Hi!
I have recently bought severall ecodim zigbee 3.0 (led) dimmers (ECO-DIM.07 Led dimmer Zigbee Pro druk/draai 0-200W - EcoDim) and i can’t get them to play nice with the Zigbee binding.
Im running the latest stable version of OH 2 and the binding is running on 2.5.12
When running a discovery the dimmer(s) are found and identified as:
0C4314FFFE236A25: ZigBee node property discovery complete: {zigbee_logicaltype=ROUTER, zigbee_powerlevel=FULL, zigbee_manufacturercode=0x126a, modelId=EcoDim-Zigbee 3.0, zigbee_networkaddress=65330, zigbee_powersource=MAINS, zigbee_stkversion=6, zigbee_datecode=20210228, zigbee_zclversion=3, vendor=EcoDim BV, zigbee_powermode=RECEIVER_ON_IDLE, zigbee_powersources=[MAINS], hardwareVersion=1, firmwareVersion=0x03096530, zigbee_applicationVersion=3}
The dimmer state eventually returns as ONLINE and everything seems well. Yet as soon as a command is send to the dimmer the devices goes offline. According to the debug logs it times out.
I have tried paring the device using the Installcode on the back of the device yet this seems to make no difference. As mentioned in another topic (Zigbee 3.0 Installation Code) the install code should make no difference and the default code should suffce.
My questions:
- The device seems to be properly discoved (vendor etc). Does this mean the device is supported by the binding.
- If the specific install code is required but not present during the pairing process. Would the device stll pair but not work (and not respond to commands like im having) or not pair at all?
- If using the Install code from a things file. What would be the proper syntax? : (eg : zigbee_linkkey=“INSTALLCODE:77A133C3C3A1222FC3C3A1E6”)
Ive included a small portion of the logs.
ecodim_log.txt (7.1 KB)
Any help is very much appreciated!!
