I’m struggeling getting my Tradfri devices to work with an cc2531. After testing with an docker imange on synology, I now installed openhab (2.5.0-1) on a Raspberry 4. On this setup I finally managed to find my things and channels via the zigbee binding. happy
I’ve linked an Tradfri Remote and a Tradfri Switch to a Tradfri Bulb (GU10 400lm). When I press the switch or the toggle on the remote, OpenHab reacts instantly and moves the dimmer bar. But the bulb doesn’t react. Sometimes it takes 10 seconds, sometimes even a couple of minutes before the bulb starts dimming.
Is there anything I can do to get an instant reaction?
Many thanks in advance!
This has been discussed in a few threads and it appears to only affect a few users. This does not apear to be a Zigbee binding issue, but something else.
Is this a new install or an upgrade?
What other bindings do you have installed?
Its a fresh (but manual) install on a new system. I’ve only installed the zigbee binding…
Since I’m in a testing phase I might also try the preconfigured Image…!?
Since I also wanted to use the Pi (Pi4, 4GB) as an Audio Player I used the newest volumio Image (based on debian jessie), installed Zulu and than OpenHab.
Are you using the ZigBee binding? Looking at your log, it looks like you are using the Tradfri binding? You also mention the “tradfri bridge” so I don’t think this is related.
In the mean time I’ve installed a original Hue Bridge (and paired my tradfri bulbs with it). Using the hue-binding I get no lag at all, all bulbs respond immediately. It works as a charm. So it’s either the zigbee binding or the cc2531 stick itself, that causes the problems!?
I am not really able to look at this until people are running the latest version. The current binding has very old libraries and there has been a lot of work done as we’re currently going through formal ZigBee certification on a product (hopefully completing this week).
Until the latest libraries are merged there is little point in me looking into this - sorry. I’m waiting for the following PR to be merged.
Okay… Just making it clear, as I´m running 2.5 Stable release binding for a few weeks on my Odroid C2 system… This seems alot more stable than ever before. Beside the traadfri motion sensor dont work, but thats an issue I read somewhere you´re looking at. All my others devices are running without any issues.
I havn´t tried restarting the system yet though
Just did a restart. Everything came up running again without any issues.
Thats very uncommon for my system. Normally my Trust motion sensor would fail after first restart, as well as the Osram plug. The Hue devices normally survive a restart, but will eventually turn to offline after a coupple of day.
