@chris
Hi Chris,
I’m trying your zigbee binding. I can see it starting up fine, and no strange errors reported.
What i’m struggling with is how to join / let it join the zigbee network. The buttons on the remote which i normally use to connect them to each other don’t seem to do anything. When I see the instructions e.g. how to link the remotes/lights to a hue bridge I see that on the hue bridge also a button needs to be pushed to initiate the joining/linking.
Is there such a button that I’ve missed, or should it always be in joining mode?
Note: I’m trying to connect a Philips living color gen 2/3 which is suppose to be zigbee based.
2016-05-11 23:46:06.009 [INFO ] [z.n.p.ZigBeeNetworkManagerImpl:1508 ] - Failed to reach the NETWORK_READY level: getCurrentChannel() failed
2016-05-11 23:46:06.016 [INFO ] [b.z.h.ZigBeeCoordinatorHandler:180 ] - ZigBee current PAN=5871, Channel=-1. Network will be reset.
2016-05-11 23:46:06.924 [INFO ] [z.n.p.ZigBeeNetworkManagerImpl:300 ] - Initialized ZigBee network with existing network state.
2016-05-11 23:46:06.963 [INFO ] [.n.i.ApplicationFrameworkLayer:211 ] - Registered default sending endpoint 1 with clusters: [0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 15, 10, 12, 21, 1794, 256]
2016-05-11 23:46:06.976 [INFO ] [.n.i.ApplicationFrameworkLayer:211 ] - Registered default sending endpoint 2 with clusters: [257, 258, 512, 513, 514, 516, 768, 1027, 1024, 1025, 1026, 1028, 1029, 1030, 2820, 1280]
2016-05-11 23:46:06.982 [INFO ] [.n.i.ApplicationFrameworkLayer:211 ] - Registered default sending endpoint 3 with clusters: [1281, 1282]
2016-05-11 23:46:06.989 [DEBUG] [b.z.h.ZigBeeCoordinatorHandler:197 ] - ZigBee network [zigbee:coordinator_cc2530:baaffcf1] started
2016-05-11 23:46:06.990 [DEBUG] [o.b.z.d.ZigBeeDiscoveryService:44 ] - Creating ZigBee discovery service for zigbee:coordinator_cc2530:baaffcf1
2016-05-11 23:46:06.991 [DEBUG] [o.b.z.d.ZigBeeDiscoveryService:48 ] - Activating ZigBee discovery service for zigbee:coordinator_cc2530:baaffcf1
2016-05-11 23:46:06.994 [DEBUG] [b.z.h.ZigBeeCoordinatorHandler:254 ] - Browsing ZigBee network [zigbee:coordinator_cc2530:baaffcf1]...
2016-05-11 23:46:07.245 [DEBUG] [b.z.h.ZigBeeCoordinatorHandler:280 ] - ZigBee network [zigbee:coordinator_cc2530:baaffcf1] READY. Found 1 nodes.
2016-05-11 23:46:07.246 [INFO ] [ome.event.ThingStatusInfoEvent:43 ] - 'zigbee:coordinator_cc2530:baaffcf1' updated: ONLINE
2016-05-11 23:46:07.246 [INFO ] [nt.ThingStatusInfoChangedEvent:43 ] - 'zigbee:coordinator_cc2530:baaffcf1' changed from INITIALIZING to ONLINE
2016-05-11 23:46:07.247 [DEBUG] [b.z.h.ZigBeeCoordinatorHandler:432 ] - Node Discovery: 00:12:4B:00:01:46:8B:4D
2016-05-11 23:46:07.247 [WARN ] [b.z.h.ZigBeeCoordinatorHandler:439 ] - Node has no devices: 00:12:4B:00:01:46:8B:4D
2016-05-11 23:46:07.248 [DEBUG] [b.z.h.ZigBeeCoordinatorHandler:291 ] - Bridge connection open. Updating thing status to ONLINE.
