could be badly broken by a recent ESH change.
If you want to pick up a new zwave binding, and don’t want to install a snapshot for the above reason, use the method explained in this post.
